Help me find a better loop - Page 4 - Overclock.net - An Overclocking Community
post #31 of 39 (permalink) Old 02-28-2019, 08:01 PM - Thread Starter
Yomny's Avatar
Rep: 20 (Unique: 16)
Quote: Originally Posted by ciarlatano View Post
Blademasters are horrible sounding fans, and don't perform anywhere near what the specs would indicate.
I was skeptical for the price, on paper they look amazing but its hard to believe all that for just 10 bucks. Currently checking out some arctics, reviews put them as the second best as far as static pressure went, second the industrial noctuas.
Corsair
(9 items)
Core i9 9900k 4.9ghz @1.3
Asrock Z390 Extreme4
RTX 2080 Ti EVGA HC Waterblock
G.SKILL TridentZ Series F4-3000C15D-16GTZ
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
HWL 280-120mm CPU/GPU
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #32 of 39 (permalink) Old 02-28-2019, 08:29 PM
Packet Pusher
Renegade5399's Avatar
Rep: 230 (Unique: 145)
Delta AFB1212SHE fans hooked to a Corsair Commander Pro via these all day. You can also use the breakout whips connected to your PWM motherboard headers if you like to save $70. At half speed, they are quiet and still produce 7.2mm H2O static pressure.
I know these are not typical suggestions, but I look for function and value. With all the crypto mines parting out, those fans can be had for cheap. Another plus is that they are RGB free and are rated for 70000 Hrs @ 40°C.
With that kind of fan power, you can set a panic point in your temp curve to run them up to 100% knowing that 151CFM at 14.5mm H2O will take care of most heat issues.
My Sauce Is Much 13373|2 Than Yours
What's in your hardware wallet?
[Gigabyte Aorus 1080 Ti Owner's Club]
Project Blackout
(24 items)
i9 7900X Delidded
ASUS TUF X299 Mark 1
EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING
G.SKILL Trident Z Royal Series 16GB - Samsung B-die DDR4 4000
G.SKILL TridentZ RGB Series 16GB - Samsung B-die DDR4 4000
4x 1TB Western Digital Black
2x 480GB Kingston HyperX Savage SSD
2x ADATA Ultimate SU800 1TB 3D NAND
Intel 660p Series M.2 2280 1TB PCI-Express 3.0 x4
INTEL® RAID ADAPTER RSP3DD080F
2x 2TB Western Digital Green
CORSAIR HX Series HX1000
Custom Water Cooling Setup
Bitspower MonoBlock ASX299TUF RGB-Nickel
Thermaltake Core X71 Tempered Glass Edition Black
Operating System
Winders 10 Pro 64bit
Pixio PX276h 27"
Acer GN276HL 27"
HP EliteDisplay E222 22"
Keyboard
Corsair K95 RGB PLATINUM - Cherry MX Speed - Gunmetal
Mouse
HP Omen Reactor
Mousepad
Corsair Gaming MM800 RGB Polaris
Audio
Sades SA926 Gaming Headset
Renegade5399 is offline
post #33 of 39 (permalink) Old 03-01-2019, 01:58 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by Yomny View Post
Yeah that's what I've settled on.. appreciate the input, been told the GTS or GTX or the more enpensive r2 or s2.
Don't get the GTR. It only works well at very high speeds (2000-3000), but is pretty bad a lower speeds.
The GTS is the best slim radiator and the GTX is one the best thick radiators. It scales very nice with fan speed. The SR2 is optimized for low fan speeds, but isn't any better than the GTS. Only get it if you want a thick rad for looks and low fan speeds or need the multi ports. Otherwise GTS or GTX.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #34 of 39 (permalink) Old 03-01-2019, 06:00 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 406 (Unique: 273)
The Arctic P series are getting good feedback from some reputable users. I haven't tested them first hand yet, though, so I can't really comment more than that.
I think you are a little (a lot, really) confused about static pressure and what the ratings actually mean to you in real world usage. The Noctua iPPC fans have high rated static pressure for no other reason than that they are high rpm fans - there is absolutely no other reason, and the same goes for the Blademasters. But....are you really intending on running your fans at 3000 rpm? Of course not. Well, maybe you would if the computer was located on a different floor of your home, or you were deaf. What you need to be looking at is the PQ, or more simply put - you need to look at what fans develop the most static pressure at tolerable noise levels with a smooth sound signature at the speed you intend on using them.
The chart below is the kind of information that matters, as well as the info in a review like this, which clearly shows that there is absolutely nothing special about the NF-F12 - https://www.techpowerup.com/reviews/...700_PWM/5.html
So, I am not sure what "reviews" you are looking at, but they are certainly not credible or informative.
ciarlatano is online now
post #35 of 39 (permalink) Old 03-01-2019, 01:08 PM - Thread Starter
Yomny's Avatar
Good stuff, really appreciate the time. I'd have to limit searches to reputable sites with actual data instead of just words.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #36 of 39 (permalink) Old 03-01-2019, 01:15 PM - Thread Starter
Yomny's Avatar
Thanks for that, all input and experiences are greatly appreciated.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #37 of 39 (permalink) Old 03-01-2019, 01:15 PM
Overclocker in training
ThrashZone's Avatar
Rep: 78 (Unique: 59)
Hi,
I have four vardar fans not worth rma'ing
They are pretty much useless full blast or nothing.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #38 of 39 (permalink) Old 03-01-2019, 01:21 PM - Thread Starter
Yomny's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Well dang lol.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #39 of 39 (permalink) Old 03-01-2019, 01:26 PM
ThrashZone's Avatar
Hi,
RMA to Germany sucks cost more than they are worth
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
