Best 90 degree fittimg for soft tubing? - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 02-01-2019, 06:09 PM - Thread Starter
VolatilXplosion
VolatilXplosion's Avatar
1/4 thread 3/8 size can someone link me the amazon to the best affordable 90 degree fittings please?
Also is there a fixed 90 fitting? Or are they all rotary? I feel like the rotary fitting are more prone to leaking cause of the swivel feature? Is there a compatible 90 fitting that works with soft tubing but is not rotary?
VolatilXplosion is offline
post #2 of 22 (permalink) Old 02-01-2019, 06:45 PM
Cloudforever Level 1
Cloudforever's Avatar
http://www.performance-pcs.com/
I bought all my fittings from these guys. They do such a good job.
Also, you'll need a 90 + standard soft tubing fitting.
so around 9$ + 5-6$ for your request.
take a look and see
Cloudforever is offline
post #3 of 22 (permalink) Old 02-01-2019, 06:55 PM - Thread Starter
VolatilXplosion
take a look and see
@Cloudforever bro can you please just send me 1 amazon link? I get lost in that website i dont k ow what I'm looking for plus i dont want to register etc i have fast free shipping from amazon plus i have some credit i can use.
post #4 of 22 (permalink) Old 02-01-2019, 06:57 PM
you'll need to match the same type of fittings your using. I cant just give you some random model.
that site is really easy to navigate.
in short, find the fitting you need on there then look it up on amazon =\
post #5 of 22 (permalink) Old 02-01-2019, 07:06 PM - Thread Starter
VolatilXplosion
@Cloudforever i attatched my fittings and tubing is there any way you can just show me a compatible "standard" 90 degree fitting for my system please?
EKWB EK-AF G1/4" 90° Angled Fitting,
Should i order this?
Name:	2019-02-01 18_1549073085190.00.37.jpg
Name:	2019-02-01 18_1549073094740.00.05.jpg
post #6 of 22 (permalink) Old 02-02-2019, 07:09 AM
News Fiend
ryan92084 Level 1
ryan92084's Avatar
Couple of quality brands are monsoon and bitspower. Many people have good luck with the budget minded barrow fittings. Looks like bitspower still does standard non rotary 90s
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 8
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #7 of 22 (permalink) Old 02-02-2019, 07:53 AM
Fish702 Level 1
Fish702's Avatar
Those EK 90s are fine, but they are flat black, I think EK offers black chrome. Seeing you have Black Chrome XSPC fittings pictured above, but I don't like XSPC's angled fittings, solely on looks. I would look at the previously mentioned Monsoon 90s. They offer a black chrome also, and are sold through Amazon.
Fish702 is offline
post #8 of 22 (permalink) Old 02-02-2019, 09:35 AM
Shooting down fallacies
ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about
ciarlatano's Avatar
@VolatilXplosion - I 100% agree with the above. I have had 30+ Bitspower and Monsoon 90s in use over multiple builds without an issue for ~5 years. Two of the five EK 90s I used leaked within a year. I wouldn't touch them again, and a little searching here will show a lot of users with the same experience. Stick to the Bitspower 90s with your XSPC fittings.
ciarlatano is offline
post #9 of 22 (permalink) Old 02-02-2019, 11:16 AM - Thread Starter
VolatilXplosion
Guys please let me know there are ok look at attatched link i bought these should i cancel them? I thought these were leak proof because they don't rotate right? I would just need to tighten them down pointimg the direction i need them to point? Please help this is my first build. I also got these with them check attatched pics please. I was scared of the rotaty or spinning ones cause of the swivel joints on any brand so i bought this combo is it good can you guys please fill me in please. I was gonna use them to point in directions i choose is this possible with the attatched photos?
I have a soft tubing build are there ok? Omg olease help me of i need to cencel my order and get rotary male to female i will if i NEED to even though i am trying to stay away from "rotary" fittings let me know please guys..
Name:	2019-02-02 10_1549131114972.10.47.jpg
Name:	2019-02-02 10_1549131264815.14.13.jpg
post #10 of 22 (permalink) Old 02-02-2019, 11:40 AM
ciarlatano's Avatar
The non rotary are fine. No need to cancel. Just keep in mind that you will have very limited control over which way these wind up facing when they are attached. If they are in line with tubing, you can do whatever you like, but if they are going to be attached to a component, they may be facing entirely the wrong direction when installed.
