Could some help me out with thermal pad placement on Vega 64? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Unread 03-15-2019, 05:50 AM - Thread Starter
Goooober's Avatar
Rep: 0
I have a reference Vega 64 and a Bykski water block and i'm not 100% sure if i'm meant to put thermal pads in certain places.
The instructions can be found here but the pictures they use dont match up perfectly with the reference PCB.
Here's what i've done so far.
I'm not sure if i'm mean to put pads on the components i've highlighted in red. On the right hand side you can see i've put three strips of pads, one of them covers the same things as those highlighted in red. Again, i'm not sure if that's correct.
The instructions for the EK block would suggest that I should cover the things in red but the instructions for the Watercool Heatkiller would suggest they you dont.
My concern is that if i put pads on things that shouldn't have them the block would fit properly.
This is the first time i've ever tried fitting a water block so i guess i'm being overly cautious.
Thanks
Goooober is offline
post #2 of 3 (permalink) Unread 03-18-2019, 03:02 PM
Iconoclast
Blameless's Avatar
Rep: 3131 (Unique: 1869)
The components you have circled are surface mount capacitors and do not need to make contact with the heatsink/block.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Haswell-E
(15 items)
Broadwell-E
(11 items)
Westmere
5820K @ 4.25/4.125GHz core/uncore, 1.21/1.2v
Gigabyte X99 SOC Champion (F23c + updated microcode)
Gigabyte AORUS GTX 1080 Ti (F3P) @ 2025/1485(5940), 1.031v
4x4GiB Crucial @ 2667, 12-11-12-26-T1, 1.39v
Plextor M6e 128GB (fw 1.06) M.2 (PCI-E 2.0 2x)
2x Crucial M4 256GB
4x WD Scorpio Black 500GB
Seasonic Focus Plus 850 Platinum (SSR-850PX)
Noctua NH-D15S + 2x Thermalright TY-143
Corsair Carbide Air 540
Operating System
Windows 7 Professional x64 SP1
BenQ BL3200PT
Keyboard
Filco Majestouch Tenkeyless (MX Brown)
Mouse
Logitech G402
Audio
Realtek ALC1150 + M-Audio AV40
i7-6800K @ 4.2(4.1)/3.4GHz core(AVX)/uncore, 1.345/1.15v
ASRock X99 OC Formula (P3.40)
MSI GTX 1080 Ti Duke OC @ 1950/1485MHz, 1.043v
4x4GiB Crucial DDR4-2400 @ 11-13-12-28-T2, 1.33v
Intel 600p 256GB NVMe
2x HGST Travelstar 7k1000 1TB
Corsair RM1000x
Thermalright True Spirit 140 Direct + TY-143
Fractal Design Define R4
Operating System
Windows Server 2016 Datacenter
Audio
ASUS Xonar DX
X5670 @ 4.3/3.7GHz core/uncore, 1.36 vcore, 1.35 qpi/vtt
Gigabyte X58A-UD5 r2.0 w/FF3mod10 BIOS
Sapphire Fury Nitro OC+ @ 1080/545, 1.275vGPU/1.394vHBM
2x Samsung MV-3V4G3D/US @ 2050, 10-11-11-30-T1, 1.52v
1x Crucial BLT4G3D1608ET3LX0 @ 2050, 10-11-11-30-T1, 1.52v
OCZ (Toshiba) Trion 150 120GB
Hyundai Sapphire 120GB
3x Hitachi Deskstar 7k1000.C 1TB
Seasonic SS-860XP2
Noctua NH-D14
Fractal Design Define R5
Operating System
Windows 7 Pro x64 SP1
Audio
ASUS Xonar DS
Blameless is offline
post #3 of 3 (permalink) Unread 03-18-2019, 03:11 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 580 (Unique: 485)
Those don't need pads. Copy the pad pattern visible when you first removed the heat sink and fan from the board. If you can no longer copy that go to You Tube and view the many disassembly videos and see where the pads go.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ 1160GHz Core/1350GHz Mem
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Open Water Loop
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Nixeus EDG 27" Freesync 1440p 144Hz
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Microsoft Sidewinder X5
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Intel Core i5-3570K @ 4.5GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990
G.SKILL Ripjaws X DDR3 8GB 1600MHz
Crucial SSD 128GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Corsair Vengeance MM200
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
AMD Athlon II X4 640
ASRock N68C-GS
NVIDIA 6600GT
G. Skill Ripjaws DDR3 1600MHz
WD Caviar Blue 500GB 16MB Cache 7200RPM
Optical Drive
LG Optical Drive
Thermaltake TR2 600W
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Viewsonic 19” Flatscreen CRT
Keyboard
Gigabyte GK-K6800 103
Mouse
Zalman ZM-M300
Mouse
Gunderman456 is offline
