Best waterblock polishing cream? - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 02-03-2019, 12:47 AM - Thread Starter
VolatilXplosion's Avatar
Rep: 0
Is there a preferred copper/nickel water block polishing cream? Which one is it if anyone knows? Also is this done by hand or can a polishing machine be used?
If not can you link me to a good block polisher? I might open my block up again to see if i can get is mirror polished as much as i can possibly thanks.
VolatilXplosion is offline
post #2 of 15 (permalink) Old 02-03-2019, 12:54 AM
white owl's Avatar
Rep: 136 (Unique: 103)
Anything that isn't abrasive.
By hand I'd use microfiber and soapy water.
For tools you'd want some sort of rotating sponge or cloth, there are too many for me to list but as long as it isn't abrasive it should be ok.
IMO it would take more time with power tools since your blocks shouldn't be too stained or dirty. Simply rubbing them down with microfiber is probably all it would take.
I wouldn't use any polish, the blocks should have been polished from the factory and the only thing that will remove a polishing (on nickel) is abrasion.
Also becasue of this:
  • Its unique, finely mixed formula produces a rich, brilliant shine on any uncoated, non-ferrous, metal surface including, brass, gold, silver, aluminum, magnesium, pewter, chrome, sterling, copper and stainless steel (no nickel)
  • In addition to restoring the original luster, Simichrome also leaves an invisible, protective coating to prevent further tarnishing and help keep the shine much longer (you don't want an unknown coating in your loop)
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #3 of 15 (permalink) Old 02-03-2019, 12:54 AM
speed_demon's Avatar
Rep: 79 (Unique: 66)
Link takes me to OCN home page.
Any reason you can't use something mild like bar keepers friend? IIRC that's what I used on my swiftech apogee water block years ago. BKF instructions don't have any mention of nickel, good or otherwise however.
Quis custodiet ipsos custodes?
speed_demon is offline
post #4 of 15 (permalink) Old 02-03-2019, 12:57 AM
Hwgeek's Avatar
Rep: 14 (Unique: 12)
I got this white polishing Compounds(Green should be more fine):
look for this kind sticks:
https://www.banggood.com/WhiteGreenP...r_warehouse=CN
Hwgeek is offline
post #5 of 15 (permalink) Old 02-03-2019, 08:54 AM - Thread Starter
Rep: 0
The actual reason i am asking is not only for general polishing of nickel or copper waterblocks, but also because i have corrosion damage from the previous owner that has literally eaten away the nickel plating on my auros 1080ti in a dozen areas on the block, pretty harsh. I have thought about using some fin sandpaper in the troubled areas as long as i stay away from the areas that the o-ring sits although there is damage around that area also. Then after using fine sandpaper i was considering using a metal polish. At this point after using sandpaper does it even matter if the metal polish is abrasive?
I am not talking about the bottom where it sits on the chip, i am talking about the inner blocks metal where the water flows through like a gpus actual water channels are of the block.
post #6 of 15 (permalink) Old 02-03-2019, 09:13 AM - Thread Starter
Rep: 0
Here is the block if you enlarge and look very closely you can see the damage EVERYWHERE especially around the edges chiped and damaged the whole way around and in the middle scattered all over. This is why i am trying to literally FIX this block because you literally CAN'T buy another one at this point for the auros 1080ti it is not produced or out of stock everywhere so i NEED to make this work Lol.
[Ps this was after a soapy water toothbrush scrub and 2 min vinegar bath so it is very clean revealing all the damage in all its glory ***
post #7 of 15 (permalink) Old 02-03-2019, 10:32 AM
cloppy007's Avatar
Rep: 77 (Unique: 53)
Unless any other member suggests a way to fix your nickel plating:
A prolonged vinegar bath will probably take out the remaining nickel, although it will take too long. Something like Viakal might be better. An automotive metal polisher might do the job easier, but you will need to rub (a used sock will do), with the added benefit that you can preserve the nickel plating on the underside.
Current
Holiday rig
(8 items)
3Dfx
Intel Core i7 5820k
Asus X99-S
MSI Radeon R9 280X Gaming
Avexir DDR4-2400 C16 16GB(4x4) Platinum
Samsun SSD 850 EVO
Hitach HDT721010
Antec TP 550 New
EK Supremacy Clear CSQ
Alphacool XT45 360+240
EK-VGA Supreme HF
Swiftech MCP655-PWM
NZXT Switch 810
Dell S2340L
Intel Core i5 2500k
Gigabyte GA-Z68AP
Sapphire Radeon HD 6850
8GiB Samsung DDR3 green
Seagate 7200.11 1TB
Corsair 550W
Themalright ultra 120 eXtreme
CM Haf 912
Athlon XP 1900+
MSI KT3 Ultra ARU
3Dfx VooDoo 5 5500 AGP
512 MiB
Samsung 80GB
Optical Drive
(no name)
Enermax 350W
(no name)
Operating System
(no name)
(no name)
Keyboard
(no name)
Mouse
(no name)
Mouse
(no name)
cloppy007 is offline
post #8 of 15 (permalink) Old 02-03-2019, 02:49 PM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
It's probably damaged from the vinegar. The acid ate the nickel plating away... I don't think polish will fix this.
But to answer you question: I use automotive chrome polish (mothers) from my nickel blocks with a microfiber cloth. And to clean them, I use a toothbrush and toothpaste/polish
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #9 of 15 (permalink) Old 02-03-2019, 10:53 PM - Thread Starter
Rep: 0
Well i only dipped it in vinegar for 2 mins. The damage was done from the previous owner using only distilled water with no additives or coolant. In less than 1 year this happened. I have not installed the card yet i am gathering and prepping part in about 3 weeks i should have it running.
Thanks for your response i might try that i am considering opening up the block again and trying my hand with a polishing cream or even sand paper to smoothen out the plating damage. The problem is it is near the inner ridge of the o-ring aswell the o-ring should function properly but it still feels nervous being so close to that area. It is the ridge right before where the o-ring channel rides in.
Honestly this is what i was going to do the first time, but i chickend out and only left it in for 2 mins vs 2 days. I am not a metal expert so i was unsure of what it would do to the actual copper if left in backing soda+vinegar bath for 2 days. I still wonder if i should do this. But i don't want a can of worms either as i have not seen documentation with pictures of someone soaking their nickel or copper block in vinegar for 2 days straight. I really wonder, darn.
Another interesting thing i saw was a "SS" stamped on the block, does this mean it is stainless steel coating? Not sure, it is the waterforce wb auros extreme 1080ti.
post #10 of 15 (permalink) Old 02-03-2019, 11:37 PM
white owl's Avatar
Distilled water didn't do that lol
They used a silver coil I bet.
I'd clean it and use it.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
