Kryonaut drying out? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 36 (permalink) Old 04-04-2019, 10:32 AM
Waiting for 7nm EUV
tpi2007's Avatar
Rep: 880 (Unique: 498)
Kryonaut is still a relatively new thermal paste isn't it? It will take a while before we know the long term reliability of it under a plethora of testing conditions, but after a month or two, seems weird.
As others also mentioned, I'm also using Arctic Cooling MX-2 and MX-4 (the difference between them is only 1-2C). I've had the same MX-2 applied on my i7-3820 for the past seven years without any problems and the temps are the same as seven years ago.
Is your CPU bottlenecking your GPU ? Find out: CPU and GPU usage along with FPS in-game
Read my reviews here.
Clubs (founder): The rare / unusual CPU club
Clubs (member): Corsair Professional HX / AX Series PSU Owners Club || The Official Cooler Master HAF X/932/922/912(+) Club
Core i7-3820
Asus Sabertooth X79
MSI GTX 1060 6 GB Gaming X
16 GB Corsair DDR3 1866 Mhz Dominator
Samsung SSD 830 128GB + WD Caviar Black 2TB
Optical Drive
Sony Optiarc DVD-RW
Corsair AX750 Professional Modular 80 Plus Gold
Corsair A70 + Noiseblocker M12-P
Cooler Master HAF 912 Plus
Operating System
Windows 7 Home Premium 64-bit
BenQ RL2455HM
Keyboard
Cooler Master Octane
Mouse
tpi2007 is offline
post #22 of 36 (permalink) Old 04-04-2019, 10:47 AM
skupples's Avatar
Rep: 529 (Unique: 299)
Quote: Originally Posted by 8051 View Post
Quote: Originally Posted by skupples View Post
yep, MX4 is my go to... Mostly because it was one of the few companies selling large volume tubes 6+ years ago.
still using the same tube.
gpu's get painted w/ CLU, n everything else gets MX4.
Is CLU liquid metal? Do you ever have to re-paste that? If so, how often?
It is a liquid metal and don’t get it confused with liquid PRO, ultra is the only one to use from Cool Labs.
Idk, I change things often enough to never run into any issues. (Longest I’ve run it is 1-2 years)
You also become way less anal over time as you learn the hobby inside and out.
Solder pads are pretty cool too, just a PITA to implement. Most folks don’t like having to thermal limit the chip for reflow.
Someone will see a 1-2c change n freak out trying to point blame, all the while it was just 1-2c warmer in your office that day. 😛
skupples is offline
post #23 of 36 (permalink) Old 04-04-2019, 10:49 AM
deepor's Avatar
Rep: 467 (Unique: 314)
@Zfast4y0u @tostitobandito
Those temperature measurements are from somewhere deep inside the cores. I'm sure the surface of the die is not at that temperature, and if you use the IHS and do not do direct-die cooling, then the surface of the IHS is guaranteed to be a lot lower than what you see in HWINFO for the cores.
About how low the temperature on top of the IHS might be, on the websites for their older generations Intel showed a "T_case" temperature, for example here for the 3770k it was 67°C:
https://ark.intel.com/content/www/de...-3-90-ghz.html
That 67°C is the temperature you would expect the IHS to reach while you stress that 3770k enough that it will measure 105°C and keep it there through throttling.
I can't find this T_case stuff for the 9900k, that's why I had to use this old 3770k as the example.
deepor is online now
post #24 of 36 (permalink) Old 04-04-2019, 11:31 AM
Rep: 2 (Unique: 2)
Yeah that's a good point. You'd have to work pretty hard to get the IHS surface itself to 80C, especially considering your heatsink or cold plate is constantly cooling that surface (as well as the paste in between). Your CPU would probably have to be above tjmax for an extended period of time, or your cooler would have to be completely turned off.
tostitobandito is offline
post #25 of 36 (permalink) Old 04-04-2019, 01:08 PM
Overclocker in training
ThrashZone's Avatar
Rep: 54 (Unique: 44)
Quote: Originally Posted by ciarlatano View Post
I'm sure Ectotherm is another TIM simply rebranded. Any idea what it is? They were rebranding GC Extreme prior to the release of this.
