the longest watercooling loop ever? - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 03-22-2019, 06:57 AM - Thread Starter
robinlawrie's Avatar
Rep: 0
a few years ago i built a massive external watercooler to try and achieve a very quiet 3d workstation.
consists of a pair of mora3 radiators in parallel, a reservoir, and a pair of d5 pumps in series. fans are 6x silverstone 180mm. all internal tubing and interconnects are 1/2 inch.
this setup is connected to my workstation via a 3/8" umbilical 3m long with quick disconnects on the end.
the workstation has a 3930k and 2x titan x all in series, on a 3/8" set of fittings and tubes.
the reason for the fatter tubes in the cooler and the thinner umbilical and workstation fittings are:
the cooler is future proofed and was designed to cool whatever hardware i could throw at it, now and future.
the umbilical and pc use 3/8" due to flexibility of umbilical and space in workstation.
it has been working beautifully for years..
even with both gpus and the cpu (at 4.6 ghz) rendering flat out together, the gpus stay around 33 degrees and the cpu sits at around 46 degrees.
this is with cooler fans running at just above stall speed, and the twin pumps both on setting 1 of 5
HOWEVER:
now its time to get a new beastly workstation.
ideally i wish to continue cooling the old one, as its still useful for rendering.
new workstation will probably be
threadripper 3 (64 core if possible, will find out soon enough
4x Titan RTX gpu, or Ampere gpu of similar spec if available (my job involves tons of gpu rendering. the extra gpu ram is very useful)
i would also like to cool vrms on mobo.
i dont plan on doing too much oc on new workstation.. maybe some mild stuff.
so, my external cooler will be getting put to the test. i guess ill need to crank up the pumps!
my current plan is to either just run a massive serial loop, with (in total) 6x gpus and 2x cpus and vrm cooler all in series with dual pumps, and only the radiators in parallel ( iirc, this was on advice of manufacturer who showed marginally improved performance with slow flow rate in those rads.)
or, run the two workstations in parallel with each other, and use a valve to balance flowrate. in that case it would be 2x gpu and 1x cpu on one side, and 4x gpu, 1xcpu and 1xvrm cooler on the other.
the second option makes a touch more sense, since the 1/2" tubing in the cooler might match quite well with a pair of 3/8" loops.
any suggestions?
thx all...
robinlawrie is offline
post #2 of 20 (permalink) Old 03-22-2019, 02:05 PM
NewType88's Avatar
Rep: 0
I gotta mo-ra3 420 for my loop.I do not have any advice, but Lets see some pics ! I'll be very interested in seeing your new setup when everything is done, sounds very interesting.
Is your workstation at home ? What do you do to need all that powa ?
NewType88 is offline
post #3 of 20 (permalink) Old 03-22-2019, 08:50 PM
lovan6's Avatar
Rep: 7 (Unique: 7)
If you are really looking to build a beastly machine, I would look for a now defunct Caselabs TX10 case.
You can transfer the old build and work on the other side for the new build.
And if you happen to find one grab it right away.
lovan6 is offline
post #4 of 20 (permalink) Old 03-22-2019, 10:15 PM
white owl's Avatar
Rep: 134 (Unique: 101)
I wouldn't want them on the same loop...in the same case perhaps but not on the same loop. The problem with doing a loop like that (IMO) especially if you need them for work is that if you have any issues both systems are down. Also in the off chance you have any corrosion or contamination you'll spread it through the entire system. I just don't see any logical reason to connect them unless you're using a more industrial pump, something beyond a D5.
If it were me I'd probably have to build my own case or at least pedestal to house the big square 9x 120mm rads I'd want to use but that's your call.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #5 of 20 (permalink) Old 03-23-2019, 03:46 AM - Thread Starter
Rep: 0
Here is the watercooler in its natural habitat.. Sorry for the mess. Yeah its a home office. I do 3d images and animation, for advertising and architecture.. A mix of cpu and gpu based rendering using vray.
Regarding doing seperate coolers, id not have built such a mahoosive cooler if i didnt plan on adding more than one machine. Its got dual pumps, for redundancy and extra pressure, specifically to handle the job. And im not going to spend all that cash again. It was quite eye wateringly expensive to build. It wa originally planned to handle a small renderfarm without making a noise. Theoretically the dual rads can handle approaching 4kw. Id imagine it would be noisy at that level tho.
A good point re. Problems affecting both machines, however a) ive already got a seperate backup machine and b) its been flawless for years and is still clean inside.
Regarding the case, ive built a dual motherboard workstation before, and it was annoying, sharing a psu it was fiddly to start without problems. Im also quite happy to leave old machine in black lian li case untouched.
Im actually going completely the opposite direction. Planning a super dense cerberus x build for the threadripper and 4x titan rtx. With external cooling it a fits quite nicely (ive made a 3d model already) and when i go away on holiday i can unplug it from umbilical and leave it in a safe place. Id be crapping it leaving such an expensive machine home alone.
Ps. Try to ignore the wonky fan cutouts, i trusted a local carpenter to do that panel, and he did a lame job. Seems he hadnt heard of a router with circle jig.
Thinking about it, i guess i could re-plumb the cooler to have one rad and one pump for each machine, however, normally id just be using one machine, so wasting half the cooling power.
post #6 of 20 (permalink) Old 03-26-2019, 10:25 PM
andrewmp6's Avatar
Rep: 13 (Unique: 12)
andrewmp6 is offline
post #7 of 20 (permalink) Old 03-27-2019, 06:36 AM
News Fiend
ryan92084's Avatar
From the thread title I was expecting an old geothermal setup : D
Ideally I think if I was only ever using one system at a time I'd probably just do Y junction from the rad box to each system and give each system its own pump(s). Maybe throw a ball valve on one of the 4 lines to cut off/minimize flow to one system if you find that the rads aren't getting enough flow but I suspect the restriction of the blocks on the non running pc would do most of the balancing.
I'm not sure how feasible that is with the current setup with the pumps being part of the box.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #8 of 20 (permalink) Old 03-27-2019, 06:56 AM
Shawnb99's Avatar
Rep: 13 (Unique: 9)
https://www.youtube.com/watch?v=3a7kKKPs6J8
My biggest regret is not ordering one of those when I had a chance
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #9 of 20 (permalink) Old 03-27-2019, 07:00 AM
toolmaker03's Avatar
Rep: 82 (Unique: 62)
well I have a massive system as well and I to use a parallel setup on my hardware and the radiators to keep the flow rate high.
here is a small scale version test setup.
https://www.overclock.net/forum/61-w...el-9-6lpm.html
here is my large scale version of that same build structure.
https://www.overclock.net/forum/62-p...c-cooling.html
maybe this will give you some ideas for your own build.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #10 of 20 (permalink) Old 03-27-2019, 07:23 AM
skupples's Avatar
Rep: 521 (Unique: 293)
sounds like a job for two dual pump loops to me. Easier to maintain.
make sure you invest in Quick Disconnects.
skupples is offline
