Question about block pressure drop - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 03-30-2019, 08:02 AM - Thread Starter
reaper829's Avatar
Rep: 0
I was wondering if someone could help me out with head pressure.
I have the photon 270 D5 vario, which is apparently 3.7 max pressure.
Here are the parts I purchased and their restriction:
EK Velocity - .72/1gpm
Ek Vecter - .82/gpm? (previous gen fc-1080 block is .82)
Nemesis 420 GTS - 1.0? (360 gts is .91)
Maximus XI Formula with Crosschill waterblock - ?
I'm also thinking about adding the Alphacool st30 280 so I can have more silent operation. Pressure drop for that it .30 / 1gpm.
Three things I'm not sure of:
1. Is this too much restriction for my pump? I don't want to be running it at 5, was hoping for 3 or 4.
2. Do I need the extra 280 for silent operation? I will be overclocking my CPU, but not my GPU.
3. What is the restriction of the Crosschill 3 waterblock on the Maximus XI formula board? I can't find any information about it anywhere.
Thanks for your help!
reaper829 is offline
post #2 of 10 (permalink) Old 03-30-2019, 08:09 AM
Hardware Princess
Hydroplane's Avatar
Rep: 37 (Unique: 29)
The D5 can easily pump through all of that. I have a D5 for 2 radiators, 1 CPU block and 2 GPU blocks. I run mine at 100% all the time (PWM) since it's basically silent. I have to turn off all my fans to hear it. A 420 (with push/pull fans) is probably enough for CPU OC + GPU no OC, but adding a 280 wouldn't hurt if you want it as quiet as possible.
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #3 of 10 (permalink) Old 03-30-2019, 11:41 AM
Overclocker in training
ThrashZone's Avatar
Rep: 128 (Unique: 84)
Hi,
Only block pressure drop I've ever seen is from a clogged block usually cpu because they have very fine thin cooling fins
EK being the worst because they have a razor blade water jet that focuses water through a slot which is only 3/16"
That slot if any thing is in the fluid will clog it very quickly.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #4 of 10 (permalink) Old 03-30-2019, 09:58 PM - Thread Starter
reaper829's Avatar
Rep: 0
Thanks for the information!
post #5 of 10 (permalink) Old 05-03-2019, 10:19 AM - Thread Starter
reaper829's Avatar
Rep: 0
Update:
I have purchased everything that i'm getting for my new PC:
Nemesis 420 GTS
Nemesis 420 GTS X-flow
EKWB Vertex Intel waterblock
EKWB Vector RTX 2080 waterblock
Asus Maximus XI Formula VRM waterblock
I added all of the parts restriction up, and it almost equals the maximum head pressure of the XSPC Photon D5 Vario (3.7m) that I have. Does this mean that I need another pump? Or am I misunderstanding how all of this works?
Thanks for your help.
post #6 of 10 (permalink) Old 05-03-2019, 12:18 PM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Be aware depending on the routing connecting all of that, specially with the VRM block, can lead to sone very tight bends.
Had the same issue myself connecting it all.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #7 of 10 (permalink) Old 05-05-2019, 07:58 AM - Thread Starter
reaper829's Avatar
Rep: 0
I figured that might be the case. I was worried that one pump might not be enough. What pump are you using for yours?
Edit: sorry, just saw your signature. Dual DDC, nice. I suppose I should probably spring for a dual pump solution as well so that I don't have to worry about anything.
post #8 of 10 (permalink) Old 05-05-2019, 10:31 AM
PachAz's Avatar
Rep: 62 (Unique: 44)
I had a cpu block clogged with oxidation and plasticiser and I barely got any flow thru my system. Once cleaned, the flow was improved. The flow was so bad that I never got the air out from the radiators. The fittings and tubes comming out from the GPU was extremely hot while the rest of the system was cool. I use the alphacool eisblock which is very restrictive and once gunk builds up it will limit the flow alot. I used the xspc raystorm before and it is alot less restrictive so the gunk in the cpu block didn't affect the flow so much. I will change the cpu block as the eisblock is one of the most restricitive ones on the market.
PachAz is offline
post #9 of 10 (permalink) Old 05-05-2019, 01:00 PM
Shawnb99's Avatar
I’m running a pair of Dual DDC’s now. My QDC’s add a lot of restriction.
I’ve always gone dual pumps, the redundancy is great.
Might want to look at adding a flow meter if you can as well, and a temp sensor for the water.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
post #10 of 10 (permalink) Old 05-06-2019, 12:23 PM - Thread Starter
reaper829's Avatar
Rep: 0
Yeah, I have one of the barrowch oled flow meters, and then I picked up 2 pass-through temperature sensors. I have the Maximus XI Formula, so I should be able to output both temperatures through the built-in screen on the motherboard.
