Does your Norprene tubing do this to copper blocks? - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 03-11-2019, 10:24 PM - Thread Starter
Retired Staff
animal0307's Avatar
Rep: 116 (Unique: 103)
EDIT:
After some back and forth I am going to say that it's likely NOT the Norprene tubing that has broke down in anyway but rather what I am seeing is an "extreme" case of oxidized copper. While visually unsettling it is not detrimental to the performance of the loop and completely normal.
There is disagreement as to whether this corrosion is normal or caused by my use of a silver kill coil and DI water vs a corrosion inhibitor/bio-cide solution for coolant.
My take: I prefer the KISS Method and don't trust cure-all solutions. So I will continue to keep using copper only blocks with DI water and silver and just deal with the visual issue of the oxide layer.
ORIGINAL POST:
Broke down my for the first time in 3 years. Yupp it's been that long. My system sits under my desk and gets ignored. So don't let anyone tell you watercooling is high maintenance.
I've been using Norprene tubing with DI water the whole time and top of the loop maybe once a year. I have a small loop thick 120 rad, CPU and GPU blocks and custom res in an it's case so there never was much fluid to begin with.
This isn't the first time I have noticed this black staining on a cpu block while using Norprene tubing. I'm not really concerned about it since I'm going back to air cooling for the foreseeable future. I will likely just put it all back together staining and all when/if I go back to water again.
Loop has only had copper, stainless and chromed brass barbs and a silver kill coil in it. Hoses are probably 4-5 years old. It just as soft as the day I bought it and the only sign if age is the dirt layer on it.
I only ask because I'm curious if anyone else has had this experience. I vaguely remember it being a concerned that Norprene might leech color over time but it doesn't appear to leech plasticizer or break down like other tubing is known for doing.
Last edited by animal0307; 03-19-2019 at 03:40 PM. Reason: Updating the OP with the "solution"
animal0307 is offline
post #2 of 19 (permalink) Old 03-13-2019, 04:06 PM
broodro0ster's Avatar
Rep: 2 (Unique: 2)
I don't think so. I used EK Neoprene tubing for a long time and never saw this. Is probably just corrosion. Rub some ketchup over the pins and let it sit for 5 minutes. Then go over it with a toothbrush. Repeat if needed and the rinse it of very well with water and a toothbrush before you assemble it again. I should be close to new after the ketchup treatment :-)
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #3 of 19 (permalink) Old 03-13-2019, 04:22 PM
Alex132's Avatar
Rep: 337 (Unique: 272)
This guy seemingly had the exact same loop components and issue as you:
http://www.xtremesystems.org/forums/...=1#post4830427
I wonder if it's the silver kill coil messing with stuff?
| This Cannot Continue | We Are Become As Gods | This Cannot Continue |
Vehicles:
Current: None.
Ex: '07 Fiat Palio, '07 Honda Accord Type-S
Illya
(26 items)
Yuki
(23 items)
Intel i9 9900K @ 5.2Ghz
Gigabyte Aorus Master
EVGA 1080 Ti FTW3
G.Skill Trident Z 32GB 4000Mhz
Samsung 970 Pro 512GB
Samsung 850 Evo 1TB
WD Red 8TB
Seasonic Prime Titanium 850W
EK Velocity CPU Block
EK 1080 Ti FTW3 GPU Block
HardwareLabs GTX420
HardwareLabs GTS280
HardwareLabs GTS140
EK D5 140 Glass Pump/res
Phanteks Evolv X
Operating System
Windows 10 Pro
Asus ROG Swift PG279Q 165Hz 1440p
I-INC 1920x1200 TN 27"
Keyboard
Ducky One 2 Midnight
Mouse
Logitech G502
Mousepad
CoolerMaster Swift-RX XL
Audio
Sennhesier HD650
Audio
Schiit Jotunheim Amp/DAC
Audio
Samson C01U Microphone
Audio
Edifier R1700BT
Other
Oculus Rift
Intel 2500K 5Ghz
ASUS P8P67 Pro
EVGA 1080 Ti FTW3
G.Skill RipJaws X 2133Mhz 16GB
120GB Corsair Neutron GTX
Samsung 850 Evo 1TB
WD Red 8TB
EVGA G3 850W
Hyper 212
EK Vardar fans
Corsair 270R w/TG mod
Operating System
Windows 10
I-Inc 1200p
Keyboard
Razer BlackWidow 2013
Mouse
Logitech G502 Proteus Spectrum
Mousepad
Audio
Sennheiser HD650
Audio
Schiit Jotunheim Balanced DAC + Amp
Audio
Edifier R1700BT Speakers
Audio
Other
Oculus Rift
Other
PS4 Controller
Alex132 is offline
post #4 of 19 (permalink) Old 03-14-2019, 05:53 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
I have been using norprene now for 7 years on all my builds and I have not seen this issue.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #5 of 19 (permalink) Old 03-14-2019, 06:01 AM
Rep: 2 (Unique: 2)
Yea, silver coil isn't very good anymore and speeds up corrosion. It's good for algea, but not for corrosion.
