Noob here, Pump Speed and temps - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 03-18-2019, 06:52 AM - Thread Starter
Rep: 0
Hi, Im new to watercooling and have just finished my first water cooling build.
Its in a Phanteks Evolv Shift and I have a few questions
What pump speed should i be running? Im running a D5 pump and right now I set the pump to run at 2600RPM. Searched online and alot says the pump speed does not matter but just wanna make sure.
And also here is what my temps look like
Idle: CPU 39c GPU 36c
Heaven benchmark: GPU 63c
Cinebench: CPU 71c
I am quite satisfied with the GPU temp but it seems my CPU is still running hot. But i have to say there is an improvement than before it was watercooled. it usually reached around 80+. I thought by reading usually the temps would be down to around 50ish if u go watercooling? Just want to ask if my temps looks ok or am i doing something wrong.
Btw here are my specs:
i7 9700k
gigabyte rtx 2080ti
asus z390i gaming
phanteks evolv shift case
watercooling parts are mostly byksi stuff
Radiators are 2 120 rads
fans are set to 1000rpm
temps inside the case is around 36ish
Thanks for any feedback.
mrsarden is offline
post #2 of 14 (permalink) Old 03-18-2019, 06:59 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Run the pump at higher speed and see if the temps come down more. If so, then you need to increase it.
Also, two 120 rads is a bit under for a 9700K and 2080ti. Single 360 or add a 240 for a 120 IMO
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #3 of 14 (permalink) Old 03-18-2019, 07:01 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 736 (Unique: 388)
do you have a flow sensor?
if not, start on the lowest setting, benchmark, note temps
repeat on consecutive settings until you see no gain from increased flow.
It tapers off pretty quickly, but I don't remember the target folks say to go for.
I'm only getting 120LPH outta 2x DDC running full tilt =\\
the min is like .5 GPM *(what I get with a 4 radiators, 3 blocks, and two PWM DDC)
Add me on Steam, same name
skupples is offline
post #4 of 14 (permalink) Old 03-18-2019, 07:07 AM - Thread Starter
Rep: 0
Yeah thats what Im scared of with the rads but with this case 2 120 rads the max. will try to run the pump faster but I noticed if the pump is too fast there will be alot of bubbles in the tubings. is this fine? or should I avoid this?
Unfortunately I dont have a flow sensor. So 1GPM is what i should go for? any idea how do i calculate if i dont have a flow sensor? Thanks
mrsarden is offline
post #5 of 14 (permalink) Old 03-18-2019, 07:26 AM
ezveedub's Avatar
You will get bubbles if the flow rate is too fast for the reservoir to allow them to bleed out and they get reintroduced in the flow. Add foam to the bottom of the reservoir or offset return will prevent this.
i9 9900K
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #6 of 14 (permalink) Old 03-18-2019, 07:26 AM
Vermin Supreme 2020
skupples's Avatar
as stated, if you don't have a flow meter, then just use a staggered approach.
Start on the lowest speed, running all your blocks as hot as possible, take temps
bump up to the next speed, test, take temps,
etc
compare, win.
flow & pump are one of those HIGHLY oversold things here on OCN, kinda like PSUs, but worse.
More flow means almost nothing above .5, and literally nothing above 1.0. & the difference between the two are within the couple degrees at most.
skupples is offline
post #7 of 14 (permalink) Old 03-18-2019, 07:46 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
etc
compare, win.
Great advice. There are a lot of tests showing that performance shows little increase over 0.5 gpm. But, by the same token, can fall off dramatically below in may loops. Using the method you recommend should find that point pretty easily and effectively.
ciarlatano is offline
post #8 of 14 (permalink) Old 03-18-2019, 07:52 AM - Thread Starter
Rep: 0
etc
compare, win.
thanks. will try and report back.
mrsarden is offline
post #9 of 14 (permalink) Old 03-18-2019, 07:58 AM
Vermin Supreme 2020
skupples's Avatar
any time.
Remember to let the benches run long enough to get a good reading. Nothing crazy, maybe a few loops.
skupples is offline
post #10 of 14 (permalink) Old 03-19-2019, 08:13 AM
NewType88's Avatar
Rep: 5 (Unique: 3)
When I'm stress testing and adjusting flow in real time, I noticed temps changes immediately. I get a 4 degree difference between 1800RPM and full speed. At some point there is a diminishing return on pump speed, but I haven't seeked what that RPM is for me yet.
NewType88 is offline
