Aquasuite service stops running while PC is on. - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-07-2019, 08:48 AM - Thread Starter
trawetSluaP's Avatar
Rep: 0
Hi all.
Regardless if i'm gaming, watching a video on YouTube or away from my computer I have an intermittent issue where the Aquasuite service will stop running causing my fans to to 100% and info to the Aquaero 6 XT to not be displayed.
Is anyone aware of a fix?
Or alternatively, is there a way to upload my settings to the 6 XT itself so I don't need to use the software?
Case: Enthoo Elite, CPU: i9-7900X Motherboard: Rampage VI Extreme
RAM: Dominator Platinum 32GB, GPU: EVGA 1080 Ti FTW3
Storage: 960 Pro 512GB, 2 x 840 Evo 250GB, PSU: EVGA SuperNOVA 1200 P2
Monitor PG279Q, MX27AQ
Custom Watercooling Loop + Aquaero 6 XT
trawetSluaP is offline
post #2 of 4 (permalink) Old 03-07-2019, 10:22 AM
roaming in his fishtank
poisson21's Avatar
Rep: 9 (Unique: 7)
Weird, i kill regularly the aquasuite service because it bloated itself to 2 GB and never ever have my fan or pump gone crazy, my aquaero 6 always keep the setting.
poisson21 is offline
post #3 of 4 (permalink) Old 03-07-2019, 10:31 AM
skupples's Avatar
Rep: 515 (Unique: 290)
same as above.
If wired properly, the aquaero should be storing the profle, thus leaving aquasuite service as optional
I'd manually remove all of it, check for system updates, restart, re-isntall ,etc.
skupples is offline
post #4 of 4 (permalink) Old 03-07-2019, 03:58 PM
drewafx's Avatar
Rep: 4 (Unique: 4)
If it depends on software sensors, you can set fallback temperature (useful when booting computer/windows update/situation where the service is not working)
drewafx is offline
