Does your Norprene tubing do this to copper blocks? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 19 (permalink) Old 03-19-2019, 06:07 AM
News Fiend
ryan92084's Avatar
Just looks like oxidation with maybe some particulate cruddy bumps to me. Its just water+copper+time no norprene or kill coil required. Heat will speed it up and a corrosion inhibitor will slow it down but run a loop long enough (especially if you don't flush) and it'll happen. Honestly the layer of oxidation will have a negligible effect on performance while the same cannot be said about some inhibitors so just run with it.
The people who panic over this sort of thing would drop dead if I showed the inside of my old d-tek fuzion gpu. That thing is almost vanta black inside after being in use for 10+ years and its never seen a kill coil.
Quote: Originally Posted by skupples View Post
kill coils are BAD. IDK why they're still being manufactured & sold.
I wish we could go back & clean up all the bad info in these easy to find first time watercooler guides that're a decade old at this point.
There is nothing to clean up. They do their job simply and well.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #12 of 19 (permalink) Old 03-19-2019, 07:31 AM
Alex132's Avatar
Rep: 337 (Unique: 272)
I've never had good luck with them, they seem to do nothing at all.
| This Cannot Continue | We Are Become As Gods | This Cannot Continue |
Vehicles:
Current: None.
Ex: '07 Fiat Palio, '07 Honda Accord Type-S
Illya
(26 items)
Yuki
(23 items)
Intel i9 9900K @ 5.2Ghz
Gigabyte Aorus Master
EVGA 1080 Ti FTW3
G.Skill Trident Z 32GB 4000Mhz
Samsung 970 Pro 512GB
Samsung 850 Evo 1TB
WD Red 8TB
Seasonic Prime Titanium 850W
EK Velocity CPU Block
EK 1080 Ti FTW3 GPU Block
HardwareLabs GTX420
HardwareLabs GTS280
HardwareLabs GTS140
EK D5 140 Glass Pump/res
Phanteks Evolv X
Operating System
Windows 10 Pro
Asus ROG Swift PG279Q 165Hz 1440p
I-INC 1920x1200 TN 27"
Keyboard
Ducky One 2 Midnight
Mouse
Logitech G502
Mousepad
CoolerMaster Swift-RX XL
Audio
Sennhesier HD650
Audio
Schiit Jotunheim Amp/DAC
Audio
Samson C01U Microphone
Audio
Edifier R1700BT
Other
Oculus Rift
Intel 2500K 5Ghz
ASUS P8P67 Pro
EVGA 1080 Ti FTW3
G.Skill RipJaws X 2133Mhz 16GB
120GB Corsair Neutron GTX
Samsung 850 Evo 1TB
WD Red 8TB
EVGA G3 850W
Hyper 212
EK Vardar fans
Corsair 270R w/TG mod
Operating System
Windows 10
I-Inc 1200p
Keyboard
Razer BlackWidow 2013
Mouse
Logitech G502 Proteus Spectrum
Mousepad
Audio
Sennheiser HD650
Audio
Schiit Jotunheim Balanced DAC + Amp
Audio
Edifier R1700BT Speakers
Audio
Other
Oculus Rift
Other
PS4 Controller
Alex132 is offline
post #13 of 19 (permalink) Old 03-19-2019, 07:41 AM
skupples's Avatar
Rep: 526 (Unique: 297)
seen many many people use just silver & get awesome biotic messes.
also, if i remember correctly. They can help accelerate your water's ph, specially when using nickel... It's been a few years, I'll see if I can find the data.
They're worse than worthless, as by doing nothing (at best) they're destructive.
skupples is offline
post #14 of 19 (permalink) Old 03-19-2019, 02:27 PM
sok0's Avatar
Rep: 4 (Unique: 4)
Every copper block ive ever had looked somewhat similar to that no matter what coolant / coil / etc after a year or 2. Its normal and has almost no effect on cooling.
sok0 is offline
post #15 of 19 (permalink) Old 03-19-2019, 03:30 PM - Thread Starter
Retired Staff
animal0307's Avatar
Rep: 116 (Unique: 103)
Cool. That's what my limited research was yielding as well. Since there are no chunks and its all superficial surface corrosion I'm not going to worry about. I used to fold on my GPU as well. It went for about 2 years straight so the "extreme" oxidation from extra heat and 3 years of neglect would make sense.
