Question about radiator placement in the Lian Li PC-O11 Dynamic - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 03-20-2019, 04:03 PM - Thread Starter
Rep: 0
I'm building in an O11 Dynamic and I'd like to have one of these two configurations with two 360mm radiators:
Side mounted radiator intake (push), Top-mounted radiator intake (push)
Side mounted radiator intake (push), Top-mounted radiator exhaust (pull)
I've chosen these two mainly for aesthetic reasons so I don't have the fans visible inside the case. My question is if I'm limiting airflow and/or cooling by going with either of these and if one is generally a better option than the other.
I'm going to be cooling a 9900k and a 2080 Ti with this build as well.
Thanks for any input.
annul is offline
post #2 of 9 (permalink) Old 03-20-2019, 07:08 PM
News Fiend
ryan92084's Avatar
In my personal testing in in was best but only with exhaust fans in the bottom otherwise it just turned into a hotbox. Side in top out wasn't much worse but I was also using a very slow intake on the bottom. Sadly I didn't do any testing with nothing in the bottom.
As a heads up plumbing the side radiator if it is in the main chamber will be challenging as I believe the mounting holes force it to be in a ports up orientation. At least they do with the rad in the side chamber.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #3 of 9 (permalink) Old 03-20-2019, 07:54 PM - Thread Starter
Rep: 0
Thanks, that is interesting. I was hoping that the bottom and rear vents would be enough to exhaust the air with both side and top set up as intake. Also, were you running your top exhaust in push or pull? I would be running in pull and I'm worried if that would be inefficient.
I have a couple of HWLabs Nemesis 360 GTS that I'm putting in this build. Looks like the side rad can be mounted with ports at the bottom and most of the holes will line up. You're right though, not much room at all if it's mounted with the ports at the top. If it comes to that I'm hopping I'll be able to work some magic with fittings.
annul is offline
post #4 of 9 (permalink) Old 03-20-2019, 07:57 PM
crazycuz2k's Avatar
Rep: 5 (Unique: 5)
Hardware canucks did a whole video on fan placement in the O11 dynamic
crazycuz2k is offline
post #5 of 9 (permalink) Old 03-20-2019, 07:58 PM
tatmMRKIV's Avatar
Rep: 132 (Unique: 88)
just a heads up, this case is tight if you plan on watercooling your gpu you pretty much need to have the vertical gpu adaptor and the front inside radiator really doesn't have a lot of space for some of the newer motherboards so be careful
(If y'all) ain’t ready for the old murder, then what you gonna do with the new me?
tatmMRKIV is offline
post #6 of 9 (permalink) Old 03-20-2019, 08:38 PM - Thread Starter
Rep: 0
Thanks for the heads up. I still haven't chosen a motherboard but I'm thinking of going with an Aorus Master. Unfortunately, it has a gigantic shroud on the VRM heatsinks so that might be an issue. I'm planning on picking one up from Microcenter and hopefully it's returnable if it doesn't have enough clearance for fittings at the top radiator ports.
As far as the GPU goes, I bought a Heatkiller IV block since it seems to be compatible in either vertical or horizontal mount configurations. I do plan on mounting it vertically though.
annul is offline
post #7 of 9 (permalink) Old 03-20-2019, 11:06 PM
tatmMRKIV's Avatar
biggest issues will be gpu and radiator. also that. its tight up there. I went with a dark so thats not a really bad issue for me but I can't do push/pull
honestly, build quality isn't very good either. I regret getting mine. I had a lot of issues getting gpu to screw in in standard configuration.
post #8 of 9 (permalink) Old 03-21-2019, 05:47 AM
News Fiend
ryan92084's Avatar
My top exhaust test would have been push. All tests were with bequiet! SW3 running between 900-1000rpm with a full load on the sig rig.
Quote: Originally Posted by crazycuz2k View Post
https://youtu.be/KU6vIDpNaxw Hardware canucks did a whole video on fan placement in the O11 dynamic
Only a clc on the cpu so not really comparable
I don't think the gts is thick enough to have any worry about either clearance. There is more than enough room up top and the side is staggered by at least 25mm iirc.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #9 of 9 (permalink) Old 05-03-2019, 09:50 PM
ChiTownButcher's Avatar
Rep: 43 (Unique: 36)
Just found this... 3 x 360 rad.
https://youtu.be/mdsVU1i6Y_Q
Self Proclaimed Gaming Nutt
ChiTownButcher is offline
