Broken EK Rad Barb - Page 7 - Overclock.net - An Overclocking Community
Broken EK Rad Barb
post #61 of 75 (permalink) Old 02-04-2019, 12:26 PM
Ashcroft Level 1
Ashcroft's Avatar
Quote: Originally Posted by ThrashZone View Post
Quote: Originally Posted by Shawnb99 View Post
I’m still debating if I should waste my time trying to fix this one or just replace it.
Thinking of replacing all 4 of my EK ones with HWL ones. See if I can fix the leaking one and resell the rest.
If I do have to replace the leaking one I sure won’t do it with another EK one.
Hi,
Most rads are all copper if they state copper rad not EK's so even if a hardware labs radiator cost a hair more at least it's not as complicated in materials used [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
EK rad Material:
- Copper fins
- 90% copper tubing (H90)
- Brass chambers
- Aluminum/Steel housing
That isn't true. EK rads are made in the same factory with the same materials as some other brands by one of the bigger OEM suppliers. There is nothing unique about then aside from the aluminium shell design.
The majority of rads on the market use a mix of materials including copper and brass for the wetted parts and steel or aluminium for the exterior.
Quote: Originally Posted by tatmMRKIV View Post
personally, just got my first EK rad through a phoenix kit... They are overengineered to the point its a negative... I have used HWlabs and before that the OG TFC/Feser rebrands they are the only ones with this extender, the only ones with a movable rad core... I wonder why? maybe its just a bad Idea in PC building...
I mean sure it looks nice having a squarer less manufactured shape but it seems to cause more problems than it solves...
I used to exclusively use EK blocks but now that other companies are out I am looking for alternatives, the plating on EK blocks is reportedly thinner than competitors so eventually the water paths get eaten through on a number of blocks...
That's also a myth based on supposition that changed into a fact while being spread.
There is nothing wrong with having a negative opinion of something based on experience or whatever else but converting opinion into fact is disingenuous and unnecessary and adds to the confusion that newcomers to the hobby have to wade through.
Ashcroft is offline
post #62 of 75 (permalink) Old 02-06-2019, 05:40 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Yeah I really don't see much point in adding a second potential leak on a rad connection frankly
Usually one leak being the actual line fitting is enough for me but what ever
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #63 of 75 (permalink) Old 02-06-2019, 10:22 AM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
After some thought I told myself screw it and will be replacing all 4 of my EL rads for HWL ones. Swapping out the EK res for an Aquacomputer one, and EK block for a Heatkiller.
At the same time figured might as well upgrade the whole system as well so grabbed a 9900k to replace my 5930k.
Shawnb99 is online now
post #64 of 75 (permalink) Old 02-07-2019, 06:17 AM
ThrashZone's Avatar
Hi,
Darn upgrade bug
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #65 of 75 (permalink) Old 02-07-2019, 08:55 AM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
Broken EK Rad Barb
Hi,
Darn upgrade bug
It’s an expensive bug. Specially since I only put my “old” system under water just over 6 months ago only to upgrade it all now.
Crazy part is how the WC parts cost almost as much as the PC. Damn expensive fans
post #66 of 75 (permalink) Old 02-07-2019, 01:10 PM
ThrashZone's Avatar
Hi,
Yeah them fans add up quick
I just get non rgb now they cost nearly half as much.
Post the build when done
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #67 of 75 (permalink) Old 02-07-2019, 01:13 PM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
Hi,
Noctua fans are the big expense for me. $25 each and I have 8 of them.
post #68 of 75 (permalink) Old 02-07-2019, 01:19 PM
ThrashZone's Avatar
Hi,
I'm running 8 fans also on each system too darn push/ pull on rads adds up
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #69 of 75 (permalink) Old 02-07-2019, 09:02 PM
ezveedub is an unknown quantity at this point ezveedub is an unknown quantity at this point
ezveedub's Avatar
I avoided current fan costs years ago buying Gentle Typhoons in group buy a few years ago when they were cheaper....stashed away almost 30 of them...just they aren’t PWM
Sent from my iPhone using Tapatalk Pro
Intel Processor
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
HAF 932
Operating System
Windows 10
ezveedub is online now
post #70 of 75 (permalink) Old 02-07-2019, 11:55 PM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
Hi,
8 is just the case fans. I have 4 360 Rads in push/pull. In total I have around 34-35 fans
I wish I was smarter years ago and bought some Typhoons myself in bulk, then again I never saw myself having 4 rads and even then would of gone bigger if I could.
