Anyone else experience coolant color change, with white coolant? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 02-22-2019, 08:56 AM - Thread Starter
Solarity's Avatar
Rep: 14 (Unique: 8)
I am curious if anyone else has used white coolant and noticed a slightly different hue of white. I noticed a slight tint of blue, compared to the left over coolant. It was only in the PC for ~6-7 months and I didn't notice it till I drained it. I do admit the first time I used the loop I really didn't clean anything out. Before I used this fluid there was a little bit of gunk that collected in the CPU block.
I got a new case so I decided to redo everything. I did flush and shake method this time, followed by running distilled water through for a few days, before moving back to white fluid. I will see if this batch doesn't get tinted by copper oxide. In theory I don't think there is any way the color change is the fluids fault. Maybe my lack of cleaning, before first using the loop and the little gunk in the cpu that I didn't clean out till now. Will be interesting to see what happens in another 6 months.
Solarity is offline
post #2 of 11 (permalink) Old 02-22-2019, 09:56 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
been using white fluid for almost 2 years now. No problems. I have changed it twice and am getting ready to do it again. All of my parts were cleaned however and I run Blitz part 2 before every fluid change. I even moved and drained my PC, kept the fluid and then put it back in and have not had any issues!
OneFunGenesis is offline
post #3 of 11 (permalink) Old 02-22-2019, 10:01 AM
Overclocker in training
ThrashZone's Avatar
Rep: 92 (Unique: 67)
Hi,
Depends on which coolant premix or constraint
Clogging cpu blocks sounds like ek premix to me since it happened to me too but wasn't a little gunk it was a lot of gunk.
Mayhams/... haven't ready anything about gunk or break down unless it was the exotic stuff which had a short "what's the point" life time anyway.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #4 of 11 (permalink) Old 02-22-2019, 10:16 AM - Thread Starter
Solarity's Avatar
Rep: 14 (Unique: 8)
Wow that is intense, never used Blitz, I might have to give that a shot if I don't see any changes in a few months.
Quote: Originally Posted by ThrashZone View Post
Hi,
The gunk was already in the block, before I added the fluid. It wasn't clogged, though saw a little buildup. Wasn't comfortable taking the block apart at that time. I did it this time and and cleaned it with a toothbrush.
Solarity is offline
post #5 of 11 (permalink) Old 02-22-2019, 10:25 AM
ThrashZone's Avatar
Hi,
This is the only white fluid thread as of late that turned weirdly clear in a short time
https://www.overclock.net/forum/61-w...ned-clear.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 11 (permalink) Old 02-22-2019, 12:50 PM - Thread Starter
Solarity's Avatar
Rep: 14 (Unique: 8)
Hi,
Oh nothing near that bad. I put it in white, it came out white, just had a small blue hue to it. I don't know if I would have noticed if I didn't have some original left over. It washed out easily. I think my lack of prep and cleaning out the CPU block contributed to the slight tinting. The fluid was not premix.
Solarity is offline
post #7 of 11 (permalink) Old 02-22-2019, 12:52 PM
News Fiend
ryan92084's Avatar
I don't know what brand you were using but Mayhems had this to say about a similar sounding, but UV focused, situation https://www.overclock.net/forum/61-w...l#post27851598
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #8 of 11 (permalink) Old 02-25-2019, 12:10 PM
Check your pH
Only time I had an issue with Mayhem fluid turning a weird color the pH in my system was off. Red fluid turned purple.
If you have not cleaned your loop with vinegar or anything like that it should be ok. Not sure what would cause a bluish hue and the gunk but it sure sounds like copper sulfate. Are your blocks or rads copper?
Nuka Cola
(0 items)
Eusbwoa18 is offline
post #9 of 11 (permalink) Old 02-26-2019, 12:14 AM
MrHarris's Avatar
Rep: 9 (Unique: 9)
Yes mine is a slight blue hue now not sure why
MrHarris is offline
post #10 of 11 (permalink) Old 02-26-2019, 06:17 AM
Mayhem's Avatar
Rep: 278 (Unique: 197)
Copper is the fault here. White to the slight tint of blue/green hue is copper not being cleaned and is filtering into the fluid.
Mayhem is offline
