X2O 750 12V Pump/Reservoir - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 03-03-2019, 07:15 AM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
Think I hear a little rattle so about time to replace again, anyone know of something that I can pretty much just swap out the pump/res and go?
I guess they stop making these combos
thanks
man00 is offline
post #2 of 17 (permalink) Old 03-03-2019, 07:42 AM
ezveedub's Avatar
Rep: 137 (Unique: 96)
They still have 5.25 bay reservoirs with pumps...but most will be with a D5 or DDC pump. I use the EK D5 D-Bay reservoirs and have used Alphacool 5.25 DDC pump reservoir also as well as XSPCs version from a while back.
Sent from my iPhone using Tapatalk Pro
Intel Processor
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
HAF 932
Operating System
Windows 10
ezveedub is offline
post #3 of 17 (permalink) Old 03-03-2019, 08:10 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 374 (Unique: 259)
The Swiftech Maelstrom V2 is a nice direct replacement, but pricier than the XSPC at $139 - http://www.swiftech.com/MaelstromV2.aspx
Monsoon makes a nice DDC res that is inexplicably cheap on Amazon at the moment - https://www.amazon.com/Monsoon-Dual-...dp/B00EURG7X8/ , you would need to add a DDC pump.
Can you make a switch to a small res/pump combo like an ION? - https://www.amazon.com/XSPC-FBA_WASE.../dp/B01FZMLFV0
ciarlatano is offline
post #4 of 17 (permalink) Old 03-03-2019, 08:23 AM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
I like to be able to use the hoses already there, just swap out the res/pump. I'll try and find a DDC pump...may be one on here for sell...thanks
man00 is offline
post #5 of 17 (permalink) Old 03-03-2019, 09:30 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 17 (Unique: 16)
Have you any personal experience with that? And if so, are you willing to share? I've read.. "reviews".. but if you've used it, i'd like to read what you thought of it.
Pride, honour and purity.
Aenra is offline
post #6 of 17 (permalink) Old 03-03-2019, 10:00 AM
ciarlatano's Avatar
I did a couple of loops for others with it a couple (maybe "few") years ago. To my knowledge, both are still working with no issue. They were easy to work with, small enough for good flexibility in mounting, and moved enough liquid for a small loop without a lot of restriction (they are easy to run in serial should you need more). They were quiet enough, but a little buzzy sounding at times, but it was masked by them being in the case. I never did any flow rate or head pressure testing, so I can't be of help there. Just impressions, no numbers.
post #7 of 17 (permalink) Old 03-03-2019, 10:03 AM
Tetrapyloctomist
Aenra's Avatar
Thanks man, appreciate it
Aenra is offline
post #8 of 17 (permalink) Old 03-04-2019, 09:24 AM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
Does anyone remember what size barbs were used in this kit 3/8" or 1/2" I'm away from that pc right now
man00 is offline
post #9 of 17 (permalink) Old 03-04-2019, 10:11 AM
ciarlatano's Avatar
All of the X2O kits I have had, or can find listed, use 1/2" barbs.
post #10 of 17 (permalink) Old 03-04-2019, 10:14 AM - Thread Starter
man00's Avatar
Rep: 5 (Unique: 5)
thanks
man00 is offline
