X2O 750 12V Pump/Reservoir - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 03-04-2019, 10:30 AM
Mr.4way SLI
Moparman's Avatar
Rep: 186 (Unique: 168)
I have been using this Dual X2O 420 for a long time now with no issues. Might be worth a look since it has a different design than the old 750 res/pump. http://www.performance-pcs.com/twin-...yres-pump.html
They also have a single pump style. http://www.performance-pcs.com/x2o-4...Specifications
Moparman is offline
post #12 of 17 (permalink) Old 03-04-2019, 11:27 AM
Rep: 844 (Unique: 618)
Quote: Originally Posted by man00 View Post
I like to be able to use the hoses already there, just swap out the res/pump. I'll try and find a DDC pump...may be one on here for sell...thanks
So, you'll just hook up a pump to the X20? I did the same. Hooked up a D5 on mine.
rdr09 is offline
post #13 of 17 (permalink) Old 03-05-2019, 08:48 AM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
I see the new one has two inlets, I only have one in my setup now, still not sure on the barbs if I recall didn't the original kit came with 7/16" hoses? I know the barbs are 1/2" should I go with 1/2" to 5/8 or 3/4" is guess 5/8" and wonder is the Res comes with plug for other inlet that I wouldn't use..I emailed them but got nothing back yet..
man00 is offline
post #14 of 17 (permalink) Old 03-05-2019, 08:57 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 371 (Unique: 257)
Yes, 1/2" barbs with 7/16" ID tubing are included in these kits.
What component are you asking about? Fittings? Tubing?
I see the new one has two inlets, I only have one in my setup now.......and wonder is the Res comes with plug for other inlet that I wouldn't use..I emailed them but got nothing back yet..
What is "the new one"? You have never indicated what you are buying?
ciarlatano is offline
post #15 of 17 (permalink) Old 03-05-2019, 09:36 AM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
the new one
I was asking about the fittings...sorry
man00 is offline
post #16 of 17 (permalink) Old 03-05-2019, 09:53 AM
ciarlatano's Avatar
the new one
If you are keeping the same tubing you need to stay with 1/2" barbs.
If you look on the link that you posted, it states "Supplied with black faceplate, 4x M3 x 4mm screws, G1/4″ Plug, and blue LED.".
post #17 of 17 (permalink) Old 03-05-2019, 12:04 PM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
I know there lots better setups out there but only cooling the CPU so this new one will be fine. To tell the truth I don't think I've OC in years.
I have a few air coolers around just in case..thanks for all the help guys
man00 is offline
