I think i've really cocked up the planning of my first loop :( - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 03-21-2019, 07:43 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
The first thing to say is that I bought my Lian Li PC-O11 case with the intention of air cooling but stupidly failed to realise you cant fit decent air coolers in it. I tried AIOs but found them to be too noisy. This led me to deciding to try my first ever custom loop.
I blindly followed the advice of others about what radiators to choose which is why i have a 30mm and a 60mm, both hardware labs. The 60mm is a problem.
And no, i cant blame the guy for this, it's ultimately down to me to choose the right components.
The 60mm is a multiport which i thought would be useful when mounting the radiator on the floor of the case so i could attach a drain port and whatnot. I quickly realised that with the fans attached there would only be about 5mm between the fans and the GPU. I've no choice but to mount it on the top.
As you can see it doesn't sit flush with the case because of the sodding plugs in the top two ports. I can just about thread the screws in but no where near 100% without warping the thin metal of the case.
[SPOILER="Top Radiator"][/SPOILER]
I can juuuuuust about managed to get a bendy tube in the top of the res to fill it.
[SPOILER="Res"][/SPOILER]
Apologies for the crappy paint skills in the picture below showing the whole system and loop order.
I've already bought a ton of soft tube fittings and Mayhems tube and as things currently stand the tubing runs are going to look properly hideous. I might have to buy some 90 degree fittings and extensions to help get the tubing over and around the fans (i've only installed one fan on each rad for loop planning but i do have three fans for each rad).
[SPOILER="Loop order"][/SPOILER]
I suppose i could try and return the 60mm rad but in another act of stupidy and i've already flushed it with vinegar and water, who knows if they (not OCUK) will be able to tell and refuse the RMA.
Goooober is offline
post #2 of 26 (permalink) Old 03-21-2019, 07:54 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Push pull fans on the top rad should solve the top spacing issue with the unused port on the rad.
The flow should be reversed.
Pump outlet/ front rad/ gpu/ cpu/ top rad/ back to pump inlet.
Lower reservoir.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 26 (permalink) Old 03-21-2019, 08:04 AM
Not a Fan
GnarlyCharlie's Avatar
Rep: 162 (Unique: 126)
Quote: Originally Posted by ThrashZone View Post
Hi,
Lower reservoir.
yeah, put intake push fans on the top. You could get out the Dremel tool and remove some of the case above the plugs if you just had to keep the radiator above the fans, but intake push fans on top would be so much better. And don't worry about running the top radiator as inlet, cool air over the radiator is what you want, just put an exhaust fan in the back and call it good. Think about a car radiator - cool air -> radiator -> hot engine. Nobody worries about the hot air from the radiator blowing on the engine and overheating it. And it seems intuitive to have the top rad as exhaust, hot air rising and all, but hot air isn't going to rise much in a case with an exhaust fan on the back and cool air over the rad is better than warmish air over the rad.
If winning were easy, losers would do it.
It's got Async Compute, it's got what plants crave!
War Pig
(12 items)
Death Bomb
(9 items)
X-Rig
(15 items)
i9-7980XE
Rampage VI Extreme Omega
2080Ti FE
G.Skill F4-3600C16Q2-64GTZSW
Samsung 970 Pro X4
Optical Drive
Pioneer BDR-209BDK
EVGA SuperNova 1300 G2
HW Labs Black Ice GTX 420-480-2X240
EK Supremacy Evo CPU Heatkiller IV GPU
2X PPCs Bitspower D5
Corsair 900D
Operating System
Windows 10 Pro 64 Bit
I7-7700K De-lidded @ 5GHz
Asus Strix Z270i
Nvidia Titan Xp
G. Skill F4-3600C15D-16GTZ
2X Samsung 960 Pro 512GB M.2
SeaSonic X750
EK Supremacy EVO CPU. Titan Xp Full Cover w/Backplate, X-TOP Revo D5 PWM Pump, Res X3 110mm Res, HW Labs GTS 280 and GTS 240, Primochill Tubing & Revolver fittings
Fractal Nano S
Operating System
I7-5960X
Asus Rampage V Extreme 1502
EVGA Titan X
EVGA Titan X
G.Skill F4-3000C15Q-32GRK
Samsung SM951 M.2
Samsung 850 Pro 512GB
Optical Drive
Pioneer BDR-2209
EVGA 220-P2-1200-X1
EKWB Blocks, Fans, and Pumps, Rads
Corsair 550D
Operating System
Windows 10 Pro Retail
BenQ BL3201PH
Keyboard
Max Keyboard Nighthawk X8
Mouse
Roccat Kone Pure Optical
GnarlyCharlie is offline
post #4 of 26 (permalink) Old 03-21-2019, 08:06 AM
Rep: 0
You should be able to mount your reservoir on the bottom radiator fan using this: https://www.ekwb.com/shop/ek-uni-pump-bracket-120mm-fan
That should give you enough clearance to fill. EKWB also makes multi-port reservoir tops that you can buy separately, which might make things easier for you as well if you don't want to use the pump top inlet.
For your radiator, you might need to get new screws from a hardware store but make sure that the screws aren't long enough to puncture through the channels in the radiator. These radiators don't have a mechanism to prevent you from doing that.
annul is offline
post #5 of 26 (permalink) Old 03-21-2019, 08:07 AM
ThrashZone's Avatar
Hi,
Boom indeed Intake always on rads good catch Charlie
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 26 (permalink) Old 03-21-2019, 08:39 AM
Shawnb99's Avatar
Rep: 50 (Unique: 32)
HWL labs should have a protector to prevent this. Also the solution to longer screws is to ether cut them to custom length yourself, easy enough to do with a Dremel, or buy some washers to make up the extra length.
Welcome to water cooling. You learned the first lesson, you can only plan so much until you get everything and actually set it all up, At that point the plan is out the window. It only took me 2 and half months to finish my loop, plans be dammed.
If able it's always better to buy more and not need it then not have it when you need it.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #7 of 26 (permalink) Old 03-21-2019, 08:58 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Take out the dremel and make some place for those 2 stop fittings?
Or add some spacers under the rad so it drops down by 5-6mm. Or a gasket would be even better like 3 of these: https://www.highflow.nl/watercooling...20mm-fans.html
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #8 of 26 (permalink) Old 03-21-2019, 09:02 AM
toolmaker03's Avatar
Rep: 95 (Unique: 72)
agreed, I have been water cooling for 20 years, and I still have never been able to get everything I need for the build, before I actually tried to build it. weather it be getting the wrong length of bolts, or just forgetting that one extension wire, their is always something, that I still need to get. this upgrade took me a little over two months to complete, and I thought I had everything I needed before I started.
https://www.overclock.net/forum/61-w...ooled-rig.html
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #9 of 26 (permalink) Old 03-21-2019, 09:07 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Thanks for the advice guys its much appreciated.
With the top rad my only idea was to buy some thick washers as mentioned above, probably need longer screws though.
As for the res it's mounted as low as it can be on that pack panel so the only option would be to mount it on top of the fan on the bottom rad as suggested by annul. I already have this thing which i think is meant to work that way as well - https://www.ekwb.com/shop/ek-uni-pum...m-fan-vertical
Goooober is offline
post #10 of 26 (permalink) Old 03-21-2019, 09:13 AM
ThrashZone's Avatar
Hi,
You could add more holes for the pump reservoir combo where ever so it doen't need to be mounted on top of a fan.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
