Can't find a water leak - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 03-10-2019, 12:42 PM - Thread Starter
justinjja's Avatar
Rep: 85 (Unique: 80)
I have a large water loop cooling 9 cards.
Cards are all in my room, then tubes run though a wall into my garage, where I have all my radiators.
Loop has 4 MCP50x pumps, and over 30ft of PrimoFlex LRT tubing.
I'm losing something like 1oz of water per day, but no signs of dripping anywhere.
Could that much water just be leaching through the tubing?
It's a lot of tubing, and under much higher than normal pressures.
justinjja is offline
post #2 of 13 (permalink) Old 03-10-2019, 01:56 PM
Shawnb99's Avatar
Rep: 28 (Unique: 19)
Is it just the tubing in the walls or are the connections behind there as well? There must be a leak somewhere.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 13 (permalink) Old 03-10-2019, 02:05 PM - Thread Starter
justinjja's Avatar
Just tubing in the wall, and I can see/feel the tubing all the way through the wall.
(only like 6 inches of tubing is in the wall)
post #4 of 13 (permalink) Old 03-10-2019, 05:54 PM
toolmaker03's Avatar
Rep: 86 (Unique: 65)
well I would suggest two things, one putting the radiators in the garage, if the garage is not keep at the same temperature as the house in the winter, is just begging for your system to fry from condensation one day. second is to replace the tubing with norprene this will reduce the amount of loss through current tubing, by around 90%.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #5 of 13 (permalink) Old 03-10-2019, 07:14 PM
Rep: 66 (Unique: 61)
Can I get a picture? I have no answer but I like seeing cool stuff!
boot318 is offline
post #6 of 13 (permalink) Old 03-10-2019, 07:53 PM - Thread Starter
justinjja's Avatar
@toolmaker03 , I built an Arduino fan controller than measures indoor temp/humidity and water temp, and lowers fans to keep 5c above the dew point.
I'm not supper worried about losing water through the tubes, if that is what is happening.
1 oz/day is just more than I would have expected.
@boot318 yes
post #7 of 13 (permalink) Old 03-10-2019, 07:58 PM
white owl's Avatar
Rep: 136 (Unique: 103)
How old is this set up?
Is it possible that bubbles are just working themselves out?
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #8 of 13 (permalink) Old 03-10-2019, 08:02 PM
Quote: Originally Posted by justinjja View Post
@toolmaker03, I built an Arduino fan controller than measures indoor temp/humidity and water temp, and lowers fans to keep 5c above the dew point.
@boot318 yes
well I have some experience with large builds, and what you are experiencing seems a little high, but not impossible. here is my own large build that I am currently working on.
https://www.overclock.net/forum/62-p...c-cooling.html
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #9 of 13 (permalink) Old 03-10-2019, 08:09 PM - Thread Starter
justinjja's Avatar
2 weeks old, flow rate is pretty high, so I kind of doubt it is trapped bubbles.
every few days I notices a bunch of bubbles in the loop because the water level is getting to low, and air is getting sucked in.
The bubbles clear up pretty quick after refilling the res.
Ooh nice toolmaker.
post #10 of 13 (permalink) Old 03-10-2019, 08:13 PM
white owl's Avatar
Only two weeks?
Sounds exactly like air bubbles...then when the bubbles get out the go into the res which feed more bubbles through it.
If there's no leak, that's where your water is going. Do you shake and flip your rads to try to get the bubbles out or just plug and play? Even AFTER trying to get the bubbles out you'll still have bubbles trapped that are released over a few months, and that just a normal loop with a couple rads.
Flow rate isn't going to make the bubbles 100% just shoot out, if they're stuck more pressure will just push them harder.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
