Kryonaut drying out? - Overclock.net - An Overclocking Community
post #1 of 48 (permalink) Old 03-31-2019, 09:09 AM - Thread Starter
Hardware Enthusiast
skawster's Avatar
Rep: 13 (Unique: 13)
pics: https://imgur.com/a/Ykaa4sf
Got some Kryonaut to try out, repasted a few PCs including an old 2600k under a NH-D14, the CPU is OCed to 4.8 @ 1.38v and is predominantly used for gaming and on average sits at ~67C under load. I applied the paste as TG recommends, by spreading it out, and everything seemed fine, the temps were good (very similar to the previous application of Noctua's NT-H1) and nothing seemed wrong.
Yesterday, a month after the initial application, I decided I needed the NH-D14 for another PC so I took it off only to find out that the Kryonaut underneath dried out in the exact spot where the CPU die is, what's weird is that I did run a 15min prime95 v26.6 small FFT test and the temps were exactly as the day I applied it.
I wouldn't care much about the paste drying up as the temps are the same if I also didn't use the same tube of Kryonaut for a GTX 1080ti Poseidon which is in a custom loop and has been exhibiting quite abnormal temps, namely when I first replaced the paste on it the temps were around 14-16c delta (water to gpu temp) but now under the same conditions the have went up to 20-21c and being that the paste on the GPU is a month older than on the 2600k it seems like it's reached a point that it's affecting the temps.
TL;DR Used Kryonaut for the first time, dried up a bit after a month of being used on a 2600k, didn't affect the temps but a GTX 1080ti Poseidon in a custom loop repasted with the same tube is now exhibiting higher temps deciding if I should drain the loop and repaste the GPU.
edit: https://www.overclock.net/forum/61-w...l#post27922914
skawster is offline
post #2 of 48 (permalink) Old 04-02-2019, 05:39 AM
well I have used AS5 for years, and it has always worked well for me. so that is what I would suggest, repaste with AS5.
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #3 of 48 (permalink) Old 04-02-2019, 05:44 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
My Kryonaut did the same and the temps on the GPU raised about 1-2°C after 1-2months and then stayed stable.
Noctua NH1 was little better initially for me, but after 3 weeks the temps raised 4-5°C and in the end the Kryonaut was better long term.
Also GPU's can heat up more with certain games then others, so make sure it's not that. I use Heaven Benchmark to benchmark my GPU since it a good reference to compare temps after a while.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #4 of 48 (permalink) Old 04-02-2019, 06:12 AM
Iconoclast
Blameless's Avatar
Rep: 3149 (Unique: 1877)
Are you sure it was actually dried out and not simply disturbed by thermal expansion/contraction cycles?
I rarely advise just spreading a thin layer of TIM unless both contact surfaces are extremely flat and made of materials with similar expansion coefficients. Putting a small dab in the center after placing a thin later is usually wise, to ensure that there are no voids.
GPU dies also need extra care as they are so large and generally not lidded. A little extra TIM, again to displace any air and ensure there are no voids, as well as to account for any pump out that may occur early on, is something I've always advocated.
I'm not yet convinced of the extreme long term viability of Kryonaut, but only lasting a month sounds like an application error.
AS5 works well enough in most scenarios, but has been long since surpassed in every metric (performance, value, longevity, safety, ease of application, ease of clean up, etc) by a whole slew of more modern TIMs.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #5 of 48 (permalink) Old 04-02-2019, 06:36 AM
NewUser16's Avatar
Rep: 56 (Unique: 37)
I had similar scenario. It did not really dried out but it did hardened slightly and temp went up 1-2C. I changed to MX4 on my CPU and 3x GPUs and from taking apart 4 months later I still think it's one of the best if not the best thermal compounds
NewUser16 is offline
post #6 of 48 (permalink) Old 04-02-2019, 06:47 AM
Overclocker in training
ThrashZone's Avatar
Rep: 176 (Unique: 106)
Hi,
Kryonaut is way over priced and over rated NT-H1 is fine.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
10900k batch # X016E724
z490 ASUS Maximus XII Apex
EVGA 1080ti FTW3
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
ThrashZone is offline
post #7 of 48 (permalink) Old 04-02-2019, 06:51 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
Quote: Originally Posted by ThrashZone View Post
Hi,
^This
ciarlatano is online now
post #8 of 48 (permalink) Old 04-02-2019, 01:22 PM - Thread Starter
Hardware Enthusiast
skawster's Avatar
I just checked a few PCs in my office which I repasted with Kryonaut when I got it two months ago, the paste on all of them has dried out, two have stock intel coolers and one has an Arctic Freezer 33. Not sure what to think of this as the temps did seem fine (although I have nothing to compare them against) but the fact that the paste is dry doesn't seem alright. What's weird though is that I noticed that the remaining paste on the applicator is also dry, I'm not sure if this is possibly a problem of the medium they use for the paste? I've never seen paste dry up on the open in a matter of days granted I've been using mostly NT-H1 for the last 8 years.
Regarding the aplication method I followed it was stated in the "manual" which I got with the tube of Kryonaut, it does seem odd as the paste is far more malleable than Noctua's and their own Hydronaut which I received with the EK waterblock, I've never applied paste by spreading it and I was reluctant to do so as it is very soft and seems even better for the pea method, what's worse is that every application I did was done with the spread method which means I have no idea how it behaves if applied in a different way.
Hi,
Yeah I'll probably stick with NT-H1 for now, I did send Thermal Grizzly and email with these pictures so hopefully they will reply if this is normal or not.
skawster is offline
post #9 of 48 (permalink) Old 04-02-2019, 01:41 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 732 (Unique: 385)
yep, MX4 is my go to... Mostly because it was one of the few companies selling large volume tubes 6+ years ago.
still using the same tube.
gpu's get painted w/ CLU, n everything else gets MX4.
Add me on Steam, same name
skupples is offline
post #10 of 48 (permalink) Old 04-02-2019, 01:58 PM
8051's Avatar
Rep: 30 (Unique: 21)
Is CLU liquid metal? Do you ever have to re-paste that? If so, how often?
8051 is offline
