Recommendations for available dual D5 pump top. - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 03-04-2019, 08:01 AM - Thread Starter
I have an old style EK that currently runs in my daughter's machine but I understand that they are no longer available.
What is the best dual D5 pump top available these days?
Nuka Cola
(0 items)
Eusbwoa18 is offline
post #2 of 10 (permalink) Old 03-04-2019, 08:22 AM
skline00's Avatar
Rep: 14 (Unique: 12)
I have been using a XSPC twin D5 pump reservoir for a LONG time with success.
9900k-5.0-Kraken X72|Asrock Z390 Taichi|16g-DDR4-3200 FlareX|EVGA GTX 2080TI XC | Corsair MP500-480g||PC P&C 950W|Thermaltake V51|Acer ET430k|Win10-64 home
5960x-4.4-EK WB|AsusRE5|16g DDR4-2400|Gigabyte GTX1080TI WB |2-500gb ssds|Win10-64|PC P&C 1200W|Thrmltake X9|3 XSPC RX480 |Dell UM3514W | Win 10-64 home
2700x stock H100i v2 240 AIO|Gigabyte 470|16g-DDR4-3200 Flare-X|Asrock Radeon VII |3-500g ssds|Antec 750W|Crsr 100R|BenQ3200+Oculus Rift
skline00 is offline
post #3 of 10 (permalink) Old 03-04-2019, 11:37 AM - Thread Starter
Anyone have experience with the EK-XTOP Revo Dual??
Nuka Cola
(0 items)
post #4 of 10 (permalink) Old 03-04-2019, 12:02 PM
2+2=5
tictoc's Avatar
I've used mine in a number of different systems, and it has been flawless. Currently it is in a loop with 3 GPUs, 4 radiators, and a 2970WX. Before that it was in a system with 4 GPUs, 2 Xeons, and 4 radiators.
In the current system I have both pumps set to 3, and in the old system they were set to 4.
tictoc is offline
post #5 of 10 (permalink) Old 03-05-2019, 08:30 AM - Thread Starter
Quiet?
How does the mounting system manage vibration transfer? It looks pretty good. I'm looking for quiet.
Nuka Cola
(0 items)
post #6 of 10 (permalink) Old 03-06-2019, 12:10 AM
ttnuagmada's Avatar
Rep: 15 (Unique: 15)
I have the newer EK one and it works fine as far as I can tell, but I don't really have a frame of reference.
ttnuagmada is offline
post #7 of 10 (permalink) Old 03-07-2019, 06:31 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
http://www.performance-pcs.com/bitsp...uv-purple.html
well bitspower makes a nice duel top for D5 pumps. if that is what you are looking for, personally I do not use the duel tops, but I do see the reason for them. all of my water loops have at least two pumps. this is for two reasons, one, to increase water flow rate, and two, for redundancy. if one pump fails, it will not prevent me from still using the system, until the new pump arrives.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #8 of 10 (permalink) Old 03-07-2019, 07:30 AM
Robocop is #1 movie ever
Dagamus NM's Avatar
Rep: 70 (Unique: 49)
The bitspower dual top is fine but it has a few serious drawbacks compared to the older EK dual tops which look similar in design.
The bitspower requires additional kits to actually attach the pump to the top. The EK comes with the mounting stuff. That said, the kits for the bitspower are metal and come in the same colors as their fittings so the end result looks amazing. The mounting kits are expensive and double the total price for the setup.
Do not use the reservoir conversion kit that mounts to the pump top. EK did this perfectly as the water comes into the reservoir and then flows down into the pump. The bitspower reservoir just sits on top and all of the air bubbles just go right into the pump and back out into your loop. Pretty much complete garbage and completely pointless yet costs the same as the EK setup.
Just things to be aware of. Have an independent reservoir upstream of the pumps and be prepared to spend twice as much. End result looks great though.
Ol' Dirty Bastard
(29 items)
6950X
Asus Rampage V edition 10
Titan X Pascal
Titan X Pascal
G.Skill Ripjawz 4 128GB 3200MHz C14 RGB
Intel 730 series 480GB
Intel 6000P 1TB m.2
WD Black 6TB
Optical Drive
Asus external BD DVD
eVGA 1600W P2
EK RVE Edition 10 monoblock
EK Titan X Pascal waterblocks with EK back plates
Aquacomputer 420mm rad/res/pump combo
Aquaero 6 Pro
Aquacomputer serial dual D5 pumps with bitspower top and mounts
Caselabs s8
Operating System
Windows 10 Pro
Asus pb287q
Asus pb287q
Asus pb287q
Keyboard
Microsoft Sculpt Wireless Ergonomic
Mouse
Logitech wireless trackball
Audio
Cambridge Audio DacMagic 100+
Audio
Sennheiser HD650
Other
Logitech F710 wireless game pad
Dagamus NM is offline
post #9 of 10 (permalink) Old 03-07-2019, 07:59 AM
just a thought, but have you ever considered that the reason EK stopped making the duel top is because they where selling it for less than it cost them to make?
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #10 of 10 (permalink) Old 03-07-2019, 08:05 AM
Dagamus NM's Avatar
The bitspower top doesn't sell for any more than the EK one did, a little cheaper actually. Well the top itself. Last time I looked when trying to decide between the two the bitspower was about $10 cheaper. Of course I learned about the mounting kits afterwards.
The EK has a piece of plastic that the D5s stick through that is secured with several screws. The bitspower requires the mounting kit which is metal and screws onto threads on the bottom of the pump top.
Maybe EK stopped producing that top because of costs though I am not convinced. Unless they said so explicitly this is just speculation.
They moved to the Revo setup which I have not used and cannot say if it is better or worse. I suppose it is better from a mounting perspective in that you don't need as much space in your case, but I do not think they look as good.
Ol' Dirty Bastard
(29 items)
6950X
Titan X Pascal
Titan X Pascal
Intel 6000P 1TB m.2
WD Black 6TB
Optical Drive
eVGA 1600W P2
Aquaero 6 Pro
Caselabs s8
Operating System
Windows 10 Pro
Asus pb287q
Asus pb287q
Asus pb287q
Keyboard
Mouse
Audio
Audio
Sennheiser HD650
Other
