Help me find a better loop - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 02-26-2019, 09:51 AM - Thread Starter
Yomny's Avatar
Rep: 20 (Unique: 16)
I've only dealt with EK the past two custom loops, they make it easy to put things together and they work but i know at times they may not be the best or cheapest. For those who know their way around other sites/companies can you put together something like what i have. Do notice that the pump/reservoir style, fan size and radiators are the max sizes i could use for my build. I'm trying to cool CPU+GPU using a front 280(note im no selecting the slim 280) and a top 120 for the gpu. So it'll go Pump>280>CPU>120>GPU back to pump.
I picked the pump as it shows to have good head pressure, i know d5 is supposed to be quieter and what not but I've used this one before and the sound is ok. See the photos for parts and quantities, total shipped shoud be <$740.
Appreciate your help! Have fun.
Name:	custom loop 2.PNG
Corsair
(9 items)
Core i9 9900k 4.9ghz @1.3
Asrock Z390 Extreme4
RTX 2080 Ti EVGA HC Waterblock
G.SKILL TridentZ Series F4-3000C15D-16GTZ
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
HWL 280-120mm CPU/GPU
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #2 of 39 (permalink) Old 02-26-2019, 09:58 AM
Shawnb99's Avatar
Rep: 8 (Unique: 6)
Heatkiller blocks for both GPU and CPU.
Get a HWL rad instead, much better at lower RPM’s.
Also go for Mayhems fluid. Pick a colour of go clear X1. Look at ordering a blitz kit as well, any rad you get needs a decent cleaning
Shawnb99 is offline
post #3 of 39 (permalink) Old 02-26-2019, 10:39 AM
Overclocker in training
ThrashZone's Avatar
Rep: 42 (Unique: 34)
Hi,
Indeed CE and SE series rads aren't very good
The pwm pump also isn't good
EK does make okay D5 pwm pump reservoir combos just not the one you picked
Matter of fact if you have a local Micro Center around get it from them it will be the one item rma to Germany will be a bummer wait
But this is what I have should be fine for rads/ gpu/ cpu
https://www.ekwb.com/shop/ek-xres-14...m-incl-sl-pump
Fittings and soft hose you'll want to use 10-15mm not 10-13mm
You'll be a lot better off with some noctua or be quiet fans either have 2000 rpm fans much quieter and more reliable like i said rma to Germany isn't all that great
Get some from amazon/....
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #4 of 39 (permalink) Old 02-26-2019, 11:33 AM - Thread Starter
Yomny's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
So what exactly makes the D5 better, is it newer, quieter? From what i see L/h abd pressure seems to be the same.
What about the smaller cousin, the EK-XRES100, just the height of the 140 is not helping me. As far as hose, why is wide OD better?
Appreciate the information and knowledge. I've read through several guides and basically i thought the G1/4 has similar size to the 10/13 so going bigger didn't help much, but im sure thats not the end of it.
Thanks for the input, i did like the heatkiller blocks but was struggling to find a place that had most things to try and order from one place.
Copy of the blitz, i had asked EK about the cleaning and they agreed distilled was fine lol.
I do recall HWL rads being very well known, now it does seem they have a few to choose from, any particular series?
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #5 of 39 (permalink) Old 02-26-2019, 01:10 PM
broodro0ster's Avatar
Rep: 2 (Unique: 2)
Don't expect great temps with a 280+120 for a 9900k and 2080ti. Those draw about 400-600W together.
It will cool sufficient, but not great.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #6 of 39 (permalink) Old 02-26-2019, 01:12 PM
ThrashZone's Avatar
Hi,
Yeah 100 is pretty much the same shorter reservoir tube
It's best to get it now rather than messing with and wasting money on 10-13mm.
The 15mm OD is just better more durable and can get better turns
Thinner tubing just insures you'll need some (probably going to leak rotary fittings) to help make turns because 10-13mm will kink a lot easier than 10-15mm
Cost is about the same or not so much it would make a large difference.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #7 of 39 (permalink) Old 02-26-2019, 01:23 PM - Thread Starter
Yomny's Avatar
That's another thing i have to think about, maybe a bigger case with more airflow will be way cheaper and have a similar improvement on temps. My case wont really allow anything bigger. Maybe id focus on the 280 for CPU alone and leave the GPU alone, is not bad at the moment but i know once i introduce a fron rad the temps will increase.
Hi,
As someone else mentioned, i may by pushing it with that loop and the massive heat producers the 2080ti and 9900k are. I may just end up with a CPU loop and increase case ventilation to help the open air cooler on the RTX.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #8 of 39 (permalink) Old 02-26-2019, 01:59 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 942 (Unique: 579)
I've kind of fallen in love with my Meshfy S2, but it's not really cheap. Lets you run a top 420 + front 360 + bottom 280 + rear 120 if for some reason you want to populate all the radiator positions
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill 16GB DDR4 4133
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #9 of 39 (permalink) Old 02-26-2019, 02:59 PM - Thread Starter
Yomny's Avatar
Coincidentally i just saw a review yesterday from J's2cent on that particular case and was just looking at bigger cases. It seems I need to invest on a case first. My case with my current CPU heatsink is cramped. VRM and mobo heatsinks are all very close and the 2080ti is literally sniffing up the front fans rear end. That was totally my mistake, i liked the case and overlooked that small factor.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #10 of 39 (permalink) Old 02-26-2019, 03:36 PM
ThrashZone's Avatar
Hi,
EK rads wise PE or EX only
Be aware ek rads do have an additional collar with o-ring that other rads do not have
Pretty much another possible leak besides the actual hose fitting.
But yeah thought it was lite weight rads but cases are what they are
I added a second floor to fit a larger radiator inside maybe that might be in order for you
Check out my rig images it shows the boxes on top.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
