Choosing Radiator/s - Overclock.net - An Overclocking Community
Choosing Radiator/s
post #1 of 26 (permalink) Old 03-02-2019, 06:35 PM - Thread Starter
Aontaigh's Avatar
Rep: 0
Choosing Radiator/s
I'm currently looking into creating my first custom loop which be used to cool both my CPU (i5-8600K - 5GHz) and GPU (1080ti - XOC BIOS).
I'm not sure whether to run two EK-CoolStream PE 240 (40MM Thick) radiators or one EK-CoolStream XE 360 (60MM Thick).
x2 EK-CoolStream PE 240 (40MM Thick): €140
x1 EK-CoolStream XE 360 (60MM Thick) €117
I have Noctua NF-F12s which will be used on the radiator/s.
Which would be the ideal option in this situation?
CPU: Intel Core i5-8600K - 5GHz (Delidded | vCore: 1.435v | Cache: 4800MHz) | GPU: MSI GTX 1080ti Armor OC [Core: 2100MHz | Memory: +600MHz | Voltage: 1.15 | XOC BIOS] | RAM: TEAM GROUP DARK PRO EDITION (8GB x 2 | Frequency: 3866MHz | Timings: 16-16-16-36 | vDIMM: 1.45v) | Motherboard: ASUS PRIME Z370-A | PSU: Seasonic PRIME ULTRA GOLD 1000W | CPU Block: EK Velocity | GPU Block: EK-FC1080 GTX Ti TF6 | Radiators: x2 HWLabs SR2 360MM  | Pump / Res: EK-XRES 140 Revo D5 PWM | Fans: x6 Noctua NF-F12
Aontaigh is offline
post #2 of 26 (permalink) Old 03-02-2019, 06:55 PM
toolmaker03's Avatar
Rep: 79 (Unique: 60)
well at minimum I would use a 360mm radiator. in truth you will need a second radiator as well. the smallest would be a additional 240mm radiator needed for this build, to run well, and cool. I would also suggest actually getting two 360mm radiators as that will be a little more than what is needed. also I would suggest getting some hardware labs GTX or GTR radiators for this build. I would also suggest getting a heat killer CPU water block, and the same for the GPU water block, if they make one for your video card. as for reservoirs I like monsoon, bitspower, and water cool. for all rotary fittings, I would suggest getting bitspower, or barrow only. for the compression fittings, I would suggest the use of koolance, or swiftech. for tubing I like norprene 3/8" ID 5/8" OD, as for the water pump, or pumps, I would suggest getting a XSPC, swiftech, water cool, or aqua computers D5.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
post #3 of 26 (permalink) Old 03-03-2019, 03:36 AM - Thread Starter
Aontaigh's Avatar
Rep: 0
I looked into getting a second radiator and was considering going for the HWLabs Black Ice Nemesis 360GTS to mount on the top of my case, anything thicker than this would have clearance issues with my RAM, and an EK-CoolStream XE 360 mounted at the front.
Do you think Noctua NF-F12s would be sufficient for those radiators or would you suggest different fans?
Aontaigh is offline
post #4 of 26 (permalink) Old 03-03-2019, 03:45 AM
Hardware Princess
Hydroplane's Avatar
Rep: 20 (Unique: 18)
I would also recommend the HWLabs Nemesis GTS series, if you need a thin radiator. The NF F-12s are good fans.
CHILLER DESTRUCTION
Build Log - White Voodoo
Test Bench
(11 items)
White Voodoo
(14 items)
9900K
EVGA Z390 Dark
Titan RTX 2085/7256
16gb Trident Z DDR4-4133 19-19-19-39 1.35V
OCZ Vertex 4 256GB
EVGA 1300 G2
HWLabs Nemesis 360GTX
EK Vardar 120ER 2200rpm
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
G.Skill Trident Z 32GB (4x8GB) DDR4-3200 CL14
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #5 of 26 (permalink) Old 03-03-2019, 03:51 AM
well I have noctua 120mm fans, but they are IPPC 3000RPM fans, I also have some kaze ultra 3000RPM fans. with a fan controller, I can turn them down at idol, and turn them up when at load. I also use fan filters, so it is a must for me, to have stronger fans. I like the noctua fans because they last forever.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #6 of 26 (permalink) Old 03-03-2019, 04:51 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 374 (Unique: 259)
If you are dead set on using a 60mm thick rad, the HWL SR2 is a much better all around rad than the EK XE. It has better low rpm performance, scales well and has very user friendly multi-port - https://www.xtremerigs.net/2015/02/1...-round-2015/5/
Your NF-F12s would be a fine choice with the GTS or SR2.
ciarlatano is offline
post #7 of 26 (permalink) Old 03-03-2019, 07:09 AM
Overclocker in training
ThrashZone's Avatar
Rep: 42 (Unique: 34)
Hi,
Be aware ek rads have a couple collars on them that other rads do not have that could break or leak
Most rads all one has to worry about are the actual hose fittings leaking not two additional places,
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #8 of 26 (permalink) Old 03-03-2019, 07:45 AM
ezveedub's Avatar
Rep: 137 (Unique: 96)
A single 360 60mm radiator will work for this setup, as I currently have one running same I5 cpu but with a 1070 and cooling is not an issue.
Sent from my iPhone using Tapatalk Pro
Intel Processor
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
HAF 932
Operating System
Windows 10
ezveedub is offline
post #9 of 26 (permalink) Old 03-03-2019, 08:00 AM
ciarlatano's Avatar
Yes....but adding the second rad would certainly bring down the noise level at like performance. And depending on the rad, the noise levels on a 60mm at like performance can be drastically different. Is it an SR2 that performs really well at 900 rpm, or are we talking about an EK XE or Nemesis GTX that don't match the SR2 until you get over 1400 rpm?
I'm baffled by the "I go by thickness and don't take the other factors into consideration" designs. In a build designed for low noise, something like a 30mm Nemesis GTS will outperform every 60mm thick rad out there.....except the SR2. THere is so much more to rads than just thickness.
post #10 of 26 (permalink) Old 03-03-2019, 08:07 AM
ezveedub's Avatar
Tell you the truth, I don’t use any Hsrdware Labs radiators...overpriced IMO. Plus noise isn’t much of an issue, as I use GT 2150 fans on a 45mm 360 MagicCool and it’s there isn’t any noise to complain about running everything on temp speed control, as most it sits at 1100-1300 RPM on the fans. The 1080 GPU will kick off more heat than the I5 CPU also.
Intel Processor
Z270X-Gaming 9
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
HAF 932
Operating System
Windows 10
ezveedub is offline
