New Aquacomputer D5 pump has become noisy after only a couple of weeks - Overclock.net - An Overclocking Community
post #1 of 25 (permalink) Old 03-11-2019, 12:58 AM - Thread Starter
Zammin's Avatar
Rep: 36 (Unique: 14)
Hi everyone
Only a few weeks ago I finished my latest watercooling loop. I used an Aquacomputer D5 PWM purchased new from Aquatuning and it was very quiet for a few weeks, but now it makes the noise in the video. It gets worse at certain speeds but can be heard all throughout the entire PWM range.
The pump was running at around 2400RPM (10% PWM) in the video. If you can't hear it try turning the volume up, it was recorded on my phone but it's particularly audible and annoying when the system is at idle (fans at 600RPM, relatively quiet environment).
I'm assuming this means it's faulty and I have put in a request with Aquatuning but incase it might be something I can fix myself, has anyone here heard this before? Any advice? It's very odd, I've never heard of a D5 pump going bad this fast (other than maybe those Alphacool VPP D5 copies).
I doubt Aquatuning will do an advance RMA so unless there's something I can do to fix it I will need to try and return for a refund so I can buy another pump elsewhere first, otherwise I will be without my PC for however long it takes them to replace it.
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #2 of 25 (permalink) Old 03-11-2019, 01:01 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Did you take the pump apart and check the impeller for anything in it? Might want to do that before going RMA. I’ve only had one D5 make noise and it was right after fully bleeding a system and then running it at close to full speed. Never found anything wrong inside and it was replaced by EK.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #3 of 25 (permalink) Old 03-11-2019, 01:18 AM
SoMBrA's Avatar
Rep: 2 (Unique: 2)
Check impeller as suggested. Use some specific product to clean it and should be fine!
Sent from my SM-G955F using Tapatalk
SoMBrA is offline
post #4 of 25 (permalink) Old 03-11-2019, 01:34 AM - Thread Starter
Zammin's Avatar
I haven't pulled it from the system yet, but I did check it before installing it. While bleeding and testing the system I had an inline filter installed. However this noise only began a few weeks after the final assembly.
When I take it out I'll check it for debris again.
Zammin is offline
post #5 of 25 (permalink) Old 03-11-2019, 01:45 AM
SoMBrA's Avatar
Rep: 2 (Unique: 2)
I would recommend getting rid of the filters. Gave me a lot of problems with flow
SoMBrA is offline
post #6 of 25 (permalink) Old 03-11-2019, 03:28 AM - Thread Starter
Zammin's Avatar
Thanks, yeah it was only during the test period. No filter now.
Zammin is offline
post #7 of 25 (permalink) Old 03-11-2019, 11:33 AM
Overclocker in training
ThrashZone's Avatar
Rep: 181 (Unique: 108)
Hi,
Only time I've notice sound from my pump is if there was a clog.
I use filters they catch what I don't want my cpu/ gpu blocks to catch
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
10900k batch # X016E724
z490 ASUS Maximus XII Apex
EVGA 1080ti FTW3
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
ThrashZone is offline
post #8 of 25 (permalink) Old 03-11-2019, 11:36 AM
go4life's Avatar
Rep: 588 (Unique: 418)
Recommend a better fluid in that case.. Also the Alphacool and AquaComputer VPP/D5/Other series are certainly not copies.
From the cold North
|i9 9940X @ 4.6ghz 1.22v|
|MSI X299 PRO|
|MSI RTX 2080 Ti Duke @ 2ghz/8200mhz|
|4x4gb Corsair Vengeance @ 4000mhz CL17-20-20-35 1T|
|1tb Samsung 970 Pro M.2| |2tb Intel 660p M.2|
|Corsair AX1600i|
|EK Velocity| |HWLabs Black Ice Nemesis 420 + 280| |EK-D5 PWM G2|
|LD PC-V7|
Operating System
|Custom Windows 10 Enterprise x64|
|Acer Predator X34P 3440x1440 @120hz IPS|
Keyboard
|Logitech G613|
Mouse
|Logitech G Pro|
Audio
|JBL L890| |2x Advance Acoustic MAA-705 mono amps| |Emotiva XDA-2 DAC receiver|
go4life is offline
post #9 of 25 (permalink) Old 03-11-2019, 12:25 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
The Alphacool VPP755 is ABSOLUTELY a D5 "compatible" knockoff, with an absolutely horrific service record and is what @Zammin was referring to - https://www.overclock.net/forum/61-w...-problems.html
ciarlatano is offline
post #10 of 25 (permalink) Old 03-11-2019, 01:59 PM
cloppy007's Avatar
Rep: 77 (Unique: 53)
I wouldn't rule out electrical noise yet, but, as others have said... check the impeller. It should be pristine even if it's 2 weeks old; mine is 4yo and still is. Besides that, are you sure it's not a coupling/vibration issue?
Current
Holiday rig
(8 items)
3Dfx
Intel Core i7 5820k
Asus X99-S
MSI Radeon R9 280X Gaming
Avexir DDR4-2400 C16 16GB(4x4) Platinum
Samsun SSD 850 EVO
Hitach HDT721010
Antec TP 550 New
EK Supremacy Clear CSQ
Alphacool XT45 360+240
EK-VGA Supreme HF
Swiftech MCP655-PWM
NZXT Switch 810
Dell S2340L
Intel Core i5 2500k
Gigabyte GA-Z68AP
Sapphire Radeon HD 6850
8GiB Samsung DDR3 green
Seagate 7200.11 1TB
Corsair 550W
Themalright ultra 120 eXtreme
CM Haf 912
Athlon XP 1900+
MSI KT3 Ultra ARU
3Dfx VooDoo 5 5500 AGP
512 MiB
Samsung 80GB
Optical Drive
(no name)
Enermax 350W
(no name)
Operating System
(no name)
(no name)
Keyboard
(no name)
Mouse
(no name)
Mouse
(no name)
cloppy007 is offline
