Did I screw up my ek block ? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 02-25-2019, 09:35 PM - Thread Starter
DOOOLY's Avatar
Rep: 38 (Unique: 37)
Hi OCN. Can any one tell me why my Ek GPU block looks like this. Its black around where the gasket lays.
CPU : i7 8700K
GPU : GTX 1080TI
MB : MSI M5 GAMING
PSU: EVGA G2 1000
Cooling Custom :EK-FC GeForce GTX FE/EK-Supremacy EVO
DOOOLY is offline
post #2 of 6 (permalink) Old 02-25-2019, 11:05 PM
white owl's Avatar
Rep: 136 (Unique: 103)
I'm hardly a water cooler but I've worked with copper all my life.
Looks exactly like the various stages of slightly acidic water + oxygen over time. Like if you left raw copper outside without touching it. Looks perfectly normal to me and you should easily be able to remove most of it with something slightly abrasive (textured sponge thing) or viperous scrubbing with cloth. If it is just oxidized (the way that copper gets dark when it remains dry) you'll need to lightly scrub with something a bit more aggressive like scotchbrite. If you tear a piece off you can push it in the gap there and use a pencil or something to push it around. Or use the corner. No matter what it is, one of those the answer (if you want to remove it).
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #3 of 6 (permalink) Old 02-25-2019, 11:24 PM
Kiros's Avatar
Rep: 53 (Unique: 43)
Toothpaste and a Toothbrush
Skip to 5:05 for the action
Anatolii
(14 items)
Intel i7 [email protected]
Gigabyte X99 Designare EX
EVGA 1080 Ti FE
GSkill TridentZ 64GB DDR4 3200mhz
Samsung 960 EVO 500gb
Samsung 960 Pro 512GB
Samsung 850 EVO 1TB
Micron 1100 2TB SSD
Seasonic SilentSnow 1050w
EK/Bitpower Custom Loop
Caselabs White SMA8
Operating System
Windows 10 Pro
Samsung 55KS8500 4K
Audio
Logitech Z-5500
Kiros is offline
post #4 of 6 (permalink) Old 02-26-2019, 05:52 AM
News Fiend
ryan92084's Avatar
Copper oxidizes, you can clean it as suggested or embrace the wabi-sabi. It isn't going to hurt anything.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #5 of 6 (permalink) Old 03-01-2019, 01:54 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Ketchup and a toothbrush is also very good for copper (but don't use it on nickel)
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #6 of 6 (permalink) Old 03-01-2019, 04:37 AM
white owl's Avatar
I wouldn't believe it if I hadn't done it myself. Ketchup really is the best product you can use for cleaning something down to bare copper, even better than products designed to clean copper. Fast too.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
