Case For Dual 360MM Radiator - Overclock.net - An Overclocking Community
post #1 of 21 (permalink) Old 03-03-2019, 02:34 PM - Thread Starter
Aontaigh's Avatar
Rep: 0
I was looking to change my case in order to house x2 Hardware Labs Black Ice SR2 Xtreme+ 360 MP Multi Port Radiators and an EK-XRES 140 Revo D5 PWM.
Radiator Dimensions:
398mm x 133mm x 60mm (L x W x H)
I'm not looking for anything particularly aesthetically pleasing, that has tempered glass, and so forth.
I'm looking more for functionality at a reasonable price and was looking at the Fractal Design Define S:
https://www.amazon.co.uk/gp/product/...KL5A1OLE&psc=1
Could this case house these two radiators or would someone have another suggestion?
CPU: Intel Core i5-8600K - 5GHz (Delidded | vCore: 1.435v | Cache: 4800MHz | AVX: 0 | VCCIO: 1.175 | SA: 1.2 | LLC: Level 6) | Cooler: Corsair H150i PRO | GPU: MSI GTX 1080ti | RAM: TEAM GROUP DARK PRO EDITION (8GB x 2 | Frequency: 3866MHz | Timings: 16-16-16-36 | vDIMM: 1.45v) | Motherboard: ASUS PRIME Z370-A | PSU: Seasonic PRIME ULTRA GOLD 1000W | Monitor: ASUS VG248QE 144Hz
Aontaigh is offline
post #2 of 21 (permalink) Old 03-03-2019, 05:24 PM
Telstar's Avatar
Rep: 24 (Unique: 20)
Why don't you check on fractal design website?
In general, the limiting factor is the thickness of the rads: the SR2 xtreme are 6cm thick.
Just looking at the pictures I would say that you can fit one of those only on front, and you are better at checking the exact case specs beforehand.
I went with a generous midtower (see signature) and got a mATX mainboard to have enough clearance for two thick 360 rads like you want to do. You basically need a full tower for your setup.
new rig 2019:
Intel 9900k >5ghz | Asus Maximus XI Gene | Eisbaer 360 LT (custom loop in progress) | bequiet! Dark Base 700 white edition | Team group Nighthawk 16GB 4000mhz | MSI RTX 2070 Armor | Storage: Intel Optane 900p 280GB + Samsung 970 evo plus 1TB + WD Red 3TB | Corsair HX850i | Benq BL3200PT 1440p | 1Gbit ftth |
Telstar is offline
post #3 of 21 (permalink) Old 03-03-2019, 05:29 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 940 (Unique: 577)
The vanilla S2 and Meshify S2 can fit a front and top 360 fine depending on your motherboard/RAM. If you have big heatsinks on your VRM or RAM it's a no go though.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill 16GB DDR4 4133
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #4 of 21 (permalink) Old 03-03-2019, 06:19 PM
⤷ αC
AlphaC's Avatar
Rep: 815 (Unique: 548)
I'd also look into the P600s from Phanteks:
http://www.phanteks.com/Eclipse-P600s.html
Page 19 reads:
TOP 120mm Radiators: A:405mm B:126mm C:65mm*
FRONT A:465mm B:148mm C:95mm
*If the motherboard and its components (e.g. memory) are 50mm or lower there is no limit in Radiator thickness.
http://www.phanteks.com/assets/manuals/PH-EC600PSTG.pdf
P600S vs Meshify S2 , slightly bigger for people with thick radiators.
Name:	P600s vs s2.PNG
Name:	P60s vs s2 noise.PNG
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #5 of 21 (permalink) Old 03-03-2019, 07:14 PM
Rep: 6 (Unique: 6)
In general, the limiting factor is the thickness of the rads: the SR2 xtreme are 6cm thick (good for medium to high airflow btw).
I went with a generous midtower (see signature) and got a mATX mainboard to have enough clearance for two thick 360 rads like you want to do (going with EKWB XE 6,5cm thick with push-pull fans to run low-moderate speed, which would be about 10cm of total thickness).
Actually it is the opposite. According Extreme Rigs reviews, SR2 is ideal for low speed fans. in fact it is the opposite. So much so that it has only 9 fpi.
lb_felipe is offline
post #6 of 21 (permalink) Old 03-04-2019, 03:36 AM
Telstar's Avatar
Yes, I confused with another rad.
new rig 2019:
Telstar is offline
post #7 of 21 (permalink) Old 03-04-2019, 05:23 PM
lovan6's Avatar
Rep: 6 (Unique: 6)
I use an Inwin 303 with 360 GTS on top and 360 SR2 at the bottom with EK-XRES 110 Revo D5 PWM and work pretty well for the price of the case.
I was planning to use 2 360 SR2 top and bottom but the top can only fit up to 70mm radiator and fans clearance . the only solution I can think is install the fans at the back of honeycomb next to power supply on the top radiator as push and use a 600 watt mini itx power supply but I have not done it yet.
lovan6 is offline
post #8 of 21 (permalink) Old 03-05-2019, 05:17 AM
Telstar's Avatar
Quote: Originally Posted by lovan6 View Post
I use an Inwin 303 with 360 GTS on top and 360 SR2 at the bottom.
It's a strange mix - one rad designed for highspeed and one for low speeds. How fast do you run your fans? I assume singles push. It's a dual loop perhaps?
new rig 2019:
Telstar is offline
post #9 of 21 (permalink) Old 03-05-2019, 08:59 AM
News Fiend
ryan92084's Avatar
The GTS and SR-2 are both great low speed rads. Literally the top 2 on the old radiator roundup 750rpm test.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #10 of 21 (permalink) Old 03-05-2019, 09:01 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 371 (Unique: 257)
These are both rads designed for low speed fans and are absolutely complementary.
ciarlatano is offline
