Radiator Setup Question - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 02-08-2019, 10:43 AM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
Hey guys, I have an Evolv X and plan to put a 420 on front and a 280 on top, and both as intake. (The usual setup would be to setup the fans on the 420 as intake and exhaust on the 280 on top. But tests have been done here by user named boli that setting both as intake will decrease water temp by at least 5c.)
Now, I have an extra 140mm rad that I can put on the back, but I'm wondering if it's going to be of any help? Since it will act as the only exhaust, it will exhaust all the hot air from the intake rads making it maybe even counterproductive? Not to mention it will exhaust less air due the rad's added air resistance
What do you think? Should I use the extra rad or not?
jelome1989 is offline
post #2 of 15 (permalink) Old 02-08-2019, 10:49 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
subbing as i have a very similar setup
OneFunGenesis is offline
post #3 of 15 (permalink) Old 02-08-2019, 10:52 AM
I don't even like Linux
cmpxchg8b's Avatar
Rep: 96 (Unique: 73)
Likely not worth the extra tube routing complexity.
I had something (remotely) similar, Fractal Design Arc XL with 240 in the front, 360 up top, 120 in the back. First tried 140 in the back, that spot fits a 140 mm fan, but a 140 mm rad would not fit, so switched to a 120 mm rad and fan. It looked cluttered, and the extra rad got in the way, and airflow wasn't great either.
cmpxchg8b is offline
post #4 of 15 (permalink) Old 02-08-2019, 11:07 AM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
Have you tried removing the 120 rad? Any difference in the temps? Yeah I also factored in the routing complexity and thought of a workaround for it.
The setup would be:
Res > top rad (orientation should be reversed, ports should be near the front, not back) > front rad > cpu > back rad > gpu > res
Still may look cluttered but not as much.
EDIT: On second thought, no probably it might even look worse. But yeah anyway, would not want to leave this rad unused if possible
post #5 of 15 (permalink) Old 02-08-2019, 11:13 AM
mine looks fine. I have it going:
res> pump> GPU> GPU> CPU> Back 120 Rad> Top X-flow 240 Rad> Front Rad> Res
post #6 of 15 (permalink) Old 02-08-2019, 11:30 AM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
How about airflow orientation? What do you think should I use the back rad or not?
post #7 of 15 (permalink) Old 02-08-2019, 11:37 AM
cmpxchg8b's Avatar
I wasn't happy with the temps at all. It's a quad-GPU config, so it was way too low on rad space. Thus I did a full rebuild in a bigger case, and went straight for 4 x 480 mm rad setup.
So no, I haven't tested with just that one 120 mm rad removed...
post #8 of 15 (permalink) Old 02-08-2019, 12:09 PM
Both of these questions are what I am struggling with as well....
post #9 of 15 (permalink) Old 02-08-2019, 12:23 PM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Little 140mm won't hurt but won't do much of anything.
Rads as intake work bottom line top/ front nothing on the back air will find it's way out naturally 140mm rad might upset that as far as how fast air goes out
One or two fewer fan speeds to deal with too without the 140mm.
I have no fans on the rear just intakes on rads push/ pull.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #10 of 15 (permalink) Old 02-09-2019, 08:59 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
absolutely not. it will cause the water temp to increase.
now for some hard questions, how fast are the fans you have attached to the radiators?
are they setup as all intake?
do you have a exhaust fan or fans?
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
