Best price/perf low rpm fans for Xspc Rx360 rad - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 03-07-2019, 09:24 AM
BlackFox1337's Avatar
Rep: 2 (Unique: 2)
Good topic.
I have 2 EK 360mm Rads currently with Corsair SP120 High Static Pressure fans. Problem with these fans is they are super loud at 50% speed ~1500rpm. I just purchased 6x Arctic P12 fans which show 2.2 static pressure at 1800rpm with 22-24 decibels. I measured the Corsair fans at 1500rpm and its 40 decibels. From the research i have done, it looks like the Corsair fans at 1500rpm get lower than 2.0 static pressure as well. The upgrade should be quieter and provide better performance. Would have bought higher quality fans, but im not paying $30 fricking dollars for a single fan.
BlackFox1337 is offline
post #12 of 14 (permalink) Old 03-07-2019, 10:38 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
Quote: Originally Posted by toolmaker03 View Post
dude, your are not understanding the post from the thread starter. the system he has now, is air cooled, and loud. he had a water cooling system a long time ago, and he wants to return to water cooling. he also wants to replace the fans, that on the radiators used on his old water cooling system. my question, is why does he want to replace the 1200RPM fans that are on those radiators now.
Ohhhh. You're right. I did not read that at all out of the post.
OneFunGenesis is online now
post #13 of 14 (permalink) Old 03-07-2019, 03:08 PM - Thread Starter
Satanello's Avatar
Rep: 4 (Unique: 4)
Thank you for all suggestionsI explain why I want to change the old fans: During last years of aircooling i decided to sell most of the old fan so atm i have in my hands only 3 of the 12 noctua nf-s12 ( with ULNA adapters ) and, if possible, I'd like to squeeze better performance and lower noise from my system using new better fans.
After a fast search in Italy the only fan with decent price are the arctic p12 (16€ for one fan), Phanteks and Be quiet have high prices (21/23€!).
In some european shops I can find Phanteks at 14,50€ Be Quiet sw3 at 17,50€ and Arctic at 10€.
Sw3 seem the best performer, i think I can start with 6 of these for the rad 3 installed on the front of the Enthoo Pro M and 3 for the rad on top.
Inviato dal mio MI 8 utilizzando Tapatalk
Satanello is offline
post #14 of 14 (permalink) Old 03-09-2019, 01:09 AM
Rep: 15 (Unique: 14)
I'm happy with the 3x SW3 HF I bought at least, They are basically completely silent at half speed(50% ~1100rpm) and can have a little noise above but it isn't much compared to the old fans I had that are much louder at slower speeds.
Though I noticed they only spin ~2000rpm on the motherboards I've had (a gigabyte and a Biostar)
NEW: Biostar x480GT8... crap shoot. ~4060Mhz CPU, 3144Mhz RAM... 131.0Mhz BCLK.
OLD: Ryzen 7 1700 @ ~4.0Ghz, Gigabyte GA-AB350 Gaming 3, F25 BIOS Agesa 1.0.0.6
4x8Gb Kingston HX434C19FB2K2/16 3466C19 1.2V @ 3733Mhz 16.(17).23.17.34.71.tRFC 568 1T 1.490V (Micron E-die 16nm)
Corsair LPX 2x8Gb 2666C16R @ 3200Mhz 14.(17).17.17.31.49...(260) 1T1.470V (Micron B-die 25nm)
Nighthog is offline
