Choosing Radiator/s - Page 2 - Overclock.net - An Overclocking Community
Choosing Radiator/s
post #11 of 26 (permalink) Old 03-03-2019, 06:42 PM
Telstar's Avatar
Rep: 24 (Unique: 20)
Quote: Originally Posted by ciarlatano View Post
If you are dead set on using a 60mm thick rad, the HWL SR2 is a much better all around rad than the EK XE. It has better low rpm performance, scales well and has very user friendly multi-port - https://www.xtremerigs.net/2015/02/1...-round-2015/5/
The bolded statement is not true. The SR2 performs better than the XE only at <1000rpm with single fans. At 750rpm push/pull they are already equal.
So, "all-around" the XE is the better rad.
https://www.xtremerigs.net/2015/05/3...ator-review/5/
I re-read most 360 rad tests yesterday because I'm making similar choices, and I decided to go with the XE because at my target speeds of around 1100rpm push-pull it will be better, leaving me more headroom if needed to push higher clocks for some benches or such.
The XE has not as many ports, just two on the opposite side of the fittings that can be used for filling, for instance.
The PE instead is a mediocre performer and should be replaced by at least an alphacool x45 or if thicker can fit Nemesis GTX (5.5cm) or SR2 (6cm).
Quote: Originally Posted by Aontaigh View Post
I'm not sure whether to run two EK-CoolStream PE 240 (40MM Thick) radiators or one EK-CoolStream XE 360 (60MM Thick).
x2 EK-CoolStream PE 240 (40MM Thick): €140
x1 EK-CoolStream XE 360 (60MM Thick) €117
Can't you fit 2x XE 240, or even better one 360 and one 240?
The PE is a bad performer, forget it. Always go for the most radiating area that you can, then for the best rad for your space and usercase (silence or speed).
new rig 2019:
Intel 9900k >5ghz | Asus Maximus XI Gene | Eisbaer 360 LT (custom loop in progress) | bequiet! Dark Base 700 white edition | Team group Nighthawk 16GB 4000mhz | MSI RTX 2070 Armor | Storage: Intel Optane 900p 280GB + Samsung 970 evo plus 1TB + WD Red 3TB | Corsair HX850i | Benq BL3200PT 1440p | 1Gbit ftth |
Telstar is offline
post #12 of 26 (permalink) Old 03-04-2019, 06:12 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 406 (Unique: 273)
I am going to say that the better build quality, better port layout and better low noise performance outweighs a very nominal difference in performance if they happen to be in push/pull at over 1300 rpm....which you should be using a GTX for, anyway.
ciarlatano is offline
post #13 of 26 (permalink) Old 03-04-2019, 06:33 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Just keep in mind that all those radiator tests are done in open air setups without filters, mesh, front door, ... in front of the radiator.
1300rpm in a case with filters and a front could, could perform the same as 800rpm in an open air setup.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #14 of 26 (permalink) Old 03-04-2019, 09:09 AM
ciarlatano's Avatar
Which pushes the advantage even further to the rad with better low rpm capabilities.
post #15 of 26 (permalink) Old 03-04-2019, 09:45 AM
Telstar's Avatar
This is correct
For low speeds, by all means go with the SR2.
I cannot disagree with the build quality but not on the performance.
GTX is a little worse performer, but it's slimmer. At 1300rpm P/P the XE performs much better.
new rig 2019:
Telstar is offline
post #16 of 26 (permalink) Old 03-04-2019, 10:59 AM
drewafx's Avatar
Rep: 5 (Unique: 5)
With fans costing more and more these days I'd not even look at push/pull performance.
It's just not worth double the thickness, cost, noise, etc.
drewafx is offline
post #17 of 26 (permalink) Old 03-04-2019, 01:43 PM
Telstar's Avatar
Well, I disagree. Having the space for the extra fans, they are wort it, particularly on 50-60mm rads. Noise does not double, it's just a few db more.
We already spend hundreds on custom parts, what are 60 bucks more for a second set of fans?
new rig 2019:
Telstar is offline
post #18 of 26 (permalink) Old 03-04-2019, 03:10 PM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
This is correct
keep in mind that all the charts are highly subjective. low FPI radiators do well with low RPM fans attached. while high FPI radiators, do poorly with low RPM fans attached, but with high RPM fans of 3000RPM+'s attached to high FPI radiators. these radiators will always out preform low FPI radiators, regardless of what type of fans are attached to the low FPI radiators. the actual design of the radiator does make a difference.
to give a example hardware labs makes a GTR 20 FPI radiator, and with 3000RPM fans attached will out preform all the radiators on that list, except one. the koolance radiator is a 30 FPI radiator, and with 4000RPM fans attached, it will be the radiator at the top of that list.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #19 of 26 (permalink) Old 03-04-2019, 05:23 PM
Telstar's Avatar
Tests are subjective now? LOL.
One can extrapolate the data to adapt it to his usercase, and that's it.
new rig 2019:
Telstar is offline
post #20 of 26 (permalink) Old 03-04-2019, 05:46 PM
very true, that is why I gave a example of what I was trying to explain. as it is a example of information extraction, for several different sources. as the source data sheet you had provided is geared for low FPI radiators only. as this exert from that radiator review clearly states, but the radiator itself only receives a 3.0 score. even though it is the highest preforming radiator he has tested.
https://www.xtremerigs.net/2015/07/3...ator-review/6/
The Koolance HX-CU1020V 360mm is a slim radiator which by default means it will never have outstanding thermal performance. When we break down the results and look at the thermal performance of only the slim radiators, the HX-CU1020 performed very well and ranked second overall for performance. It is however extremely restrictive and this lowered its performance score a bit. However for high speed fans and the ability to dissipate heat in a small space without regard to noise this radiator is simply the best option. No other radiator comes close to such high performance at high airflows.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
