Bad performance from Treadripper EK-Supremacy sTR4 RGB Nickel waterblock - Overclock.net - An Overclocking Community
post #1 of 31 (permalink) Old 03-24-2019, 07:31 PM - Thread Starter
MacMus's Avatar
Rep: 0
Hello,
Recently I have completed my watercooling build but i am getting high temperatures on my treadripper 4Ghz 1950x similar to presented here:
My prime95 load cooling temperatures are reaching 80 degree. I have re-pasted already few time my cpu using diffrent methos and diffrent pastes, but i am achiving more or less same temperatures.
I'm thinking about switching to XSPC: http://www.xs-pc.com/waterblocks-cpu...md-str4-chrome
Now I have two issues this is copeer block and all my fittings etc are nickel, does it matter?
Does anyone has better blocks suggestions ? I'm going with Asus Zenith Extreme Alpha so monoblocks are also possible i think.
Do you also have poor performance with watercooling on EK sTR4 block ?
Thank.
MacMus is offline
post #2 of 31 (permalink) Old 03-24-2019, 08:36 PM
jura11's Avatar
Rep: 98 (Unique: 62)
Hi there
Best performing TR4 blocks are Heatkiller TR4, XSPC Raystorm Neo TR4, EK TR4 depends if its older one then these are poor performing blocks
There has been thread over here regarding the EK TR4 blocks and their performance, most of them didn't performed as should there
Hardocp.com and Kyle done pretty good reviews of TR4 waterblock and air coolers as well
Hope this helps
Thanks, Jura
jura11 is offline
post #3 of 31 (permalink) Old 03-24-2019, 08:39 PM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
first question depends on what type of coolant you plan to use. I personally use Prestone green antifreeze, at a 80% distilled water, to 20% antifreeze mix, so mixing metals for me, does not matter at all.
the TR4 water block from XSPC, has the highest thermal rating out of the water blocks made for the TR4 CPU's.
yes, the cheap $24 EK TR4 water block, has really poor performance on the TR4 CPU's, that is the reason for it being so cheap.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #4 of 31 (permalink) Old 03-24-2019, 09:05 PM
Invalid Media
J7SC's Avatar
Rep: 10 (Unique: 8)
Quote: Originally Posted by jura11 View Post
Hi there
(..edit..)
...have been using the Heatkiller TR4 (Nickel-plated version) on a 2950X and MSI Meg Creation @ 4.25 GHz since November. Great quality etc. and absolutely no complaints on temps, idle temps in mid-20s C and full load-temps rarely even get to 60 C. In fairness, system has dual pumps and dual 360 rads for the TR, and I covered the IHS w/ MX4 end to end.
J7SC is online now
post #5 of 31 (permalink) Old 03-24-2019, 10:13 PM - Thread Starter
MacMus's Avatar
Rep: 0
Where do i get HEATKILLER® IV PRO for Threadripper™ ACRYL NICKEL from US ?
It looks it's sold out ;-(
I'm using EK SOLID neon green which should be fine, as it's one of the latest coolants.. I think when you mix nickel and copper it's still fine..
The problem is when aluminium comes into play..
I have all my radiators and fitting nickel.
EK-WB str4 has disgusting performance. I feel bad for ordering it.. I have trowed away 100 bucks ;-(
For owners of Heatkiller TR4: This RGB is 12 V?
MacMus is offline
post #6 of 31 (permalink) Old 03-24-2019, 11:20 PM
Invalid Media
J7SC's Avatar
Rep: 10 (Unique: 8)
I ordered my Heatkiller IV TR4 (non-RGB version) directly from the manufacturer's online shop in Germany...got to CDN in about a week, even during the holiday season.
J7SC is online now
post #7 of 31 (permalink) Old 03-24-2019, 11:34 PM - Thread Starter
MacMus's Avatar
Rep: 0
did u get nickel copper or full copper ?
i did same thank you but went with RGB of course.. RGB is proven to give better OC results.
I got pissed about EK-WB block tbh ;-(
MacMus is offline
post #8 of 31 (permalink) Old 03-24-2019, 11:45 PM
Ironsmack's Avatar
Rep: 50 (Unique: 47)
Did they shipped it through DHL? Or they gave you the option to ship it through DE postal service?
Ironsmack is offline
post #9 of 31 (permalink) Old 03-25-2019, 12:03 AM - Thread Starter
MacMus's Avatar
Rep: 0
dhl
MacMus is offline
post #10 of 31 (permalink) Old 03-25-2019, 04:44 PM
Invalid Media
J7SC's Avatar
Rep: 10 (Unique: 8)
They had an express option (could be DHL, don't recall) on their site which I used, but it arrived here (CDN) via a partner carrier.
J7SC is online now