Hi,
Reminded me of runny baby poop
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #26 of 36 (permalink) Old 04-04-2019, 02:45 PM - Thread Starter
Hardware Enthusiast
skawster's Avatar
Rep: 13 (Unique: 13)
On the topic on thermal paste longevity, does anyone know what's the shelf life of MX-4, mainly can it exceed 3 years? Noctua states that theirs is 2 years in the tube and 3 years between the CPU and heatsink, but I am curious if anyone has a 3 year old tube of any paste for that matter and how does it behave after all that time? I'm mainly asking as I am kinda fed up of buying TIM every so often and as a few PCs do go through my hands each month I'm looking into getting a 20g or larger tube of something that is as close to bulletproof as it can be.
skawster is offline
post #27 of 36 (permalink) Old 04-04-2019, 03:18 PM
Falkentyne's Avatar
Rep: 375 (Unique: 267)
I Just checked a new 6 year old tube of MX-4.
The very edge of the paste was hardened (around the nozzle) but everything else was just fine. Not using it, though.
Also I've had no problems with Kryonaut. Yes it is a little hardened in the 9900K compared to brand new, but there was no difference between a 2 week old application and a 3 month old application. Temps may have worsened by 2C or so from completely fresh, but remained stable afterwards.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
post #28 of 36 (permalink) Old 04-04-2019, 04:39 PM
Waiting for 7nm EUV
tpi2007's Avatar
8 years for both MX-2 and MX-4, stated on the package for several years now, just checked mine and cross checked with the 2019 editions on their site, it's still the same 8 years. Speaking of which, I just opened a still unopened tube of MX-2 I had lying around for ~3 years and it's fine. I have experience with MX-2 and MX-4 and they last for several years. The MX-2 in my i7-3820 has been there for 7 years and is still going strong. The AXP cooler (also made by Arctic) that I put on a GTX 480 in 2011 came pre-applied with MX-4 and I ran that card for almost 3 years without any temperature problems.
https://www.arctic.ac/eu_en/mx-2.html
https://www.arctic.ac/eu_en/mx-4.html
Core i7-3820
Asus Sabertooth X79
Optical Drive
Sony Optiarc DVD-RW
Operating System
BenQ RL2455HM
Keyboard
Mouse
tpi2007 is offline
post #29 of 36 (permalink) Old 04-04-2019, 05:48 PM
ThrashZone's Avatar
Hi,
Never noticed a born on date
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
Audio
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #30 of 36 (permalink) Old 04-04-2019, 07:23 PM
Not a linux lobbyist
rluker5's Avatar
Rep: 43 (Unique: 34)
Why only ultra? I'm on my second tube of pro and have been exclusively using that for my delidded cpus since 2014. But if ultra is better I wouldn't mind switching. I just like pro because of how thin it is.
Also MX-4 always migrates for me. AS5 beats it without fail after a few months for me. Not at first, but as soon as the application of MX-4 turns to nothing but mineral oil in the interface area it falls back. Maybe I mount my coolers too tight?
L5
(18 items)
Lea2
(11 items)
L7
(11 items)
5950hq
z97 Classified
Aorus 1080ti Waterforce
16 G Gskill Trident @ 2400,cas10,1.575v
16 G Team Extreme @ 2400,cas10,1.575v
2xSamsung 840 EVO 250G
seagate barracuda 3T
Optane 900p 480G OS
Optical Drive
Asus BW-16D1HT
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design R4 (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear
Audio
SoundbasterX AE-5
Other
Megatron
4770k
Asus Z87 Deluxe
Fury Nitro
8Gb patriot 1600mhz
ROG Raidr 240Gb pcie
1Tb WD blue
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
DIYPC P48-W
Operating System
W10 64 pro
40"tv
4980hq
Asus H81T/CSM
16GB 1600 generic
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
50" samsung plasma 720p
Keyboard
Logitech K400+
Other
Intel wifi ac card and noname antennas
rluker5 is offline
