When do you need to move to two D5 pumps? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 03-01-2019, 07:42 PM
ttnuagmada's Avatar
Rep: 8 (Unique: 8)
I have a CPU, VRM and 2 GPU blocks along with a 560 GTX 480 GTX and 280 SR2 plus 2 QDCs. With 2 D5's at full blast I get like 1.1 GPM.
ttnuagmada is offline
post #12 of 17 (permalink) Old 03-04-2019, 10:56 AM
pgdeaner's Avatar
Rep: 36 (Unique: 35)
The generally accepted wisdom of water cooling is that your loop needs to maintain a flow of 1GPM or greater to be most efficient. So if you can get 1GPM or greater with the equipment you have you are fine. If you get less than 1GPM you need another pump in serial, or as others suggest you can run parallel loops. (I run all mine serial with dual pumps running less than 50% for noise and for aesthetic reasons).
“Who you are is defined by what you’re willing to struggle for.”― Mark Manson
Nuka Cola
(0 items)
pgdeaner is offline
post #13 of 17 (permalink) Old 03-04-2019, 11:03 AM
skupples's Avatar
Rep: 515 (Unique: 290)
skupples is offline
post #14 of 17 (permalink) Old 03-05-2019, 07:28 AM
pgdeaner's Avatar
Quote: Originally Posted by skupples View Post
When you have the money
Unfortunatly, custom loops are not a budget friendly hobby. Lots of data to support the 1GPM requirement. Wish Martin was still publishing but his data is still out there. There are stronger pumps available for a single pump configuration. Lots of ways to measure flow without a flow meter. A graduated home depot bucket and a watch will work as accurate as a flow meter.
That is what really determines the need for a second pump. All else is redundancy and preference.
Nuka Cola
(0 items)
pgdeaner is offline
post #15 of 17 (permalink) Old 03-05-2019, 07:34 AM
profundido's Avatar
Rep: 16 (Unique: 15)
Quote: Originally Posted by MADworld View Post
My current plan
1x 560 Hardware Labs Black Ice SR2 560MP
2x 420 Hardware Labs Black Ice SR2 420MP
1x CPU Watercool Heatkiller IV Pro Intel Black Copper
2x GPU Watercool Heatkiller IV RTX 2080 Ti acrylic Ni-Bl RGB
1x RES Aqua Computer Aqualis XT
1-2 PUMP Aqua Computer D5 Next
All with hard tubing (brass) so quite a few 90 degree angels I imagine.
Would a single Aqua Computer D5 Next be able to handle this or should I look at a dual serial D5 setup?
TLDR When is it too much for a single D5?
That setup is borderline for a single D5 pump. It will be possible but the pump will need to run close to 100% in order to achieve just acceptable flow rate. In other words this calls for double D5.
Absolutely go single loop ! Your plan of maximizing 3D radiator space is awesome so make sure you use it by sharing all load over that combined volume. Splitting into 2 loops would be a mistake
profundido is offline
post #16 of 17 (permalink) Old 03-07-2019, 04:23 AM
RichKnecht's Avatar
Rep: 4 (Unique: 4)
I read through this thread (and others) about using 2 pumps. My loop consists of a XRes 140 D5, 2 PE360s, a XE 360, 6 90 degree elbows and a Supremacy block. It is all soft tube. My temps seem fine at idle, but I feel they should be better than they are with 3 360mm rads, especially when bench marking or pushing it hard. I've seen other people using the same chip as I am (7900X) with more current and less rad space and they are running cooler than I am. Something has to be going on here.
Editing PC
(11 items)
7900X
Asus Rampage VI Extreme Omega
ASUS RTX 2060 Dual
Corsair vengence RGB 3466
Samsung 960 EVO 256GB
EVGA 1300W SuperNova Gold
EKWB PE360x2, XE360, Supremacy EVO RGB, Xres140 D5 RGB
Liam Li PC011 Air
Operating System
Windows 10 Pro 64bit
Dell U2412
BenQ 2700PT
RichKnecht is offline
post #17 of 17 (permalink) Old 03-07-2019, 05:07 AM
toolmaker03's Avatar
Rep: 79 (Unique: 60)
well their are a couple things most likely going on with your water loop, but a second pump may fix most of the issues.
https://www.overclock.net/forum/61-w...ter-block.html
as for the CPU water block itself, that is up to you on how to deal with that issue, if your CPU water block has the same issue mine has.(replace it)
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
