Are Silent Wings 3 an upgrade over Phanteks F120MP? - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 02-28-2019, 03:54 PM - Thread Starter
RyuBlade94's Avatar
Rep: 0
Hi everyone. So, i want to replace my actual fans (120mm F120MP x6) in my hardline watercooled pc.
The phanteks F120MP served me real good, but i just want to try out something new and maybe give a slighly different look to my pc. So, i am really looking into the silent wings 3 PWM fans. I am honestly wondering how they would perform, when compared to the fans i am currently running, considering both, noise and performance.
Also i would like to know, for anyone who owns them both, if i should be getting the standard PWM fans or grab the high speed ones instead, expecially considering that 5 of those fans will end up being mounted on a Nemesis GTS radiator (240 and 360mm).
Can you guys please help me out with this? Thanks in advance!
RyuBlade94 is offline
post #2 of 2 (permalink) Old 02-28-2019, 06:17 PM
⤷ αC
AlphaC's Avatar
Rep: 909 (Unique: 591)
Similarly, slightly better but probably not worth it (especially due to cost) unless you get high speed ones.
I would buy the high speed ones to have a rational "upgrade" of maximum speed if you intend to have that increase in speed.
http://thermalbench.com/2016/10/21/b...h-speed-fan/3/
140mm vs other radiator/heatsink fans https://www.hardwareluxx.de/index.ph...t.html?start=4
Your current fan isn't bad.
PH-F120MP (1600RPM = 68.8CFM , 1000RPM = 44.1CFM): http://www.coolingtechnique.com/rece...s.html?start=5
They're still among the best between 1000-1300RPM per one of the latest reviews: https://www.techpowerup.com/reviews/...x25_PWM/5.html
1000RPM: 23.1CFM with 29dBA (SW3 = 24.4CFM, 31.7dBA)
1250RPM: 27.1CFM with 31.8dBA (SW3 = 28.6CFM , 35dBA)
1500RPM : 31.9CFM with 37dBA (SW3 = ~34CFM , 38-39dBA)
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
