Best 90 degree fittimg for soft tubing? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 22 (permalink) Old 02-02-2019, 11:42 AM - Thread Starter
VolatilXplosion's Avatar
Rep: 0
Quote: Originally Posted by ciarlatano View Post
Quote: Originally Posted by VolatilXplosion View Post
Guys please let me know there are ok look at attatched link i bought these should i cancel them? I thought these were leak proof because they don't rotate right? I would just need to tighten them down pointimg the direction i need them to point? Please help this is my first build. I also got these with them check attatched pics please. I was scared of the rotaty or spinning ones cause of the swivel joints on any brand so i bought this combo is it good can you guys please fill me in please. I was gonna use them to point in directions i choose is this possible with the attatched photos?
I have a soft tubing build are there ok? Omg olease help me of i need to cencel my order and get rotary male to female i will if i NEED to even though i am trying to stay away from "rotary" fittings let me know please guys..
The non rotary are fine. No need to cancel. Just keep in mind that you will have very limited control over which way these wind up facing when they are attached.
Have you used these? I was hoping on holding the fitting where i wanted it to point, then finger tighten the male to male adapters that holds it in? Fair enough or impossible? @ciarlatano
VolatilXplosion is offline
post #12 of 22 (permalink) Old 02-02-2019, 11:44 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 368 (Unique: 255)
That won't work. You need rotaries for that. Just grab some Bitspower rotaries, its your best solution.
ciarlatano is offline
post #13 of 22 (permalink) Old 02-02-2019, 12:00 PM - Thread Starter
Rep: 0
Darn it, I cancelled than thanks for the quick reply as they were not shipped yet.
Now the problem I have with bitspower is that they are too expensive, it is like 29.99 for just one and multi packs are way to pricey.
How about these from Alpha cool they are priced reasonably https://www.amazon.com/Alphacool-Fem...fitting+g1%2F4
Also this 2 pack is priced ok aswell https://www.amazon.com/EK-AF-Angled-...fitting+g1%2F4
post #14 of 22 (permalink) Old 02-02-2019, 12:12 PM
News Fiend
ryan92084's Avatar
They only cost that much because you are limiting yourself to Amazon.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 8
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #15 of 22 (permalink) Old 02-02-2019, 12:58 PM - Thread Starter
Rep: 0
Only cause amazon has fast free shipping. Plus returning and canceling is a breeze also getting on the phone with customer servers 24/7 no prob. I worry about smaller retailers often they don't have the leverage of a huge company like amazon. Where do you suggest I look?
Edit, just checked performance pcs website all the 90's are like 20 bucks or more same if not more expensive than amazon although they do have more options but I just need black or black nickel when amazon already has ***.
post #16 of 22 (permalink) Old 02-02-2019, 01:04 PM
ishbu's Avatar
Rep: 0
uhhh
I personally would not recommend non rotary 90s. if when you thread it and its snuggle to your male/male what happens if its facing wrong way? see how my soft tube causes my 90 to be on a angle on pump? if that was turned half other way i would have been screwed but i USED rotary 90.
lol Try ekwb rotary 90's. i have 6 and non leaked. link below. they have silver also. do remember tho, every ones silver is not same. i bought bitspower rotary 3 way and it didnt match all my ekwbs color
https://www.amazon.com/EKWB-EK-AF-An...44722939&psc=1
ishbu is offline
post #17 of 22 (permalink) Old 02-02-2019, 01:08 PM - Thread Starter
Rep: 0
Ok thanks dude I will go ahead and order these they are just what I need Thank you to you and all than helped me appreciate it.
post #18 of 22 (permalink) Old 02-02-2019, 02:05 PM
ciarlatano's Avatar
You are really gambling using EK rotary fittings.....
post #19 of 22 (permalink) Old 02-02-2019, 02:21 PM - Thread Starter
Rep: 0
*** lol i was trying to stay away from any "rotary and just go with fixed standard fittings but it seems as though you can't point them in the direction you want even with male to male adapters? Which i thought would be possible since you can hold the female to female in the position you wanted and just twist the male to male tight? I don't see how this is not possible can some explain this to me please? Or else i guess i will wait till next week when i have some more money to get basically the one and only brand everyone trusts bitspower but it is again a "rotaty swivrl joint which introduces more points of failure due to the swiveling joint lol
post #20 of 22 (permalink) Old 02-02-2019, 04:24 PM
jura11's Avatar
Rep: 97 (Unique: 61)
Hi there
Personally I'm using Barrow fittings and never have issues with them, for price they're hard to beat
https://www.amazon.com/Barrow-Degree...RQL&ref=plSrch
Hope this helps
Thanks, Jura
jura11 is offline
