Swiftech D5 Vario pump with much vibration. - Overclock.net - An Overclocking Community
post #1 of 25 (permalink) Old 02-07-2019, 12:20 PM - Thread Starter
Not New to Overclock.net
iSpark's Avatar
Rep: 9 (Unique: 9)
Hi
I have a Swiftech D5 Vario pump and at max speed setting it vibrates like crazy and the reverb throughout the case is really bad.
I have it set on 2 - 2.5 speed setting at the moment and it's barley noticible with the sound now, however you can still feel the vibration pretty strong.
I have it mounted in a Singularity Computers Protium D5 combo res., which is mounted to the Cooler Master 120mm fans which is mounted to the 240mmx30mm Alphacool radiator in the front of a Fractal Design Define R6
I used to have it in a Bitspower res and pump top combo and when it was in that I couldn't tell if it was on or not, that's how smooth and quite it was.
Not sure which way to go with testing out possible reasons for it, about all ways of testing mean tearing apart the loop. sigh... :-\
So I guess my first question is, does extremely bad vibrating from the D5 mean it's nearing it's EOL?
iSpark is offline
post #2 of 25 (permalink) Old 02-07-2019, 01:06 PM
Overclocker in training
ThrashZone's Avatar
Rep: 115 (Unique: 78)
Hi,
Think it might be a loose part in the rad or somewhere else ?
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #3 of 25 (permalink) Old 02-07-2019, 01:27 PM - Thread Starter
iSpark's Avatar
Rep: 9 (Unique: 9)
Quote: Originally Posted by ThrashZone View Post
Hi,
I've checked for anything loose, don't think it's any of that, this is definitely coming from the pump, you can feel it as you turn the speed dial up and down.
iSpark is offline
post #4 of 25 (permalink) Old 02-07-2019, 01:41 PM
ThrashZone's Avatar
Hi,
For what it's worth I wasn't impressed with a watercool vario
Wasn't worth rma shipping to return it.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 25 (permalink) Old 02-07-2019, 02:10 PM - Thread Starter
iSpark's Avatar
Rep: 9 (Unique: 9)
Actually, this pump has been great for the last 6 to 7 years I've had it running. Based on the way these things are made, I'm not sure what could be so out of balance.
When I took everything apart to move it to the Protium, I cleaned and checked pump and everything looked new inside.
I guess I'll tear loop apart and check it again when I get a new pump in, which won't be anytime soon.
I'll have to see what temps do in CS Go. CS:S temps are great, upper 20's to low 30's.
Haven't tried Go yet. haha
iSpark is offline
post #6 of 25 (permalink) Old 02-07-2019, 02:31 PM
cloppy007's Avatar
Rep: 77 (Unique: 53)
Please take a picture of the impeller and the ceramic ball. When was it made? I've got a circa 2005 IIRC D5 that vibrates quite a lot in the stock housing, and makes quite lot of electrical noise.
Current
Holiday rig
(8 items)
3Dfx
Intel Core i7 5820k
Asus X99-S
MSI Radeon R9 280X Gaming
Avexir DDR4-2400 C16 16GB(4x4) Platinum
Samsun SSD 850 EVO
Hitach HDT721010
Antec TP 550 New
EK Supremacy Clear CSQ
Alphacool XT45 360+240
EK-VGA Supreme HF
Swiftech MCP655-PWM
NZXT Switch 810
Dell S2340L
Intel Core i5 2500k
Gigabyte GA-Z68AP
Sapphire Radeon HD 6850
8GiB Samsung DDR3 green
Seagate 7200.11 1TB
Corsair 550W
Themalright ultra 120 eXtreme
CM Haf 912
Athlon XP 1900+
MSI KT3 Ultra ARU
3Dfx VooDoo 5 5500 AGP
512 MiB
Samsung 80GB
Optical Drive
(no name)
Enermax 350W
(no name)
Operating System
(no name)
(no name)
Keyboard
(no name)
Mouse
(no name)
Mouse
(no name)
cloppy007 is offline
post #7 of 25 (permalink) Old 02-07-2019, 02:51 PM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
You need to decouple the res from the fans with some mounts that have rubbers between them. Like the stock EK mount or heatkiller fan mount kit.
I don't think the singularty kit has them, but I might be wrong.
And at some RPM's the pumps is quiter than other, so try different settings. Setting 3 is more quiet than 2 on my D5 vario.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #8 of 25 (permalink) Old 02-07-2019, 03:30 PM - Thread Starter
iSpark's Avatar
Rep: 9 (Unique: 9)
Yep, plan on it. When I'm able to order a new D5. This time I plan on a PWM D5.
Yeah, Singularity doesn't include any kind of rubber isolation mounting.
I guess if I get a wild hair up my ..., I may dismantle it all and put everything back in the Bitspower and see what happens, it had two rubber pads to mount on.
iSpark is offline
post #9 of 25 (permalink) Old 02-07-2019, 03:48 PM
Rep: 3 (Unique: 3)
Ouch The rubbers are a big improvement since the resonances that are going through the case are a lot louder than the pump noise itself.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #10 of 25 (permalink) Old 02-08-2019, 05:58 AM
ThrashZone's Avatar
Hi,
All my D5's are pwm ek at that
Only thing I've noticed are really nice but a tad over priced but I buy them locally so it's returnable instead of rma shipping worth the extra costs
Pumps are the one thing that will fail eventually best to be able to replace that asap.
6-7 years you got your money out of it and then some
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
