New to Forum and water cooling--looking for some quick advice! - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 03-01-2019, 08:09 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
Quote: Originally Posted by cms062407 View Post
yeah, I did plan to have one--but my microcenter didnt' have the proper fittings, so I said screw it and just finished the tubing because I was excited to see if there was a difference in my 360 AIO....there is no difference in temps, but I guess people don't necessarily do custom loops on CPUs nowadays for performance gains...I guess its about looks and system quietness.
Also this pump/res combo only has two ports on it----one inlet and one outlet, so I couldn't just use an extra port for a dedicated drain loop unless I buy the EKWB Multiport top--which is what I am going to do whenever I decide to drain the system. I have no idea how to setup the multiport top--but I guess I'll figure that out when the time comes.
No need to use and extra port with the proper fittings. But I am sure you know that. As to the multi port top, just use the ports your need and plug the ones you dont. Multiport tops are very nice. I have a 3 port top. 1 port for the loop return, 1 port for filling and 1 port for air bleeding.
so, you are saying to just remove ONE of the tubes on the pump/res combo (either the inlet or outlet) and blow through the other end of it? I have seen jayztwocents do it before, so it must be okay, right? lol
It is fine. Any coolant you use should have growth inhibitors in them to kill any bacteria that might get in the loop. I blow into mine all the time as I get fluid stuck between my CPU and Radiator for some reason.
OneFunGenesis is offline
post #12 of 16 (permalink) Old 03-01-2019, 08:25 AM
Overclocker in training
ThrashZone's Avatar
Rep: 42 (Unique: 34)
Hi,
Yes
It's also the best way to see if something like cpu water block might be clogged by blowing through the outlet hose first
If it's harder than expected the water block picked up some fluid crap and needs to be cleaned.
I added a inline filter onto the outlet of the pump to pick up anything that gets through the system "hopefully" before the cpu.. picks it up and gets clogged.
Koolance has them for cheaper and where i got them
https://www.amazon.com/Koolance-INS-.../dp/B008G3OTLO
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #13 of 16 (permalink) Old 03-01-2019, 10:14 AM
News Fiend
ryan92084's Avatar
On the subject of using air to help drain a rad. On a whim I used some junky foot pump (see spoiler) from my wife's yoga ball which helped a fair bit. Pretty sure the hose would explode long before it built enough pressure to damage a rad and it sure beat tilting the case all around for 20 minutes.
Spoiler!
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #14 of 16 (permalink) Old 03-01-2019, 10:55 AM
ThrashZone's Avatar
Hi,
Shouldn't need a lot of air pressure to begin with if one does you have a clogged block
Reverse blow can clear it but throws the crap into maybe a rads where it might return later and reclog the block again.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #15 of 16 (permalink) Old 03-01-2019, 11:34 AM
News Fiend
ryan92084's Avatar
For sure, you still end up with some residual in your pump, vertical mounted gpu block, bottom of the ports up rad, etc because there just isn't enough there for the air to not just bubble past but the majority is out.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #16 of 16 (permalink) Old 03-01-2019, 11:38 AM
ThrashZone's Avatar
Hi,
Yeah vertical gpu mostly for looks to see that 130.us+- water block bling otherwise hell to drain
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
