New Aquacomputer D5 pump has become noisy after only a couple of weeks - Page 3 - Overclock.net - An Overclocking Community
post #21 of 25 (permalink) Old 03-18-2019, 06:06 AM
Overclocker in training
ThrashZone's Avatar
Rep: 129 (Unique: 85)
Hi,
Yeah I don't see how one rma's a pump without having another to use rma's take a while
Fortunately my local micro center carries ek pwm D5 pumps as tops and reservoir combos so replacements are pretty easy to get
They also have in store warranty options too so no shipping other than drive time is involved.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #22 of 25 (permalink) Old 03-18-2019, 06:11 AM - Thread Starter
Zammin's Avatar
Rep: 29 (Unique: 10)
Quote: Originally Posted by ThrashZone View Post
Hi,
Yeah absolutely, I won't be buying important parts from Aquatuning again, I'll try to buy locally where I can to save the hassle dealing with warranties.
I've been looking around the Australian stores this past week to see if any of them have PWM D5 pumps and so far I've only been able to find one at Singularity Computers and it's $150 :/
All the other stores only seem to carry the pre-assembled pump/res combos and pump/top combos. I'm probably just gonna have to bite the bullet and buy from Singularity when I get the rest of this business sorted out.
I haven't forgotten the advice you guys gave me earlier in the thread and when I do get to pulling everything apart again I'll keep it in mind and report here if I find anything.
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #23 of 25 (permalink) Old 03-18-2019, 06:24 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
There’s a reason I don’t use AquaComputer & Alphacool....they don’t know customer service and when I had cosmetic issue with Alphacool’s reservoir when the face plate was coming off, it was more replies that it wasn’t installed correctly that’s why it looks off than actually the faceplate which the adhesive failed and I sent pics showing it peeling off. More back and forth with them to get the RMA approved. Once I given an RMA with my vendor, it was returned for a different brand.
As for my D5 pump, it’s was noisy when at full speed. Sent a video of it to the vendor who sent it to EK. EK approved replacement in 2 days and I had a new D5 pump.
As for the Alphacool VPP755, those are Chinese clones of the original D5 pump. Barrow sells the same pump...it has two washers inside on the impeller shaft, not a ceramic bearing and they are on version 3 now I believe. The VPP655 is original Laing D5 with ceramic bearing and only one I’d trust from Alphacool.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #24 of 25 (permalink) Old 03-18-2019, 06:43 AM
ThrashZone's Avatar
Hi,
Spare is needed regardless
Which one will end up as the primary will depend on the original issue of the thread here = which one is quietest
I have a vario d5 too from watercool "spare" it's not worth it to me to rma
The speed dial is messed up somehow turn it all the way past 5 and it actually slows down
Turn it a tad back and it increases
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #25 of 25 (permalink) Old 03-18-2019, 01:51 PM
Section31's Avatar
Rep: 14 (Unique: 12)
Hi,
Which one will end up as the primary will depend on the original issue of the thread here = which one is quietest [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Turn it a tad back and it increases [IMG class=inlineimg]/forum/images/smilies/confused.gif[/IMG]
I always carry an spare pump. Remember to test them. I have ordered like three of the aquacomputer d5 next in period of two months. I got one that is defective (hope the 3rd one works). I got to send the defective one back for checking.
Section31 is online now
