Help me find a better loop - Page 2 - Overclock.net - An Overclocking Community
post #11 of 39 (permalink) Old 02-26-2019, 04:01 PM - Thread Starter
Yomny's Avatar
Rep: 20 (Unique: 16)
Quote: Originally Posted by ThrashZone View Post
Hi,
EK rads wise PE or EX only
Be aware ek rads do have an additional collar with o-ring that other rads do not have
Pretty much another possible leak besides the actual hose fitting.
But yeah thought it was lite weight rads but cases are what they are
I added a second floor to fit a larger radiator inside maybe that might be in order for you
Check out my rig images it shows the boxes on top.
Copy that, thanks.
Corsair
(9 items)
Core i9 9900k 4.9ghz @1.3
Asrock Z390 Extreme4
RTX 2080 Ti EVGA HC Waterblock
G.SKILL TridentZ Series F4-3000C15D-16GTZ
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
HWL 280-120mm CPU/GPU
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #12 of 39 (permalink) Old 02-27-2019, 05:45 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 372 (Unique: 258)
Quote: Originally Posted by Yomny View Post
I do recall HWL rads being very well known, now it does seem they have a few to choose from, any particular series?
HWL arguably makes the best rads on the market. Having used just about everything out there right now, HWL is by far my first choice. But, be aware that they run slightly wide and you need to be sure they will fit where you are intending on using them.
As far as series, it depends on your goal. The GTS is a slim 30mm rad designed for stellar low noise performance, and is comparable in performance to top name 45mm rads out there. The SR2 also has top notch low noise performance, but will scale more than the GTS, but is 60mm thick. The GTX and GTR are their all out performers, but only at high fan speeds - in other words, if you aren't looking to have your rig sound like a vacuum cleaner, the GTS and SR2 are better choices as they offer better performance at low/mid fan speeds.
Avoid the L series entirely. They are an oem piece that are very restrictive and do not perform on par with the Nemesis or Black Ice lines.
ciarlatano is offline
post #13 of 39 (permalink) Old 02-27-2019, 06:40 AM
broodro0ster's Avatar
Rep: 2 (Unique: 2)
That's another thing i have to think about, maybe a bigger case with more airflow will be way cheaper and have a similar improvement on temps. My case wont really allow anything bigger. Maybe id focus on the 280 for CPU alone and leave the GPU alone, is not bad at the moment but i know once i introduce a fron rad the temps will increase.
I wouldn't go for anything less than dual 360's for a 9900k and 2080TI. I have 2x 360's and a 8700k and 1080TI. I'm reaching a delta T of 10°C with a full blown OC under gaming loads. And 8.5°C with my GPU undervolted. The 9900k is about 70-150W during gaming loads, but the RTX2080TI draws 300-380W depending on the max power limit of you model.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #14 of 39 (permalink) Old 02-27-2019, 09:01 AM - Thread Starter
Yomny's Avatar
Yep, just did a little quick loop configuration with EK for the setup and its suggested at minimum two 280's, their 45mm ones which hold a lot more liquid than a single slim 360, so its clear lol. It calculated 600w for the system.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #15 of 39 (permalink) Old 02-27-2019, 09:41 AM
Overclocker in training
ThrashZone's Avatar
Rep: 39 (Unique: 31)
Hi,
45mm is the CE series mediocre at best
I have a couple and 2-gtx-240's are about the same as 2-CE280's
SR2 is really where you want to be you can get discount using OCN55 discount code
Presidents days is soon they usually have holiday coupons matter of fact most items are better bought through them instead of EK directly
http://www.performance-pcs.com/hardw...tor-280mm.html
https://www.overclock.net/forum/61-w...upport-47.html
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #16 of 39 (permalink) Old 02-27-2019, 12:17 PM
drewafx's Avatar
Rep: 4 (Unique: 4)
X-Flow rad saves the hassle of tilting pc around when filling/draining...just a really long tube in one direction.
drewafx is offline
post #17 of 39 (permalink) Old 02-28-2019, 08:11 AM - Thread Starter
Yomny's Avatar
Hi,
So the ratings in the radiator specs are usually bs or not? It seems EK radiators dont have the best rep. I was configuring something on PCS website using the Nemesis LS series so a LS360 would suffice for 1000w and LS240(rated at 650w) for the GPU, at least is what their spec sheets say. Sound about right?
This all considering a new case of course. How does one go about calculating whether you need one two or three pumps? I'm going now for the d5 pwm xres140 from ek rated at 1500 l/ph and 3.2m of head pressure.
My goes is the same cool GPU and CPU.
Thanks.
Lol, i laugh because its like you read my mind, already had an LS360 and LS240 in the cart solely for configuration purposes not to actually buy. I do much rather have a quiet PC, i understand with OCing there will be noise but the lower end of the spectrum is what i want. GTS it is, so would 2x240s work? They're rated at 750W each, dont want to bump to 280's as i already have decent 120mm fans.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #18 of 39 (permalink) Old 02-28-2019, 08:28 AM
Shawnb99's Avatar
Rep: 5 (Unique: 4)
Thanks.
You shouldn’t need 3 pumps. 2 is the most you’ll need. More head is better the more restrictive your loop is.
Most specs are very generous and not totally accurate. Take them with a grain of salt. Go by user reviews and people who compare and test them rather then what the website says.
Shawnb99 is online now
post #19 of 39 (permalink) Old 02-28-2019, 08:42 AM
News Fiend
ryan92084's Avatar
You can make 2 240s work if you throw enough fan power at them for sure, it just depends on what your temperature and silence goals are. For For a standard 2 blocks and 2 rads loop double pumps are already just for redundancy.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #20 of 39 (permalink) Old 02-28-2019, 08:51 AM - Thread Starter
Yomny's Avatar
So 2x240s will need what a push/pull config or we're talking good SP fans? I'm really sticking to one pump. Trying to keep it as simple and quiet, while not aiming for a quiet loop. I just didn't see the different in wattage capacity from 280 to 240's in the line of rad im choosing. As mentioned taking specs lightly but for the sake of reference, the 240's cool 650W and the 280 would work for 700w. I'm not speaking of 360's as they were out of stock for now(GTS line).
What exactly will work? I understand we're cooling some of the hottest pieces of hardware but i really dont think i need 60mm thick cores(best of the best names out there) to cool this CPU or GPUs, there're AIO's cooling these already(not great but keeping sub 90c). Just trying to weigh my options here as it seems the deeper you get the deeper its implied you need to get lol. I knowits all based on goals as it was mentioned. So 70's for temp while pushing the hardware hard would be my goal, right off the top of my head. GPU isn't overclocked so only cpu.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
