Twin pumps strong enough? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 03-19-2019, 04:14 PM - Thread Starter
Rep: 0
So I have the Alphacool Eisbaer and the Eiswolf GPX Pro M02 for my 2080 Ti hooked together currently and they work just fine. However, I want to add a reservoir and another radiator which would total in: 1x 420mm / 30mm radiator, 1x 240mm / 30mm radiator, 1x 140 / 86mm (sic) radiator, the 250x50mm reservoir and ofcourse the gpu block... Will the Eisbaer and Eiswolf pumps be enough to push water efficiently through this? I'm pretty new to watercooling so I want to make sure it actually works.
The Eisbaer pump has the following specs:
  • Speed: 2600 RPM
  • Voltage: 7-13.5V DC
  • Power consumption: 4W
  • Maximum flow rate: 70L/h
  • Maximum head: 0.85m
The Eiswolf pump I couldn't find any specs on but its speed is 2200-2300 RPM peak and I gather it does a decent job. I suppose my main worry is that fat 140mm x 86mm Monsta radiator since it's a massive radiator.
Intel Core i7-6700K
ASUS ROG Maximus IX Hero
Palit GeForce RTX 2080 Ti Dual
Kingston HyperX Fury 32 GB @ 3200 MHz, CL15, 1.35 V
Samsung 850 EVO-Series 500 GB 2.5" SSD
Western Digital Caviar Green 1 TB 3.5" 5400RPM
Western Digital Red 3 TB 3.5" 5400RPM
Optical Drive
Asus DRW-24F1MT DVD/CD Writer
EVGA SuperNOVA G2 750 W 80+ Gold Certified Fully-Modular ATX
Alphacool Eisbaer 420mm AIO CPU kit
be quiet! Pure Wings 2 140 61.2 CFM 140mm
Fractal Design GP14-WT 68.4 CFM 140mm
Noctua NF-A14 iPPC
Noctua NF-A14 iPPC
Noctua NF-A14 iPPC
Fractal Design Define R5 (Black) ATX Mid Tower
Operating System
Windows 10 Pro 64-bit
Acer Nitro XV273K 4K IPS 144 Hz HDR400 10-Bit
Keyboard
Ducky One Blue LED MX Black
Mouse
Razer DeathAdder Elite Wired Optical
Mousepad
Razer Vespula
Audio
Native Instruments Komplete Audio 6 (USB Sound Interface)
Audio
M-Audio BX8 D2
Audio
Audio-Technica ATH-R70X
Audio
MXL 990
Other
FREDDE Desk (IKEA)
Lashmush is offline
post #2 of 14 (permalink) Old 03-20-2019, 05:20 PM
dwolvin's Avatar
Rep: 7 (Unique: 7)
Just personal experience but... Radiators don't add any real restriction so I'd think you should be fine. My original pump (EK in house pump) ran through CPU / GPU / 240 / 120 / 140 and still had good flow (both blocks were low restriction. Your Eisbaer should be fine on it's own, but a pair for redundancy (in series) can't hurt if it makes you feel safer.
dwolvin is offline
post #3 of 14 (permalink) Old 03-21-2019, 12:09 AM - Thread Starter
Rep: 0
Ok, thanks!
Intel Core i7-6700K
Optical Drive
Noctua NF-A14 iPPC
Noctua NF-A14 iPPC
Noctua NF-A14 iPPC
Operating System
Keyboard
Mouse
Mousepad
Razer Vespula
Audio
Audio
M-Audio BX8 D2
Audio
Audio
MXL 990
Other
FREDDE Desk (IKEA)
Lashmush is offline
post #4 of 14 (permalink) Old 03-30-2019, 07:04 PM
padman's Avatar
Rep: 1 (Unique: 1)
Nemesis GTS rads would like to have a word with you
padman is offline
post #5 of 14 (permalink) Old 03-30-2019, 09:00 PM
Umm, How Bout Noooooo.
Cyber Locc's Avatar
Rep: 114 (Unique: 79)
Ehh even then, a standard Rad is about a .5psi drop, so it would take 2 to equal 1 gpu block. A HWlabs, and a lot of the German Companies, have like .75ish, its only a tad more.