I personally have never had a bio-mess, though I have never tried using anything other than silver and DI H2O. I have had bits of detritus and lint from poor loop cleaning/flushing and some surface oxidation apparently. Also couldn't say I ever tested the pH levels.
I have avoided nickle plated blocks because of the nasty flaking issues a few years back. I saw zero need to add extra bling and risk to my loops since I'm water cool for the performance/reduced fan noise.
If you find any of that data that would be awesome to share.
Glad to see there are others that have the same experience with raw copper as I do. I hadn't noticed any appreciable change in the performance of the loop though I never kept records of what it was like new so I can't say if i had or not.
Given the general consensus is that it's likely not the Norprene but rather the use of silver vs regular oxidation I will make a note in the original post.
Last edited by animal0307; 03-19-2019 at 03:42 PM. Reason: oxide vs corrosion usage
animal0307 is offline
post #16 of 19 (permalink) Old 03-19-2019, 03:52 PM
Cloudforever's Avatar
Rep: 60 (Unique: 46)
time to shill for mayhems.
no silver, just biocide+and inhibitor+ and you'll have the cleanest system you've ever experienced.
I have 2 kill coils in my water loop (using distilled water) for 1 year so far and it's just as clear as it was from day one?
maybe you mean if you use liquids other than water, they are bad? I would have to agree with that
Cloudforever is offline
post #17 of 19 (permalink) Old 03-19-2019, 04:10 PM
Umm, How Bout Noooooo.
Cyber Locc's Avatar
Rep: 113 (Unique: 78)
Quote: Originally Posted by broodro0ster View Post
Yea, silver coil isn't very good anymore and speeds up corrosion. It's good for algea, but not for corrosion.
Everybody should stop using kills coils and use a fluid with biocide and corrorion inhibitor included. Something like Mayhems Biocide+ mixed with Inhibitor+ is perfect.
Its funny to see this, I been trying to tell people this for YEARS! And am still thoroughly upset, that my copper ray storm looks like this due to monsoon changing their fittings to Silver, and after 3 months of using the extra 4 I added to the loop, my Raystorm also looked like that.
You are giving me the impression that is what is commonly said around here which is funny all the hours, and threads I spent fighting that here .
Nope, with just water, 4 Monsoon fittings did that to my copper raystorm in a couple of months. the issue is not Copper + Silver, its Copper + Silver + Nickel.
Even then, like Ryan said, its going to happen with copper period. However Copper+Silver+Nickel speeds up the process.
Favorite OCN Quotes (Click to show)
You are just talking more and more nonsense now. It's time to take this back to whatever noob forum it came from.
____________________________________________________________________________________________________________________
Cyber Locc is offline
post #18 of 19 (permalink) Old 03-19-2019, 05:28 PM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
ok, so you where upset because nobody would agree with you years ago about this issue. now that people have educated themselves, and more evidence of this is available. now, you are still upset, because people today actually agree with the message, that you have finally got across to others. IMO their is no pleasing you, because it seems that no matter what happens, you will find a reason to be upset about it.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #19 of 19 (permalink) Old 03-19-2019, 07:48 PM
Cyber Locc's Avatar
Ahh my friend toolmaker, its been a long time . Its been too long .
Quote: Originally Posted by toolmaker03 View Post
Qok, so you where upset because nobody would agree with you years ago about this issue.
Not really upset was a figuring of speech, you know sarcasm and joking do not translate well on the net, so understandable. I did spend a lot of time arguing that very point, with users and Manufactures however . However I hold Zero grudges with anyone, here or anywhere .
I'm not upset people have found more evidence and learning about it, at all. I am very happy, and sorry for those that had to learn the hard way to make this info apparent .
On another note, how did your parallel loop go? Do you have an updated thread for me to check out?
