How unscrew a compression fitting (i'm not kidding)? - Overclock.net - An Overclocking Community
post #1 of 35 (permalink) Old 03-29-2019, 05:31 AM - Thread Starter
Goooober's Avatar
Rep: 0
I've been doing some test fitting of my first custom loop and i've found that i can screw the compression fitting collar by hand and have it nice and flush to the bottom part.  The trouble is any attempt to unscrew the collar just results in unscrewing the whole fitting from the radiator/block/whatever.  If both ends of the tube are connected it makes it impossible to remove without cutting the tube.
My only thought is to use a couple heavy duty pliers but i'm worried about this damaging the fitting.
Goooober is offline
post #2 of 35 (permalink) Old 03-29-2019, 05:41 AM
Shawnb99's Avatar
Rep: 17 (Unique: 12)
Hold the tube in place while you unscrew the fitting. I’ve had this issue with a few of my EK fittings, it’s really a PIA.
My Baby
(24 items)
Delidded I9 9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB in Raid 0
2x Intel 660P 2TB in Raid 0
Asus Hyper M.2 Card
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 35 (permalink) Old 03-29-2019, 06:27 AM
Rep: 453 (Unique: 385)
Needle nose pliers to hold the bottom, even that becomes tricky working inside the case. A barb with a worm-drive hose clamp will solve all your problems but if you want it to look nice you'll have to struggle a bit
Darren9 is offline
post #4 of 35 (permalink) Old 03-29-2019, 06:34 AM
Fluxmaven's Avatar
Rep: 9 (Unique: 5)
They probably still can't feel their fingers from getting all their fittings on that tight to begin with.
Fluxmaven is offline
post #5 of 35 (permalink) Old 03-29-2019, 06:46 AM
skupples's Avatar
Rep: 529 (Unique: 299)
sweet jesus, that's one cranked down compression.
You can use towels on the jaws of your pliers to prevent finish damage.
skupples is offline
post #6 of 35 (permalink) Old 03-29-2019, 07:36 AM - Thread Starter
Goooober's Avatar
Rep: 0
You'll have to excuse my noobness but are you not meant to screw them on the whole way?
Goooober is offline
post #7 of 35 (permalink) Old 03-29-2019, 07:43 AM
Overclocker in training
ThrashZone's Avatar
Rep: 54 (Unique: 44)
Hi,
No just a poorly designed system
Obviously the bottom fitting should have a shoulder so one can grip it and the top should fit down on it
The cap has a horizontal line all the way around the cap just to show where the break should be lol
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #8 of 35 (permalink) Old 03-29-2019, 08:00 AM - Thread Starter
Goooober's Avatar
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
I apologize for being stupid but i'm not sure what horizontal line you mean?
The picture below is with the collar not screwed in at all, how far down should it go?
Goooober is offline
post #9 of 35 (permalink) Old 03-29-2019, 08:07 AM
ThrashZone's Avatar
Hi,
There's your break so what is the problem ?
As far down as it doesn't leak
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
Audio
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #10 of 35 (permalink) Old 03-29-2019, 08:09 AM
Missing the Old days
Cerberus's Avatar
Rep: 247 (Unique: 214)
QFT, I always procrastinate loop maintenace due to the blinding pain my fingertips are after about 30 min of untightening and re tightening fittings
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Folding Rack
(10 items)
Work Folder
(7 items)
AMD r7 2700x
ASUS ROG Crosshair VI Hero
Nvidia Titan X Pascal
Zotac GTX 980 AMP!
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G602
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD r7 1700x
MSI X470 Gaming Plus
GIGABYTE GTX 1080
GIGABYTE GTX 1080
Geil EVO 1x4GB DDR4
Toshiba 3TB
Silverstone ST-1000PT
4U Rosewill
Operating System
Ubuntu 18.04LTS
Headless
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
