Running GPU and CPU in parallel in the loop? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 02-28-2019, 07:55 PM - Thread Starter
tintreach's Avatar
Rep: 6 (Unique: 5)
I keep seeing a lot of builds going this route. It looks clean but I have yet to see anyone to report back anything on the cooling impact of halving the flow rate to the CPU. Has anyone done this before and what input do you have on parallel vs series to blocks?
tintreach is offline
post #2 of 9 (permalink) Old 02-28-2019, 09:17 PM
I don't even like Linux
cmpxchg8b's Avatar
Rep: 96 (Unique: 73)
Haven't done this personally, but there's plenty of builds like that here on OCN, and on the Internet in general, and it works just fine, assuming all else is done right, and the pump creates enough flow - which it will unless you add tons of restriction elsewhere in the loop.
If this makes for cleaner tubing routing in your build, go for it.
cmpxchg8b is offline
post #3 of 9 (permalink) Old 02-28-2019, 09:47 PM
Rep: 0
it's been a while since iv'e seen this video, although i'm pretty sure jay covers that orientation in this vid:
orientation doesn't make any significant difference if your loop has been "done right".
blnk is offline
post #4 of 9 (permalink) Old 03-01-2019, 01:26 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
That's about components in serial. Parallel is something totally different.
@TS: Xtremerigs tested this: https://www.xtremerigs.net/2018/02/1...s-performance/
If you ok with a small drop in performance, you're fine.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #5 of 9 (permalink) Old 03-01-2019, 08:43 AM - Thread Starter
tintreach's Avatar
Rep: 6 (Unique: 5)
Thanks, that link was helpful. It totally answer the question I had but also gave me some performance data on cpu blocks I didn't know about either.
post #6 of 9 (permalink) Old 03-01-2019, 12:18 PM
toolmaker03's Avatar
Rep: 86 (Unique: 65)
I parallel all of my water loops today.
my test build
https://www.overclock.net/forum/61-w...el-9-6lpm.html
my actual build
https://www.overclock.net/forum/61-w...ooled-rig.html
my extreme build
https://www.overclock.net/forum/62-p...c-cooling.html
as you can see I have been doing this for some time.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
post #7 of 9 (permalink) Old 03-01-2019, 02:20 PM
drewafx's Avatar
Rep: 5 (Unique: 5)
Flow rate is what cools the blocks lower...then water temperature which is determined by how fast the fans are moving.
Halve your pump and see it it gets worse significantly...probably will need to double that pump speed when you parallel loop for equal flow rate.
drewafx is offline
post #8 of 9 (permalink) Old 03-07-2019, 11:02 AM
Yomny's Avatar
Rep: 20 (Unique: 16)
I'm assuming we're not using two pumps for separate loops for obvious reasons. Regardless most pumps now days could run a single CPU/GPU loop in parallel easily. Unless you're running some old junker, i'd say anything over 500l/h with decent head pressure should suffice.
Corsair
(9 items)
Core i9 9900k 4.9ghz @1.3
Asrock Z390 Extreme4
RTX 2080 Ti EVGA HC Waterblock
G.SKILL TridentZ Series F4-3000C15D-16GTZ
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
HWL 280-120mm CPU/GPU
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #9 of 9 (permalink) Old 03-07-2019, 11:04 AM
skupples's Avatar
Rep: 584 (Unique: 327)
I've ran 3x gpu in parallel, to an entire cooled board (mem, chip, set) n had no issues or differences compared to when I used a serial block.
I'm however running MCP35x2 @ full tilt due to the sheer size of my loop. Water barely hits 1GPM, in serial or parallel.
skupples is online now
