I think i've really cocked up the planning of my first loop :( - Page 3 - Overclock.net - An Overclocking Community
post #21 of 26 (permalink) Old 03-22-2019, 11:26 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by ThrashZone View Post
Hi,
Yes rad on front the skinny one with inlet outlet down
Then all you need is a simple T valve and shut off valve for drain.
Well it does fit with the fans on the rear side of the upright rad.
But it certainly doesn't work with the ports on the top rad to the right of the case and the ports on the upright rad on the top.
As you say I would have to have the upright rad with the ports on the bottom.
Goooober is offline
post #22 of 26 (permalink) Old 03-22-2019, 11:36 AM
Overclocker in training
ThrashZone's Avatar
Rep: 128 (Unique: 84)
Hi,
Put the thinner rad on top where the ports would be on the left side.
Never mind rad too thick :/
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #23 of 26 (permalink) Old 03-22-2019, 12:51 PM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
I have to say that aesthetically i prefer the rads top and bottom. The thick rad on the bottom would be my preference and although its tight it should be doable to get tubing from the rad to the GPU with 90 degree fittings.
Goooober is offline
post #24 of 26 (permalink) Old 03-22-2019, 01:48 PM
ThrashZone's Avatar
Hi,
Yeah if you don't care if blocks half the bottom of the board go for it.
Thick one work and looks good on the top and has enough room for push/ pull fans looks like.
I guess since you put the thin rad on the back on the same plain as the mother board attaches too there is no way to mount a radiator on the front of the case.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #25 of 26 (permalink) Old 03-25-2019, 06:26 AM
News Fiend
ryan92084's Avatar
For your initial setup like others said just get some longer screws and make a gasket out of some craft foam sheets or switch the fans to push from the top if you are ok with that aesthetic. However, I'm not a fan of having a bottom rad in this case because the bottom grill is extra restrictive, the look of the plumbing, and blocking the motherboard.
For the option of putting a rad in the side of the dynamic it would usually go in the secondary chamber not the main and then the fans would be in the pull configuration from the main chamber. This allows for plumbing the rad in the top port position. The issue there is it looks like you've bought a GTS which is slightly too wide because of how the case's front panel is configured but that can be modified. If that is an option you are interested in I have some tips in this post https://www.overclock.net/forum/161-...l#post27690358
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #26 of 26 (permalink) Old 03-25-2019, 06:54 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Thanks for the info. Unfortunately i'm not really comfortable modding the case as its 100% the type of thing i'd mess up. The only way i could mount the GTS on the side would be with the ports on the bottom. I'm only using soft tubing but i'm not sure how easy it would be to plumb it all together with those ports on the bottom with the res/pump mounted slightly higher.
I dont know if this would work?
Loop order being Pump/Res>GPU>CPU>Top Rad>Side Rad>Pump/Res
Tubing runs would look seriously weird though.
Goooober is offline
