Got my feet wet; looking for advise on future loop expansion. - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 03-19-2019, 11:04 PM - Thread Starter
Just a random internet
Decade's Avatar
Rep: 59 (Unique: 52)
Been a long time since I've signed into the OCN, but I need y'all's expertise on improving my loop for a future expansion to a 360x40 rad.
Waiting on Primochill to stock the candy purple 360x40s before purchasing an additional rad and install my Heatkiller Pro IV and complete my setup. Cooled the GPU first because EVGA hybrid pumps are way too noisy.
Really enjoyed the challenge of building and have already done two fills and a drain (just distilled w/ primochill sysprep) thanks to poorly seating my GPU block the first go around. Meshify S2 helped in just being a heck of a sweet case as well as binge watching JayzTwoCents videos.
Would appreciate constructive feedback on better tubing runs and radiator placement suggestions for both the 240x40 in the pic and the 360x40 that is incoming. (EG: 360x40 have fittings at the back of case for a short run from the GPU to the CPU)
Water cooling parts used:
Primochill CTR res + D5 PWM pump (works great with NZXT cam, going to be using a Grid V3 when I dump the X52 for a 360 rad)
Primochill 240x40 rad
EVGA Hydro Copper block -- original card is a 2080 Ti FTW3 hybrid
Primochill fittings and tubing.
Watercool Heatkiller Pro (not installed currently)
All fans are Noctua NF-12 chromaxs. I love these fans.
For those curious, running Heaven at 1440p DX11, ultra quality, extreme tessellation netted an equilibrium temperature of 68C after 15 mins with +140 core and +1300 memory and running my pump and fans at 100%. Original config of card would hit about 75C, but with A LOT more noise.
Teal'n'purp
(10 items)
i7-9700K
Gigabyte Z390 Aorus Master
EVGA 2080 Ti FTW3
Corsair Vengeance LPX 16gb
Samsung SM951
Crucial P1
Crucial P1
Corsair SF600 Platnium
Custom loop
Viotek GN27D
Decade is offline
post #2 of 12 (permalink) Old 03-20-2019, 07:10 AM
wheatpaste1999's Avatar
Rep: 1 (Unique: 1)
Well, your loop is going to change once you get the other rad and CPU block in there, but based off your setup now I'd get a couple 90 deg rotary fittings and maybe even a couple 45 deg rotary fittings to clean up the tube runs, particularly off the GPU block. Swapping in and out ports on the rad would also allow you to hide the tube that runs from the rad to the reservoir, and untangle the tube from the GPU to the rad from the AIO tubing.
I would also lower the 240 rad, as the position it's in right now isn't doing you any favors for bleeding the loop. I think you'll need to do this anyway to get the 360 rad in the top (assuming that's your plan).
Side note: 68C is very high for a GPU in a custom loop, even a small loop like yours. You sure you got the block seated correctly on the GPU? Do you have a way to monitor water temps?
i9 7900x
(8 items)
i7 7700k
(8 items)
i9 7900x
Asus Rampage VI Extreme
EVGA 1080Ti SC2 2-Way SLI
Corsair Vengence RGB
Corsair AX1600i
Custom Loop
Lian-Li O11-Air/Dynamic
Other
Aquaero 6LT
i7 7700k
Asus Maximus IX Hero
EVGA 1080Ti SC Black
Corsair Dominator Platinum
EVGA 1000G3
Custom Loop
Phanteks P400S
Other
Aquaero 6LT
wheatpaste1999 is offline
post #3 of 12 (permalink) Old 03-20-2019, 07:23 AM
skupples's Avatar
Rep: 521 (Unique: 293)
+1300 memory?
or you mean, +650 = 1300?
skupples is online now
post #4 of 12 (permalink) Old 03-20-2019, 07:29 AM
Overclocker in training
ThrashZone's Avatar
Rep: 46 (Unique: 37)
Hi,
Ideally for draining the front rad would need to be flipped so the in-out ports are on the bottom not the top but I'm sure you've already found out how bad they are on top
I personally am not a fan of rotary fitting they are nothing but an addition leak possibility.
Straight barb compression fitting are just fine.
I would remove the vertical gpu mount and just connect it to the board
Flow
Pump outlet/ front rad/ gpu/ cpu/ top rad/ vrm block/ back to pump inlet.
So yeah add a vrm block it's a good transition from top rad to reservoir
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #5 of 12 (permalink) Old 03-20-2019, 07:38 AM
skupples's Avatar
definitely agree about rotaries.
the only ones I've not have fail over the years are BP or Enzotech. Everthing else? Any amount of pressure on the internal o-ring causes a leak. Yes, even swiftech's super fancy ones.
