why are my temps so high? - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 03-02-2019, 05:49 AM - Thread Starter
kaitlin4599's Avatar
Rep: 2 (Unique: 2)
ok so i have a xeon w3690 overclocked to 4.3Ghz at 1.35 volts on the vcore. while gaming temps max out at 70c on all 6 cores i recently had a 240mm aio at 4.01Ghz but decided to up grade my aio. i though going from a 240mm to a 360mm aio would net me better temps, seeing how it had more space and a 3rd fan. even tho i increased my over clock from 4.01 to 4.3 am i missing something below is a link to my AIO thermal paste
is MX-4
http://www.coolermaster.com/cooling/...id-ml360r-rgb/
HP Z400 workstation with a GTX 750Ti
kaitlin4599 is offline
post #2 of 12 (permalink) Old 03-02-2019, 06:00 AM
Mmmm donuts.....
VicsPC's Avatar
Rep: 1 (Unique: 1)
is MX-4
If that's max its not too bad, if that's the average then seems a bit high. Don't forget that AIOs dont have the flow rate of custom loops, although people say it doesn't matter, it does. The radiator is also aluminum, won't dissipate heat as much as a copper one. You need to see what your cpu is maxing out at. Depending on fan speed, a copper radiator can dissipate anywhere between 75 to 350w or so depending on push/pull and good flow. Thats for a water delta of 10°C for 5°C half those measurements.
You can try repasting but i doubt youll see much improvement. Not sure if the 3690 is soldered or not.
My 1700x build
(6 items)
1700x
ROG Crosshair VI Hero
Vega 64
Corsair 16gb 3200mhz CL16
Corsair RM1000
Core X5
VicsPC is online now
post #3 of 12 (permalink) Old 03-02-2019, 06:09 AM
Overclocker in training
ThrashZone's Avatar
Rep: 42 (Unique: 34)
Hi,
All AIO's have paper then radiators
Set pump to max and fans as well about all you can do
Where is the rad installed ? front/ top ?
As intake or as exhaust ?
Intake would be best.
Paste isn't all that different either
I use easy to get nt-h1 personally.
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #4 of 12 (permalink) Old 03-02-2019, 06:16 AM - Thread Starter
Rep: 2 (Unique: 2)
Quote: Originally Posted by ThrashZone View Post
Hi,
rad is installed in the top as exhaust in my enthoo pro all fans and pump are set to max speeds fans are these 3 of them
https://www.ekwb.com/shop/ek-furious...b-1200-3000rpm
post #5 of 12 (permalink) Old 03-02-2019, 06:46 AM
ThrashZone's Avatar
Hi,
Inside case mother board/ ram/... is hotter than I hope your room temperature is
Rads like cool air.
If you want to try it flip the fans as intake
The top/ front of cases are filtered for a reason designed for intake.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #6 of 12 (permalink) Old 03-02-2019, 07:00 AM - Thread Starter
Rep: 2 (Unique: 2)
Hi,
Rads like cool air.
will setting the rad fans as intake lower my temps at all or no
post #7 of 12 (permalink) Old 03-02-2019, 07:03 AM
ThrashZone's Avatar
Hi,
Depends on room temperature
Cooler water = cooler cpu.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #8 of 12 (permalink) Old 03-02-2019, 07:21 AM
white owl's Avatar
Rep: 126 (Unique: 96)
If your CPU cooler is the only exhaust for the GPU then there's a really good chance it would lower temps.
Keep in mind we only know what CPU you have and what size your CLC is so it's hard to say anything for sure.
For all we know temps are high because you have poor case flow and you're playing Battlefield with 1.4vcore.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #9 of 12 (permalink) Old 03-02-2019, 10:47 AM
Dangerously Enticing.
DomeD-'s Avatar
Rep: 5 (Unique: 5)
Do you have a block on your GPU or is it just normal? Whoever said the top fans ahould be intake, yay cookie. Thats what Id do atleast. If your using that HP Z400 case than your airflows doodoo haha. I always put a 150mm fan on top, 1 on the rear and atleast a side fan all sucking air In. Then one on the bottom of the case blowing it out and It worked nicely.
My case is never on carpet or the ground either.
DomeD- is offline
post #10 of 12 (permalink) Old 03-02-2019, 11:58 AM
Shawnb99's Avatar
Rep: 8 (Unique: 6)
Yes. Ambient temp is lower then what’s in the case.
Rads should almost always be intake
Shawnb99 is offline