That said, those are AIO level pumps, as that is what they are, expandable AIOs. I wouldn't use those, I would if you can send them back and just get regular blocks and a Pump. You could easily get a good cpu block, gpu block and a d5 for that same price. You are paying the price of a d5 + Blocks, for AIO level bound to fail, junk, and Alphacools other pumps are prone to failure and issues, like their Spin on the d5.
even better, if you dont mind the Chinese stuff, and dont mind waiting, you could get a GPU block, CPU block and a proper D5, for the price of the GPU block alone. However even from more established brands, you can get a D5, CPU and GPU block, for about what you paid.
As to the Chinese, its pretty risky, however with my experience, OCool, isnt the best quality stuff either, actually the barrow stuff I have is better quality than the OCool.
Not to mention, the GPU blocks would be actual GPU blocks, not some hybrid AIO crap. Your getting AIO performance for Custom loop pricing, its a Raw Deal and a stupid product that shouldnt even exist. Which is exactly what ran Phoyba (owned by Ocool) out of business, and Ocool is next.
Favorite OCN Quotes (Click to show)
You are just talking more and more nonsense now. It's time to take this back to whatever noob forum it came from.
____________________________________________________________________________________________________________________
Cyber Locc is offline
post #6 of 14 (permalink) Old 03-30-2019, 09:04 PM
badtaylorx's Avatar
Rep: 46 (Unique: 43)
yeah, it'll be just fine. I believe they both use the same motor to drive the pumps. so..... However, if they both use PWM 4pin leads try to keep the RPMs somewhat close.
I would also keep the 2 pumps in line together if possible. Res-gpu-cpu-rad-rad-res-gpu.....(forget the 140. not worth the hassle)
Modified Tt P5 chassis | RYZEN 2700X 4.4 all-core| AsRock X370 Taichi | Corsair 3200cl14 RAM | Radeon VII | 3x500gb SSD | EVGA P2 1200W psu | custom watercooling, 3xKoolance 360 rads, GT fans, AC cpu block, Koolance universal gpu blocks, 2xDDC swiftech pump, VRM block, 400ml res | Asus Essence One Muses ed. DAC/amp |
badtaylorx is offline
post #7 of 14 (permalink) Old 03-30-2019, 09:27 PM
reaper829's Avatar
Rep: 0
I just got a 420 GTS, and while I don't know what its restriction is, the 360GTS is [email protected], so I would bet that the 420 is at 1.0 or more. It's my most restrictive part in my case.
reaper829 is offline
post #8 of 14 (permalink) Old 03-30-2019, 09:36 PM
Cyber Locc's Avatar
Ehh like I said, its restrictive, but not by not that much.
.91 is not that bad in the grand scheme, Middle restriction CPU blocks are around the same, you also have to remember that a D5 on setting 5 is like 6psi with a good top, 5 without, at 1gpm.
That means you could run, 2/3 of them and CPU and GPU block, 10 feet of tubing, few 90s, thats a pretty standard Mid Range loop, and you still have PSI to spare with a top. However ya the GTS is up there in restriction. However OP also has a Ocool Monsta, which is extremely low restriction.
And like I said, "most the German companies are around .7", which look at the graph. "And the GTS is only a tad more", which again look at the graph
as to the 420, I dont think it would be more restrictive, it may be, however usually a bigger rad, is less restrictive, as there is more room for the water to move. As seen here with the 480 GTS, which is only .8, that however isnt always the case.
post #9 of 14 (permalink) Old 03-31-2019, 08:03 AM
Overclocker in training
ThrashZone's Avatar
Rep: 127 (Unique: 83)
Hi,
Deja vu
https://www.overclock.net/forum/61-w...t-my-loop.html
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #10 of 14 (permalink) Old 04-01-2019, 06:32 AM
toolmaker03's Avatar
Rep: 92 (Unique: 70)
yea, this is why I hate charts, yea they can be cool to use but only if the person using them understands how this information translates. personally I tested all my hardware individually with a simple water loop consisting of the component being tested and a flow meter. at this point I can say that the chart does translate for me but does it for most people. I think what needs to start happening is that those with the hard ware should start posting how their hardware functions with the pumps they have. it is not like we don't do this kind of testing already. we just need to start posting our results.
as for my own hardware labs GTX it is restrictive, with a single D5 full power the flow rate on a simple water loop is 4.6LPM this is the most restrictive radiator I own. my swiftech QP has a flow rate of 5.9LPM and it is only 35mm thick compared to the HWL at 54mm thick. so thickness does not always equate to a higher flow rate, it really is all about the design of the radiator itself.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
