will my 750ltr x20 pump be enough please? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 03-25-2019, 06:34 AM - Thread Starter
No.2 in Gaming
MrPerforations's Avatar
Rep: 78 (Unique: 57)
hello forum,
I got a xspc x20 750 pump with cpu block and 2 x 360 radiators and I am going to add in two gpu blocks in parallel, would the pump be enough or will I need a extra pump please?
also, I was thinking of buying a pump from ali express to the loop if needed, its a Bykski-B-PMS5-NX-RBW-lighting-PWM-Automatic-Pumps-D5-Series-Flow-Rate-1100L.
can I just run a hose from the first pump to the next pump and then use it to boost the flow rate please?
I do have a lot of hose length as the radiators are external mounted.
im also changing my hose to 10mm id and 16mm od type from the 7/16 which is 12mm id and 16od, what effect would this have please?, I was hoping it would travel further.
AMD Ryzen™ 1700 3.75ghz
MSI™ X370 Gaming Pro Carbon™
MSI™ Radeon™ Vega 56 Air Boost OC
Avexir™ Blitz™ 3200 CL16 @ 3200
Seagate™ 2TB Barracuda™
Optical Drive
ASUS™ DRW-24D5MT
EVGA™ Supernova™ 1000 G2
XSPC™ Raystorm™ 750 2x EX360 Radiators
Coolermaster™ Cosmos Pure Black
Operating System
Windows™ 10 x64
Electriq™ VM280UHD 4k
Keyboard
RII™ K66 Red Switch mechanical keyboard
Mouse
EasySMX™ Red Gaming mouse
Audio
Creative labs™ sb x-fi titanium
Audio
Logitech™ 540x 5.1
MrPerforations is offline
post #2 of 9 (permalink) Old 03-25-2019, 07:07 AM
Overclocker in training
ThrashZone's Avatar
Rep: 45 (Unique: 36)
Hi,
Do you know any water temp readings under full load now ?
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #3 of 9 (permalink) Old 03-25-2019, 07:30 AM
skupples's Avatar
Rep: 521 (Unique: 293)
pumps must be identical to use two, and typically you'd use a dual top (MCP35x2 for DDC. or EK dual D5 as examples)
I'd replace the XSPC with the single D5.
PWM isn't necessary though. Pump speed is set & forget. Just add a water temp sensor so you can properly dial it in.
Flow rate has incredibly high diminishing returns between .5GPM - 1.0GPM, and almsot zero gains over 1.0GPM. (~120LPh-240LPH)
best way to judge this if you don't have flow sensor is by starting on the lowest pump speed while running a full system bench, & stop turning up the speed when you stop seeing gains in temp reduction. The results are almost instant when changing speeds.
skupples is offline
post #4 of 9 (permalink) Old 03-25-2019, 08:35 AM
Shawnb99's Avatar
Rep: 13 (Unique: 9)
Quote: Originally Posted by MrPerforations View Post
hello forum,
Tubing size makes absolutely no difference.
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #5 of 9 (permalink) Old 03-25-2019, 08:47 AM
ThrashZone's Avatar
Hi,
Thicker tubing 10-15mm or 3/8-5/8" can make sharper turns without kinking/ more durable.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #6 of 9 (permalink) Old 03-25-2019, 09:16 AM - Thread Starter
No.2 in Gaming
Quote: Originally Posted by ThrashZone View Post
Hi,
about 40c underload with the ryzen 1700.
the motherboard seems to be the hottest thing, but from what I gather, the motherboard sensor is in Fahrenheit and reporting as in centigrade.
I just got a pair of vega 56's for £500, I used info that basically said that the vega 56 crossfire would outperform the radeon vii, new info tells a very different story, dam it.
thx skupples,
ill have a go and see if it can pump though with the x20 first, but if I have to get new pump and res ill do that d5 job. the prices at the moment on ali express are good as they have a sale.
the pump is locked to 750lph.
good to hear that the hose wont make a difference, was worried I had made a mistake getting smaller type.
also got me some compression fitting to improve the look, at a £1 each, there about £5 in the shops over here, hope there good.
as you can see, I got the kink coils on the outside, there supposed to be inside, but glad I didn't as they went brittle and snapped all over the place, recommend metal only.
and thank you all for your advice.
Optical Drive
ASUS™ DRW-24D5MT
Operating System
Windows™ 10 x64
Keyboard
Mouse
Audio
Audio
Logitech™ 540x 5.1
post #7 of 9 (permalink) Old 03-25-2019, 10:03 AM
skupples's Avatar
a pump's rated LPH goes down exponentially when you hook it into the system.
Example - I have 3 UT60 480s, 2 GPUs, n a fully blocked board via MCP35x2 (2x high powered DDC) and I only get just above .5GPM (120LPH) switching over to dual D5 may net me more flow, but that's $300 worth of pump for a couple c. I've also been running these nearly nonstop for 6 years, so their time is coming.
skupples is offline
post #8 of 9 (permalink) Old 03-25-2019, 04:22 PM
TeslaHUN's Avatar
Rep: 17 (Unique: 15)
Quote: Originally Posted by skupples View Post
pumps must be identical to use two, .
Nope , im using 2 different pump(VPP 655 +VPP 755) in different speeds( 1/5 , 3/5 speed ) in my system, no problem at all.
In my old pc i had one D5+1 Phobya dc260 pump without any problem.
TeslaHUN is offline
post #9 of 9 (permalink) Old 03-26-2019, 03:03 PM - Thread Starter
No.2 in Gaming
oh my god, from the amount of radiator you have my guess is you must have been a fx9590 user at some point.
from what I read on that water cooling basics article, that mobo block is a real bottleneck, I could do with one, but it really would need a better pump.
thanks for the info, was thinking of putting the 1100lph pump after the 750lph pump and use it to increase the flow.
Optical Drive
ASUS™ DRW-24D5MT
Operating System
Windows™ 10 x64
Keyboard
Mouse
Audio
Audio
Logitech™ 540x 5.1