Now a days I try to use only one rotary piece in a run, it's all that's needed to benefit from them.
post #6 of 12 (permalink) Old 03-20-2019, 09:06 AM
Shawnb99's Avatar
Rep: 13 (Unique: 9)
Now I’m concerned about my rotaries, I have 2 in my loop. One connecting my CPU block to the MB I do Not want that to fail.
Something else I’ll have to rethink when I redo my loop. Both are EK and with my luck with EK gear recently I’m sure it’ll fail on me.
Thanks for the info
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #7 of 12 (permalink) Old 03-20-2019, 09:14 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 378 (Unique: 262)
I've had really good luck with the Monsoon and BP. I haven't tried the Enzotech. I have a had a Swiftech leak after a while, and had two of the five EK I used leak within a couple of months. I try to simply stick with the BP since I have some with 5+ years of continuous service including 5-6 rebuilds, and they seem as solid as the day I bought them.
ciarlatano is offline
post #8 of 12 (permalink) Old 03-20-2019, 09:42 AM - Thread Starter
Decade's Avatar
Quote: Originally Posted by wheatpaste1999 View Post
*Snipped*
Thanks for the reply, wheatpaste! The 240 definitely isn't in its final resting place and will be lowered once I get the 360 for up top, I'm actually surprised how well it bled and found getting enough water in the loop was more difficult with the rad where it was. (Water would backflow into the rad and res on pump power off and the rad-res tube would be empty and the gpu-rad tube half empty) Water temp monitoring is something I need to figure out, infrared temp gauge is much less convenient than checking a screen. Saturating the loop with heat results in the external tube temp being 98F (36.6C) which should put the water temp around the 40C mark.
I'm definitely working on the temps with GPU still, as high as they seem, they're improved over the EVGA AIO solution that was originally on the card.
+1300 memory?
Hi Skupples, I have it set to an additional 1300mhz on memory in Precision X1.
Quote: Originally Posted by ThrashZone View Post
Hi, *snipped*
Thanks ThrashZone! Appreciate the input. That first drain to reseat my gpu block the first time was definitely interesting, but I did get drained what I needed and the rad didn't present an issue. Full drain and I definitely realize why it should be flipped around.
Not sold on the vertical GPU mount 100% myself, but wanted to give it a shot to "fill out" the case. This is my first ATX build in seven years and it just felt... empty. (And why I still run a SFX power supply in an ATX case... Corsair SF600 Platinum)
Attached a screen grab of X1 after 30 mins of playing Far Cry New Dawn for a non-synthetic measurement. I was running fans at ~1100rpm and the pump at 70% PWM which was between 2900 and 3100 rpms. I still think I may need to reseat the block again, but on the otherhand, this can ran 70C with the EVGA pump unit at 100% pwm duty and the same Noctua NF-12 Chromax running at ~1300rpm. (But with MUCH less noise. I can hear my coil whine again!)
Teal'n'purp
(10 items)
i7-9700K
EVGA 2080 Ti FTW3
Samsung SM951
Crucial P1
Crucial P1
Custom loop
Viotek GN27D
Decade is offline
post #9 of 12 (permalink) Old 03-20-2019, 10:11 AM
ThrashZone's Avatar
Hi,
Most want to see that expensive water block that is what vertical mounts are all about
Personally I wouldn't use one as I said before draining is a pain
Besides piping is easier with typical mount with front rad flipped.
One want to hit the cpu first usually because it's the hottest item
With a 2080ti it too will be pretty hot so gpu first then cpu will work great.
Not sure what soft tubing size you ended up with but 3/8-5/8" is ideal for sharp turns eliminating any use of rotary fittings.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #10 of 12 (permalink) Old 03-20-2019, 10:18 AM
skupples's Avatar
this this THIS
YES, we all know BP are stupid expensive, but I still have every BP fitting I've ever purchased, 50/50 rotary, or not. They're all still as tight as the day I bought em. I just replaced all the primary O-rings after 5 years, but that was out of an extreme abundance of caution. Compare this to my throwing away ALL other rotary that aren't enzo male/male rotary, or 90 degree compression fitting rotary.
1300... that's insane... is that a normal memory OC on 20 series? that would be a 2.6ghz bump for a 10 series & below card...
Oh I see, it's a pure 1300mhz bump..
10 series & below, you get 2x what you input, so 650 to get 1300mhz bump.
