Help me find a better loop - Page 3 - Overclock.net - An Overclocking Community
post #21 of 39 (permalink) Old 02-28-2019, 11:03 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 410 (Unique: 274)
Quote: Originally Posted by Yomny View Post
So 2x240s will need what a push/pull config or we're talking good SP fans? I'm really sticking to one pump. Trying to keep it as simple and quiet, while not aiming for a quiet loop. I just didn't see the different in wattage capacity from 280 to 240's in the line of rad im choosing. As mentioned taking specs lightly but for the sake of reference, the 240's cool 650W and the 280 would work for 700w. I'm not speaking of 360's as they were out of stock for now(GTS line).
What exactly will work? I understand we're cooling some of the hottest pieces of hardware but i really dont think i need 60mm thick cores(best of the best names out there) to cool this CPU or GPUs, there're AIO's cooling these already(not great but keeping sub 90c). Just trying to weigh my options here as it seems the deeper you get the deeper its implied you need to get lol. I knowits all based on goals as it was mentioned. So 70's for temp while pushing the hardware hard would be my goal, right off the top of my head. GPU isn't overclocked so only cpu.
The GTS line shows absolutely no benefit from push/pull, only an increase in noise - https://www.xtremerigs.net/2015/02/1...-round-2015/5/
If you can fit the 280mm and get appropriate fans, you will see an increase in performance over the 240mm as you will have a 36% increase in surface area.
ciarlatano is online now
post #22 of 39 (permalink) Old 02-28-2019, 11:05 AM
Overclocker in training
ThrashZone's Avatar
Rep: 92 (Unique: 67)
Hi,
Just get a new case 2-360mm rads boom.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #23 of 39 (permalink) Old 02-28-2019, 11:33 AM - Thread Starter
Yomny's Avatar
Rep: 20 (Unique: 16)
Copy, damn and i was happy with the little cooler master fans, they looked the part but i'll look for 140's.
Quote: Originally Posted by ThrashZone View Post
Hi,
Copy that sir, thank you.
Corsair
(9 items)
Core i9 9900k 4.9ghz @1.3
Asrock Z390 Extreme4
RTX 2080 Ti EVGA HC Waterblock
G.SKILL TridentZ Series F4-3000C15D-16GTZ
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
HWL 280-120mm CPU/GPU
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #24 of 39 (permalink) Old 02-28-2019, 12:12 PM
ciarlatano's Avatar
Hi,
That really is the preferable thing to do under the circumstances if you can fit it in your budget.
post #25 of 39 (permalink) Old 02-28-2019, 12:26 PM - Thread Starter
Yomny's Avatar
So the 360's are better than same series/line 280's, for quieter performance? Given there isn't much of a drop in heat reducing capacity.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #26 of 39 (permalink) Old 02-28-2019, 02:21 PM
ciarlatano's Avatar
There will be very little performance difference. The pair of 280mm will likely be a little quieter, as you will be using four rather than six fans. But, you had stated that you have 120mm fans on hand, so the ~$60-80 you would be spending on 140mm fans could be used toward a case more suited for your needs.
post #27 of 39 (permalink) Old 02-28-2019, 03:50 PM - Thread Starter
Yomny's Avatar
I had my eye set on some 120 fans but not really a big deal to change. They just looked good on paper with low noise, high SP and decent price. They're cooler master blade master 120. i'm trying to get a good set of 140mm high static pressure fans with decent under 30db ratings but seems hard unless paying more than $25 per fan.
Im sure my search criteria is bit messed up. I seems to think that only 3.0 or above for static pressure is good but these usually mean high rpms which is also a synonym for high noise. Noctua's are great but the one's im looking at are running $30 a fan lol.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #28 of 39 (permalink) Old 02-28-2019, 04:22 PM
Hardware Princess
Hydroplane's Avatar
Rep: 31 (Unique: 26)
I would go with the HWLabs radiators.
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #29 of 39 (permalink) Old 02-28-2019, 05:10 PM
ciarlatano's Avatar
Blademasters are horrible sounding fans, and don't perform anywhere near what the specs would indicate.
post #30 of 39 (permalink) Old 02-28-2019, 07:59 PM - Thread Starter
Yomny's Avatar
Yeah that's what I've settled on.. appreciate the input, been told the GTS or GTX or the more enpensive r2 or s2.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
