Problem with EK Fittings (First time builder) - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 02-12-2019, 04:41 PM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
So I got all my parts together and assembled the build. Tubing's all that's left. However, I ran into some problems while experimenting with the fittings.
I tried test fitting some tubes, (I have 16mm hardline EK tubes and fittings) but the tube doesn't seem to go all the way in, and after screwing in the compression, I can still pull the tube out quite easily. I did a little research and indeed the tube has to go all the way in (after chamfering and sanding the tube), past the o-ring.
With that technique, I managed to push the tube all the way in, but it still requires an excessive amount of force which there's no way I'll be able to do in my case. Even after a few tries, I still can't get the hang of it.
Any suggestions?
Or should I just try other fittings like this one on Jayz video:
He managed to fit the tube fairly easily.
jelome1989 is offline
post #2 of 12 (permalink) Old 02-13-2019, 02:37 AM
broodro0ster's Avatar
Rep: 2 (Unique: 2)
Wet the tube and O rings before you slide it in. And yes, it takes some force to get it in. And pulling it out will always be easier than getting it in. Hardtube isn't as secured as softtube.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #3 of 12 (permalink) Old 02-13-2019, 05:31 AM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
Yeah, but if you'd look at Jay's video (forward to 7:45), there's like no effort sliding in the tube. I didn't know the EK fittings would be so much tighter. Makes the build a lot harder for me.
But ye, I somehow managed to fit a tube with a 90 degree bend (using fittings) from one port of the loop to another. However the other tube from the 90 degree bend is not perfectly straight, but only every so slightly. Do you think this is fine?
https://i.imgur.com/VzDikas.jpg
post #4 of 12 (permalink) Old 02-13-2019, 01:47 PM
GAN77's Avatar
Rep: 0
You do the assembly in the case and with the motherboard, about which I dream!
Do you have more photos?
GAN77 is offline
post #5 of 12 (permalink) Old 02-13-2019, 11:02 PM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
Also not sure how tight I should screw in my EK Velocity block. Should I screw it all the way in? Here's a pic:
https://i.imgur.com/rNToCDK.jpg
I do I will upload more later when I finish the build. Hopefully tomorrow
EDIT:
Do you plan on building the same build? What angles do you need to see? Here are a few.
https://i.imgur.com/pTSvJSa.jpg
https://i.imgur.com/5PyeHYQ.jpg
It's becoming a much bigger project than I hope it would be. The tube routing has become a mess I didn't know how I managed to arrive at cpu to radiator routing. Should be a simple 90 degree bend (which I've done but decided not to use). It's a pain to redo the routing since the EK fittings are just so hard to build with.
post #6 of 12 (permalink) Old 02-14-2019, 05:04 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
Screw it in until it is quite tight to the CPU. Give the block a wiggle/twist. If you can move it, tighten it a little more. The goal is that your cant move it with normal force of your hand.
OneFunGenesis is offline
post #7 of 12 (permalink) Old 02-14-2019, 05:39 AM
Rep: 2 (Unique: 2)
If the same as Supremacy EVO, then you need to keep screwing until the screw bottoms out.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #8 of 12 (permalink) Old 02-14-2019, 06:08 AM
Overclocker
OrganizedChaos's Avatar
Rep: 0
Although I used bitspower fittings, I relate - it took a lot of pressure to get the tube into the fittings the first time. But in the end that's good because it will be that much more secure. The o rings will loosen a bit over time, so if you're having a really hard time with it, maybe pop the o rings out of the fittings and just put them over the tube overnight or something and maybe it will make assembly a little easier.
[Build Log]
OrganizedChaos
(19 items)
Intel Core I7 8700k
Asus Maximus X Hero (Wi-Fi AC)
Nvidia Geforce GTX 1080 FTW
G.Skill Trident
Samsung EVO 850 SSD
Western Digital Black Edition
EVGA SuperNova 850 G2
EK Supremacy EVO
EK-FC1080 GTX FTW
EK Coolstream PE 360mm
EK-XRES 140 Revo D5 PWM + Multi-port Top added on
Phanteks Enthoo Luxe (Tempered Glass)
Operating System
Windows 10
ASUS ROG SWIFT PG279Q
Keyboard
Corsair K70 RGB
Mouse
Logitech G-400s
Mousepad
Razr Scarab - Battlefield 3 Edition
Audio
Logitech Z-5500
Audio
Hyper-X Cloud II
OrganizedChaos is offline
post #9 of 12 (permalink) Old 02-14-2019, 06:57 AM
pgdeaner's Avatar
Rep: 36 (Unique: 35)
I think wetting the o-rings is probably the best approach. Even with flexible tubing it can be difficult to get the tube over the fittings and I have had to resort to KY to get the tubes in place.
“Who you are is defined by what you’re willing to struggle for.”― Mark Manson
Nuka Cola
(0 items)
pgdeaner is offline
post #10 of 12 (permalink) Old 02-14-2019, 07:45 PM - Thread Starter
jelome1989's Avatar
Rep: 1 (Unique: 1)
Only two ports left for the build. Right now I just want to finish the build with no leaks. Don't care that much anymore about how it looks as taking it apart is a pain for a 1-2mm adjustment. Next time around I'll make sure I'll play around with different fittings and see which I'm comfortable with.
