When do you need to move to two D5 pumps? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 03-01-2019, 05:44 AM - Thread Starter
MADworld's Avatar
Rep: 2 (Unique: 2)
My current plan
1x 560 Hardware Labs Black Ice SR2 560MP
2x 420 Hardware Labs Black Ice SR2 420MP
1x CPU Watercool Heatkiller IV Pro Intel Black Copper
2x GPU Watercool Heatkiller IV RTX 2080 Ti acrylic Ni-Bl RGB
1x RES Aqua Computer Aqualis XT
1-2 PUMP Aqua Computer D5 Next
All with hard tubing (brass) so quite a few 90 degree angels I imagine.
Would a single Aqua Computer D5 Next be able to handle this or should I look at a dual serial D5 setup?
TLDR When is it too much for a single D5?
MADworld is offline
post #2 of 17 (permalink) Old 03-01-2019, 06:28 AM
Indentified! On the Way!!
LancerVI's Avatar
Rep: 153 (Unique: 114)
I would say "you're there".
Not that a single pump won't still work, it will, but you'll get almost double the head pressure with two and the security knowing that if one of the pumps fail, the second will still pump. I believe a single pump in the loop you described, depending on how many bends, would struggle in the long run. My two D5s, I purchase more than 10 years ago and they're still running great. My theory is because I always use them together, in serial. I could be completely wrong, I'm no expert, but I had a single D5 in another complicated loop and it failed after about 4 years. I believe the restriction of the loop caused that pump to work harder than if it had a second pump working along side it, hence the failure. I'm only sample size of one, but still, it was enough to convince me of two pumps in complicated loops.
I run two Koolance 480's, two RES and one GPU block and CPU block and always use two D5s in serial. I would say, IMHO, that when more than one Rad and waterblock is involved, two pumps is almost a necessity.
It looks like you'll have 3 RADs and 3 blocks. Again, IMHO, I would never run that loop without two pumps. Not saying it wouldn't work, but I'd sleep better at night knowing if one pump failed, I'd still be good to go.
Boy do I miss Martin's Liquid Lab......check this out for more info. It's old, but most of it still applies.
https://martinsliquidlab.wordpress.c...s-vs-parallel/
If you do go dual pump, GO SERIAL! Don't do a parallel loop.
LancerVI is offline
post #3 of 17 (permalink) Old 03-01-2019, 08:15 AM
ChiTownButcher's Avatar
Rep: 34 (Unique: 30)
Every time I see people quoting Martin's LL I remember how crucial he was to this hobby and how much we lost when he stopped testing.
That said I would agree that a second D5 would be a good idea. You will be able to get same or better flow rate with less noise and the reliability that 2 pumps provide
Self Proclaimed Gaming Nutt
ChiTownButcher is offline
post #4 of 17 (permalink) Old 03-01-2019, 08:34 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
The SR2 radiators are very high flow. And if you setup the GPU blocks in parallel, the pressure drop will be 50% of a SINGLE block. (25% of 2 blocks in series).
For reference: I'm running 2x 360GTS, CPU and GPU block, 9x 90° adapters and a single D5. 3x SR2's are have the same restriction as 1 GTS360 and a GPU block has the same restriction as a single 360 GTS. And 140mm rad with is also less restrictive than 120mm rad with because you have 1 or 2 extra channels.
So your loop would have about the same restriction as mine with the GPU's in serial and even less with the GPU's in parallel. I'm getting 1GPM with a D5 at full speed, so you should be fine with a single D5. And when I drop my pump speed too 3000rpm, my temps raise only 1°C.
If you had 3x GTS rads, then it would be a different story and I'd dual D5's is a must.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #5 of 17 (permalink) Old 03-01-2019, 08:41 AM
Overclocker in training
ThrashZone's Avatar
Rep: 92 (Unique: 67)
Hi,
I'd personally if I had a case to do it I'd just use two loops
One for cpu and one for gpu.
Put two rads on the hottest item which you don't mention which cpu you'd be using
But two 2080ti's I'd suspect to be the two hottest items pushed hard
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #6 of 17 (permalink) Old 03-01-2019, 08:43 AM - Thread Starter
MADworld's Avatar
Rep: 2 (Unique: 2)
Figured as much but good to confirm my suspicion.
So what now,
The XTOP is incompatible
https://www.ekwb.com/shop/ek-xtop-re...-d5-pwm-serial
The XSPC works I hear but it goes in a bay and the case I want does not have any bays
http://www.xs-pc.com/reservoirs/twin...-bay-reservoir
What serial tops are there for the Aqua Computer D5 Next?
MADworld is offline
post #7 of 17 (permalink) Old 03-01-2019, 08:50 AM - Thread Starter
MADworld's Avatar
Rep: 2 (Unique: 2)
Quote: Originally Posted by ThrashZone View Post
Hi,
I guess a dual loop should bee considered.
I'm just so attached to making a single loop . Don't even know why, more elegant?
plans are
2x 2080 ti, 380W bios
9900K 5GHz+ if lucky.
MADworld is offline
post #8 of 17 (permalink) Old 03-01-2019, 08:56 AM
Rep: 3 (Unique: 3)
plans are
Single loop is perfect. The CPU barely produces heat during gaming. My 8700k was cooled by a single GTS360 for a while and the delta T was only 2-4°C depending on the water. With a 1080TI in the loop and an extra 360GTS it's 10°C. This means that my CPU is running a little hotter, but my GPU is benefitting from extra cooling.
I would go dual loop, my GPU would run hotter and my CPU a little cooler.
Just choose whatever you want. Both options have their pro's and cons so choose the one you like the most. Single loop is easier to build and maintain btw.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #9 of 17 (permalink) Old 03-01-2019, 09:05 AM
ThrashZone's Avatar
Hi,
Draw it out your case will pretty much sum whether dual loop can be done nicely.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 17 (permalink) Old 03-01-2019, 11:02 AM
toolmaker03's Avatar
Rep: 86 (Unique: 65)
plans are
I would be considering two pumps at the least. also if you like the single loop idea, but would like to try something a little different. I parallel all of my water loops today.
my test build
https://www.overclock.net/forum/61-w...el-9-6lpm.html
my actual build
https://www.overclock.net/forum/61-w...ooled-rig.html
my extreme build
https://www.overclock.net/forum/62-p...c-cooling.html
as you can see I have been doing this for some time.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
