I think i've really cocked up the planning of my first loop :( - Page 2 - Overclock.net - An Overclocking Community
post #11 of 26 (permalink) Old 03-21-2019, 09:13 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
Quote: Originally Posted by Goooober View Post
Thanks for the advice guys its much appreciated.
With the top rad my only idea was to buy some thick washers as mentioned above, probably need longer screws though.
As for the res it's mounted as low as it can be on that pack panel so the only option would be to mount it on top of the fan on the bottom rad as suggested by annul. I already have this thing which i think is meant to work that way as well - https://www.ekwb.com/shop/ek-uni-pum...m-fan-vertical
I'm not sure if you have seen my post edit, but a thick gasket is probably also an option for you.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #12 of 26 (permalink) Old 03-21-2019, 09:33 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
No i didn't see it, thanks for pointing it out it looks like you should do the job nicely.
I've now run in to another annoying problem. The 30mm screws that came with my radiators aren't long enough to go throught the EK Pump bracket, through the fan and in to the radiator. Once its through the bracket and fan there's only about 1-2mm of screw left. It's almost certainly down the Corsair ML Pro fans being too thick.
Goooober is offline
post #13 of 26 (permalink) Old 03-21-2019, 09:48 AM
Overclocker in training
ThrashZone's Avatar
Rep: 172 (Unique: 105)
Hi,
Hardware store for... longer screws.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k batch # X016E724
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is online now
post #14 of 26 (permalink) Old 03-21-2019, 06:07 PM
lovan6's Avatar
Rep: 7 (Unique: 7)
You have ton of space with that case and it is just a matter of planning. I was thinking of getting that case too. Here is my current build on a Inwin 303 with Hardware labs radiators. In fact you can install 2 60mm + another 360 GTS X flow back side of radiators if you plan just to use a single gpu.
https://imgur.com/zHp3M1K
Always remember loop order does not matter as long as you have a steady supply of water from reservoir to pump. Run the shortest path of tubing into blocks and radiators traveling inside the loop.
I would install the 60mm radiator at the bottom in push fans.
Use the uni mount pump reservoir bracket above SR2.
Install the 30mm radiator on top in push fans or Dual fans in push pull.
Loop order is Pump to GPU > CPU> Top radiator> SR2 > back to reservoir.
Mount the drain valve with soft black tubing at the front back side of SR2. I think you still have enough space to use a 90 degree rotary fitting.
lovan6 is offline
post #15 of 26 (permalink) Old 03-22-2019, 07:46 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
It sure is a tight fit, only about 30mm between the GPU port and the rad. It's not enough to fit a regular compression fitting which is all i bought but i guess a 90 degree fitting would work. Would probably look neater if i used another 90 degree in the rad too. I imagine they would both need to be rotary's too?
The rest of my fittings are Barrow so i guess these would do the job - https://www.ebay.co.uk/itm/Barrow-G1...cAAOSwPYZU5UtR
It'll be super tight as the fitting is 26mm according to the diagram.
Goooober is offline
post #16 of 26 (permalink) Old 03-22-2019, 09:22 AM
ThrashZone's Avatar
Hi,
Yeah put it back on top that's way too high for the bottom.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
EVGA 1000P2
Corsair 450D
Operating System
post #17 of 26 (permalink) Old 03-22-2019, 09:26 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by ThrashZone View Post
Hi,
Aside from the tight working space what's the problem with it being that high? It'd make my life easier as far as a drain port goes having the multi port rad on the bottom.
Goooober is offline
post #18 of 26 (permalink) Old 03-22-2019, 09:34 AM
ThrashZone's Avatar
Hi,
Not really sure why you're not putting a rad on the front 360mm won't fit there ?
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
EVGA 1000P2
Corsair 450D
Operating System
post #19 of 26 (permalink) Old 03-22-2019, 09:39 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Hi,
Do you mean upright where i had my res mounted originally?
I did think about that but i'm thinking there might not be enough clearance between it and the other rad. I'll give it a go though and see what happens.
Goooober is offline
post #20 of 26 (permalink) Old 03-22-2019, 09:47 AM
ThrashZone's Avatar
Hi,
Yes rad on front the skinny one with inlet outlet down
Then all you need is a simple T valve and shut off valve for drain.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
EVGA 1000P2
Corsair 450D
Operating System
