Algae or something else? - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 04-05-2019, 05:59 AM - Thread Starter
mrschizo's Avatar
Rep: 0
Hello everyone, I have a question if this is algae or something else in my loop. Water blocks are a ek copper ek supremacy evo and ek full coverage nickel plated copper acetal 980ti water blocks. I have always been using distilled water with drops of PT nuke mixed in. I added a new RAM kit and to do this I needed 30mm extensions on CPU for clearance of tubing over the dominators. I checked my cpu and also notice blackish deep brown on my glass reservoir. I'll link the pictures and let me know what I should do next.
mrschizo is offline
post #2 of 12 (permalink) Old 04-05-2019, 06:07 AM
Overclocker in training
ThrashZone's Avatar
Rep: 54 (Unique: 44)
Hi,
Yep pretty much clogged jet plate with what exactly no telling looks like mildew but you don't show what tubing is being used/ black...:/
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is online now
post #3 of 12 (permalink) Old 04-05-2019, 06:09 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
well at this point it is in the GPU water block, and the radiator. as well, the whole build needs to be broke down, cleaned, and reassembled. I would also suggest a the use of Prestone green antifreeze, at a 20% antifreeze, to 80% distilled water mix in the loop, to prevent this kind of issue from ever happening again.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #4 of 12 (permalink) Old 04-05-2019, 06:15 AM
skupples's Avatar
Rep: 529 (Unique: 299)
Don’t use anti freeze if you have any acrylic anywhere. It’ll eat it alive.
Buy mayhems biocide + and inhibitor +
It’s THE best low cost solution on the market right now. 2-3 drops from each bottle, and no more nasties every again.
Mayhems also sells a high test cleaning kit that’ll murder all that biotic nasty
This is not an advertisement. It’s a testimonial from someone that’s been using mayhems for almost a decade with ZERO issues ever. Even after 5 years at one point.
skupples is offline
post #5 of 12 (permalink) Old 04-05-2019, 06:44 AM
this is a absolute myth, as I have been using Prestone antifreeze for 20 years, with acrylic components in my water loops.
[IMG]https://i.imgur.com/IWnnD4Y.jpg[/IMG]
[IMG]https://i.imgur.com/sh5SxSI.jpg[/IMG]
here is a chemical resistance chart that shows Ethylene Glycol as a E, or went 30 days of constant exposure with no damage. Plastic may even tolerate chemical for years
https://www.eplastics.com/blog/chemi...lic-plexiglass
just saying, maybe try not spreading misinformation, as it really does not help newcomers, thanks.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #6 of 12 (permalink) Old 04-05-2019, 06:55 AM
ThrashZone's Avatar
Hi,
Yeah I was under the impression tubing is what might not like anti freeze so changing to some tygon stuff will solve that.
Wish I had originally used 10-15mm fittings so I could of used the thicker hosing but this had to due fittings are expensive x24 for two builds
https://www.usplastic.com/catalog/it...1119&catid=864
https://www.overclock.net/forum/61-w...tectors-7.html
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
Audio
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #7 of 12 (permalink) Old 04-05-2019, 07:08 AM
skupples's Avatar
Interesting, makes me wonder what the true cause ended up being for some of the threads Ive seen over the years. Maybe they weren’t diluting it.
buddy of mine uses a small amount of water wetter in his home made coolant, n he’s supposedly never had an issue either.
In that case -
Just use an otc acid & basic to clean your radiators, don’t wait in line for blitz kits.
However you go about it, your blocks should remain looking near brand new, minus some patina, for years n years when properly maintained against biotics n corrosion. People tend to miss one or the other in the beginning, but heavy dilute antifreeze resolves all that by the jug.
skupples is offline
post #8 of 12 (permalink) Old 04-05-2019, 07:32 AM
In that case -
as for the culprit to this myth, it is alcohol based antifreeze, this is why I stated Prestone specifically.
http://rvlife.com/techtipsrv-antifre...-all-the-same/
so using alcohol based antifreeze, is like purring isopropyl alcohol into your water loop, now that will destroy acrylic.
I did a test with 50% wetter water 50% distilled water it took about a month before the reservoir started to fail and three months before it failed completely. that being said I do use two to three table spoons in my water loops as a tweak to get them to flow a little faster. never have had a issue with it at that concentration of at most 10%.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #9 of 12 (permalink) Old 04-05-2019, 07:41 AM - Thread Starter
mrschizo's Avatar
Rep: 0
So I have black primochill advanced lrt tubing, that antifreeze to distilled water ratio will be fine with that tubing? Also what do I use the best to clean my blocks and radiators with like a solution. And to get that black stain crud off the glass of my reservoir. Thank you for the help. I just don't want this to happen again. Radiators are alphacool nexxxos full copper. Also found out today new pump VP755 V2 makes loud noise that is a problem. Today just really sucks. But I will fix all these issues with the help.
mrschizo is offline
post #10 of 12 (permalink) Old 04-05-2019, 08:04 AM
ThrashZone's Avatar
Hi,
AC Delco doesn't show an ingredient list so no telling what's in it or base is
I just needed some for my truck because that is what was used when my water pump was replaced ac delco gold so that is what I used but under 20% more closer to 10%-15%.
3 cups for 1 gallon
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
Audio
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