Everybody should stop using kills coils and use a fluid with biocide and corrorion inhibitor included. Something like Mayhems Biocide+ mixed with Inhibitor+ is perfect.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #6 of 19 (permalink) Old 03-14-2019, 06:32 AM
skupples's Avatar
Rep: 525 (Unique: 296)
kill coils are BAD. IDK why they're still being manufactured & sold.
I wish we could go back & clean up all the bad info in these easy to find first time watercooler guides that're a decade old at this point.
time to shill for mayhems.
no silver, just biocide+and inhibitor+ and you'll have the cleanest system you've ever experienced.
skupples is offline
post #7 of 19 (permalink) Old 03-15-2019, 06:10 PM
Ashcroft's Avatar
Rep: 80 (Unique: 63)
Looks to be just copper oxidation. It should clean up to look as new pretty easily, though the darkened copper does not impact the cooling.
Ashcroft is offline
post #8 of 19 (permalink) Old 03-16-2019, 06:11 PM - Thread Starter
Retired Staff
animal0307's Avatar
I think that is about old my tubing is. Honestly I have noticed this before on a different CPU block prior but just assumed it was normal oxidation because it came clean.
I haven't heard about this one yet. Anyone have some articles/studies about this?
My understanding is that silver is inert and is used as anti microbial. I have always been wary solutions that claim to solve all. I'll be the first to admit that I'm no chemist so I completely acknowledge that there is way more science than black magic. KISS has been my method of choice which is why I've been using silver and DI water with only copper in my loops.
https://www.watertechonline.com/effe...lver-in-water/
I have had this happen to a different CPU block before and it was the same black layer. It did clean up from the other block so I wasn't too concerned this time. I've just used a bit of vinegar and a tooth brush to clean it.
If the layer of oxidation is normal and is only a cosmetic issue then I won't sweat the problem.
Here is a picture of the GPU block that was in the same loop. It's been in use for 4-5 years with the same tubing, Silver and DI water(not the same water) without ever being cleaned. I would just attribute different rates of corrosion to due to different grades of copper used in the block.
post #9 of 19 (permalink) Old 03-16-2019, 07:53 PM
Meow!
djriful's Avatar
Rep: 242 (Unique: 204)
I would avoid Silver Kill Coil to be honest, just get Dazmode Protector and Distill water. Mix and forget - lasted me 2 years in the loop and it is still clean as ever. EK blocks + EK Norprene tubing.
~ Nothing to see here ~
djriful is offline
post #10 of 19 (permalink) Old 03-16-2019, 08:28 PM
Alex132's Avatar
A bit off topic, but where did you get your distilled water from? I've gotten mine from Shoppers and it turned two different batches of my Primochill clear PRT adv tubing a hazy white within less than a week. Ended up buying Cryofuel and some more tubing, with EK ZMT tubing just in-case, because of it.
Vehicles:
Current: None.
Illya
(26 items)
Yuki
(23 items)
EVGA 1080 Ti FTW3
Samsung 850 Evo 1TB
WD Red 8TB
HardwareLabs GTX420
HardwareLabs GTS280
HardwareLabs GTS140
Phanteks Evolv X
Operating System
Windows 10 Pro
Keyboard
Mouse
Logitech G502
Mousepad
Audio
Sennhesier HD650
Audio
Audio
Audio
Edifier R1700BT
Other
Oculus Rift
Intel 2500K 5Ghz
ASUS P8P67 Pro
EVGA 1080 Ti FTW3
Samsung 850 Evo 1TB
WD Red 8TB
EVGA G3 850W
Hyper 212
EK Vardar fans
Operating System
Windows 10
I-Inc 1200p
Keyboard
Mouse
Mousepad
Audio
Sennheiser HD650
Audio
Audio
Audio
Other
Oculus Rift
Other
PS4 Controller
Alex132 is offline
