Every Case Fan Has a Radiator...Bad? - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 02-07-2019, 07:52 AM - Thread Starter
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
Hi All -
I am in no way new to water cooling I just haven't upgraded my loop in a while. I am adding an additional 240mm of rad space but that now means that every fan on the case has a radiator on it.
My setup is in an Enthoo Pro M:
240mm Rad up front with stock phanteks fans (intake)
240mm rad up top with static pressure optimized fans (exhaust) (cant think of fan names right now)
120mm rad in back with the same static pressure fan (exhaust)
My question is 2 fold. 1) is it bad that I don't have a ton of air movement when my VRM's are still air cooled? 2) this is technically a negative pressure case, would it hurt to turn my 120mm into an intake having only a single 240mm exhaust?
I searched and did not find my specific problemo so thanks in advance!
OneFunGenesis is offline
post #2 of 15 (permalink) Old 02-07-2019, 12:46 PM
MrHarris's Avatar
Rep: 9 (Unique: 9)
I too wonder this same question as I am building my new rig....
MrHarris is offline
post #3 of 15 (permalink) Old 02-07-2019, 12:56 PM
Overclocker in training
ThrashZone's Avatar
Rep: 39 (Unique: 31)
Hi,
Doubt there is a positive/ negative pressure thing
There is only dust verses filtered
I don't subscribe to radiators being exhausted through.
Cases are open in the back for a reason
Top and front are filtered for a reason
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is online now
post #4 of 15 (permalink) Old 02-07-2019, 01:11 PM - Thread Starter
So that somewhat answers part 2 of my question. You would recommend 480mm of intake and 120mm of exhaust?
post #5 of 15 (permalink) Old 02-07-2019, 01:28 PM
ThrashZone's Avatar
Hi,
If the 120mm is on the back yeah exhaust or remove it completely it's not likely doing much anyway.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #6 of 15 (permalink) Old 02-07-2019, 02:41 PM - Thread Starter
Quote: Originally Posted by ThrashZone View Post
Hi,
Cool thanks. I’ll keep it as it’s still providing some cooling for the loop. I can easily turn the top fans to intake as I have to tear my loop apart annuway in mid March to SLI my graphics cards.
Question 1 still stands. That’ll be pumping even more heat into the case
post #7 of 15 (permalink) Old 02-07-2019, 03:22 PM
badtaylorx's Avatar
Rep: 45 (Unique: 42)
The biggest difference will be in gpu temps if you're still air cooling your card. They need a fresh supply of air. If it's in your loop, nevermind.... You should be fine. If you find the temps climbing too much, remove one of your side panels.
Modified Tt P5 chassis | RYZEN 2700X 4.4 all-core| AsRock X370 Taichi | Corsair 3200cl14 RAM | MSI GX 1070's SLI | 3x500gb SSD | EVGA P2 1200W psu | custom watercooling, 3xKoolance 360 rads, GT fans, AC cpu block, Koolance universal gpu blocks, 2xDDC swiftech pump, VRM block, 400ml res | Asus Essence One Muses ed. DAC/amp |
badtaylorx is offline
post #8 of 15 (permalink) Old 02-08-2019, 05:06 AM - Thread Starter
Thanks. Both GPUs are under water
post #9 of 15 (permalink) Old 02-08-2019, 05:22 AM
ThrashZone's Avatar
Hi,
It's fictional that rad heat is greater than mother board/ ram/... produce
With gpu's on water that is also a plus
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #10 of 15 (permalink) Old 02-08-2019, 05:46 AM - Thread Starter
Thanks. I will make sure to keep an eye on my temps over the next few months.
