Water Temps - What are you getting? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 03-09-2019, 04:19 PM
Abaidor's Avatar
Rep: 2 (Unique: 2)
Quote: Originally Posted by Puck View Post
Pre and post rad temps should be nearly identical in a running loop.
There is virtually no temp delta before and after the rad since the system quickly reaches equilibrium. You may measure 1-2c difference tops, not always 7-8c. If you are seeing that, one of your temp sensors is bad (swap them and the delta will move).
FWIW my ambient temp is currently 23c and my loop temp after just watching youtube for 30mins is 27.1c. If it was just the CPU though coolant would be whatever ambient is.
Right now on idle I have 1C difference when on full load (e.g. Prime 95) then the difference is greater and certainly not 1C. It is not 7-8C I just mentioned the extremes (lowest out of radiator on idle and highest before the radiator on load).
But my loop is big, my radiator is a external and holds 2L of water and when the water temp rises the FANS go from 550rpm to 1200C resulting in much higher drop in temps..
Prime 95 right now show 20C out 27C in....the sensors are fine....its the radiator that does a good damn job and being external makes it even more efficient.
However, I will test with another sensor too since I was also amazed at the difference. But having come from using a salt water aquarium and playing with a chiller in the past...this is possible if the rad/chiller whatever you use is of much higher cooling capacity than the amount of heat that enters in it at any given moment.
X299 - i9 7940X
(24 items)
i9-7940X
Asus Rampage VI Extreme
Asus Strix GTX 1080Ti OC
64GB Trident Z RGB
Samsung M.2 960Pro 512GB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Phanteks Asus Strix 1080Ti GPU Block
EK-XTOP Revo Dual D5 PWM
Bitspower Fittings
Heatkiller 200mm Reservoir
9X Corsair ML140 Pro Fans
Coolermaster Cosmos 2
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Logitech MX Master 2S
Mouse
Abaidor is online now
post #12 of 14 (permalink) Old 03-09-2019, 04:28 PM
toolmaker03's Avatar
Rep: 79 (Unique: 60)
Quote: Originally Posted by Thingamajig View Post
No offense but, if thats what it takes to get acceptable temperatures count me out. HAHA.
I'm all for self-contained loops -- all internal. Applying this principle to an ITX rig proved to be even harder than i imagined, but i got there in the end.
well we are of two opinions here. I started 20 years ago water cooling my PC, back then I did install all my hardware inside the PC case. now, obviously that has changed, rather than completely opposing this change, maybe try asking why? to answer this question, It really comes down to looks, Vs performance. I no longer care how my system looks to others, I am more concerned with how well it keeps my hardware cool. I realize that this approach is not for everyone, but it works for me. here is a look at test build I did, before building that actual build.
https://www.overclock.net/forum/61-w...el-9-6lpm.html
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #13 of 14 (permalink) Old 03-09-2019, 04:35 PM
OG AMD
Redwoodz's Avatar
Rep: 574 (Unique: 454)
Quote: Originally Posted by toolmaker03 View Post
yea. here is a pic.
Holy motherofall! You trying to time-travel?
ps.
I think that dust filter on the side has had it.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #14 of 14 (permalink) Old 03-09-2019, 04:48 PM
Rep: 0
8086k @ 5.2Ghz 1.32V LLC 6. Delidded LM.
MSI GTX1080ti X Gaming @ stock
Maximus V Gene
16GB Trident Z 3600/C15
CPU + heatkiller (acetal/copper)
GPU + EK full cover (acetal/nickel)
Pump is a D5, 150mm res, 1/2" tygon tubing
1x GTX black ice 360 Front mount 3x corsair 120mm pull @ 60% speed.
1x GTS black ice 360 Top mount 2x noiseblocker 120mm push out @ 100%. (couldnt fit 3rd fan due restrictions)
Ambient 22 ~ 25C.
Water idle 25 ~ 26C. GPU 25 ~ 26C. CPU 29 ~33C.
Water load 32 ~34C might spike up to 37C during benchmarking. GPU 47 ~ 52C. CPU 58 ~ 65C.
Intens gaming sessions do not alter values, nor does a few of hours stress testing.
That_1_Hz_Extra is offline
